Old 03-14-2014, 04:18 PM   #141
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by mike the snake View Post
That looks SICK!
My BRZ is the same color. Did you have any trouble color matching?
No, paint was computer matched by code (E8H) and came out perfect.
Old 03-14-2014, 06:33 PM   #142
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Details! Modified stock hood or is it an aftermarket hood?
Looks good!
Sellout is offline   Reply With Quote
Old 03-14-2014, 06:52 PM   #143
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Like a BOSS.
Same route I plan on going on my asphalt. Color matched as well. I was thinking of molding in aerocatch pins though for safety. Completely flush with the hood (no exposed hardware) prior to paint. Can you take some pics of the latch setup underneath? If there is a decent amount of material around it and it seems to have a good bonding area maybe I can skip the hood pins
The Following User Says Thank You to spitfire481 For This Useful Post:
Sportsguy83 (03-14-2014)
Old 03-14-2014, 07:03 PM   #144
Sportsguy83
Drives: Limited BRZ
Looks good!
Seibon TS used for about half price of new.
I have no concerns whatsoever of the Lach failing I can take some pics. It closes tighter than stock.
Sent from my SM-N900A using Tapatalk
Old 03-14-2014, 07:18 PM   #145
spitfire481
Drives: 2JZ FRS
Good to hear. My concerns are how much latch material is there behind the inner skin and how well its bonded. I've seen too many fail and fly open at the track. I do feel like that was more a thing of the past and times have changed production wise
Old 03-14-2014, 08:12 PM   #146
Sportsguy83
Drives: Limited BRZ
Old 03-14-2014, 08:20 PM   #147
spitfire481
Drives: 2JZ FRS
Good bit of material around the latch. Makes me feel better. Plus the air pressure escaping the vents instead of putting that much extra force on the skin itself
Old 03-15-2014, 12:30 AM   #148
Ethan
Drives: Subaru BRZ
Originally Posted by cdrazic93 View Post
how much did that cost? if its less than a vented hood then that's definitely do able as a cooling option for me.
I bought the vents from Rally Sport Direct. Not cheap. And I had a body shop do the work, so I spent more $ there too. BUT, it looks stock (unless you are an owner and can tell the difference). So, that is what I paid for -- the stock look but replacing fake with real. It was like a reverse boob job.
Ethan is offline   Reply With Quote
Old 03-15-2014, 03:42 PM   #149
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
hahah works for me
Old 03-16-2014, 02:10 PM   #150
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Looks great! Maybe I'll swap my VS hood for one like this.
kmbkk is offline   Reply With Quote
The Following User Says Thank You to kmbkk For This Useful Post:
Sportsguy83 (03-16-2014)
Old 04-03-2014, 07:46 AM   #151
dp1
driving smoother faster
Drives: Sold
Did anyone compare ambient/intake/water temperatures on track without and then with vented hood and/or Prova vent openings (with cut out hole)?
I read the thread, have Jackson Racing SC, catted and uncoated P&L header, bunch of extra radiators up front (oil cooler, sc cooler, trans cooler, Koyo)...want to know what else I should do to lower temperatures in the engine bay, if anything, before heading out for 8+ track days this year.
Ideally, if I should install vented hood, it wouldn't fly off the car at 120mph+, and it would help by either sucking air in that escapes at the bottom or sucking out air from top...effectively.
Also ideally, if it's the vent opening, it would actually suck air out at speed as opposed to not do much at speed.
Maybe this is too new and unchartered territory, please school me, thank you
dp1 is offline   Reply With Quote
Old 04-03-2014, 08:21 AM   #152
s2d4
s2d4's Avatar
Double coat your header with the 2200+ temp stuff, coat the inside with coating that can with handle direct contact with fire.
Or get inconel heat shields/wrap.
EDIT: catted just wiped out the coating options.
The Following User Says Thank You to s2d4 For This Useful Post:
Sportsguy83 (04-03-2014)
Old 04-03-2014, 08:58 AM   #153
raven1231
Originally Posted by charged86 View Post
can you multitask son!!!
Multitasking is impossible
Old 05-24-2014, 12:45 PM   #154
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Does anyone have a before and after data that shows the effectiveness of the vented hoods and/or side vents (cut by dremel)? Thanks in advance
glamcem is offline   Reply With Quote
snails and turbos carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 10 12-27-2012 04:44 PM
Turbos making less power down low? subatoy Forced Induction 40 10-03-2012 02:30 AM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 04:44 PM
Why does the aftermarket love turbos? Why not superchargers? ahausheer Other Vehicles & General Automotive Discussions 43 07-22-2012 10:27 AM
For those crying about turbos Mari0 Off-Topic Lounge [WARNING: NO POLITICS] 2 06-15-2012 09:57 PM
