Old 03-03-2014, 11:10 AM   #127
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by blackfireball5 View Post
Ironsquid, do you prefer the Varis hood that has the small scoop with the vents over the one that has only the vents? How large of a difference does that small scoop make you think?
The naca scoop will direct air into the engine bay, the side vents pull air out. Without the naca scoop you wont have a circular air venting system and you'll just have to rely on heat rising out the vents.
Ironsquid is offline   Reply With Quote
Old 03-03-2014, 11:44 AM   #128
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
I remember reading something about making any kind of scoop would disrupt the flow of air going through the radiator and that having vents alone are more effective at keeping the air flowing through the radiator and out the vents? Or maybe that was speculation and there isn't that big of a difference.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 03-04-2014, 12:10 AM   #129
Ethan
Drives: Subaru BRZ
I replaces my BRZ faux vents with the Prova real ones. I had a body shop do the work. It looks completely stock unless you are a twins owner and know what you are looking at. All it took was cutting a hole and then sealing the newly exposed metal with primer. The Prova replacement part took a bit of sanding on the backside too to get a factory looking fit. As to how much heat does it evacuate? I did not do a before and after on engine bay temps so could not really say. I can tell you that when it is 80 degrees outside and I drive the car hard, after I park I will put my hand over the vent and the heat is substantial. I presume that when I am moving, even more heat is being sucked out because of negative pressure created by the shape of the molding in front of the vent opening. If anyone knows of a tape that changes color based on temp, I would get some and stick it to the vent as a test.
As to potential water damage, I don't think so. Water would have to be going at a weird upwards angel to get into the engine bay through the side vent. I would worry about a vented hood and water damage, but not the side vents.
Finally, the real reason I did it was I hated the faux vent.
Ethan is offline   Reply With Quote
The Following User Says Thank You to Ethan For This Useful Post:
bama_brz (07-18-2014)
Old 03-04-2014, 01:24 AM   #130
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Scoops bad, vents good. Anything you can do to exhaust the fenders and the engine bay will improve cooling and downforce.
Element Tuning is offline   Reply With Quote
Old 03-14-2014, 01:03 AM   #131
Ethan
Drives: Subaru BRZ
Here is a pic of my conversion. You can't tell, but the fender is cut behind the mesh of the new functional vent.
bama_brz (08-06-2014)
Old 03-14-2014, 02:23 AM   #132
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
how much did that cost? if its less than a vented hood then that's definitely do able as a cooling option for me.
Old 03-14-2014, 10:12 AM   #133
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The Prova vents are about the price of a vented hood.
http://www.rallysportdirect.com/Prov...rld-Rally-Blue
Old 03-14-2014, 11:12 AM   #134
mike the snake
If you are handy with a dremel, you can make basically the exact same vents out of the BRZ fender garnishes for no $$.
Old 03-14-2014, 11:27 AM   #135
mrk1
Drives: Sterling BRZ Ltd
I was all for the Prova vents and cutting the fender till I saw that price
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 03-14-2014, 01:28 PM   #136
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Those are fine, I was talking like Seibon CF vented hood price lol
Old 03-14-2014, 02:39 PM   #137
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Like a BOSS.
The Following 7 Users Say Thank You to Sportsguy83 For This Useful Post:
86-tundra (05-25-2014), cdrazic93 (03-15-2014), charged86 (04-03-2014), diss7 (05-30-2014), GhostOp86 (12-24-2015), mack4477 (03-16-2014), OjiGeorge (03-15-2014)
Old 03-14-2014, 02:43 PM   #138
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
@Sportsguy83 ricer.........
Jk
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Sportsguy83 (03-14-2014)
Old 03-14-2014, 02:45 PM   #139
Sportsguy83
Drives: Limited BRZ
Jk
I love me some R.I.C.E.!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
raven1231 (04-03-2014)
Old 03-14-2014, 03:59 PM   #140
mike the snake
That looks SICK!
My BRZ is the same color. Did you have any trouble color matching?
Like a BOSS.
The Following 2 Users Say Thank You to mike the snake For This Useful Post:
kmbkk (03-16-2014), Sportsguy83 (03-14-2014)
snails and turbos carbonBLUE Off-Topic Lounge [WARNING: NO POLITICS] 10 12-27-2012 04:44 PM
Turbos making less power down low? subatoy Forced Induction 40 10-03-2012 02:30 AM
Carbon Fiber Hoods. Asterisked Accolade Cosmetic Modification (Interior/Exterior/Lighting) 17 09-25-2012 04:44 PM
Why does the aftermarket love turbos? Why not superchargers? ahausheer Other Vehicles & General Automotive Discussions 43 07-22-2012 10:27 AM
For those crying about turbos Mari0 Off-Topic Lounge [WARNING: NO POLITICS] 2 06-15-2012 09:57 PM
