Old 03-07-2014, 08:51 AM   #57
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by regal View Post
My car idles at 900 rpm from a cold start in the single digit (5 degreees F), is that not normal? maybe explain the long warm up time? The car is 100% stock.
nope not if you are talking about a soaked cold start. In other words, if the car sits over night you go out and crank it, the initial crank should kit up to 1500 rpm and hold that for 20 - 30 seconds before it drops out of the initial high idle. After that, the idle target is controlled by the coolant temp vs idle target tables. Depending on the ambient temps, and thus coolant temps, the 2nd stage high idle (before full operating temp) may be just under 1500 rpm or as low as the warmed up idle target of 750.. just depends on coolant temp.
Sounds like you have a tune that messed with the cold start routine or fault with the cold start system. Might also check coolant levels and make sure there is no air in the system and check your thermostat is not stuck open.
Old 03-07-2014, 10:40 AM   #58
regal
Drives: Scion FR-S/Toyota Yaris
Thanks I a ready changed the thermostat, wasn't it. In hindsite it reaches op temp at about the same spot every day. I bought it new though so I can't imagine the ecu being messed with. Will bleed the coolant it does point to air entrapment.
thanks.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-07-2014, 11:04 AM   #59
FR-S Matt
Mine definitely idles higher when it is colder outside, (30-40 degrees) and idles much lower when warmer (60+). Figure it's just trying to get fluids up to operating temperature quicker based on outside temp. I wouldn't try removing this feature.
Old 03-07-2014, 11:07 AM   #60
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Yeah, mine will hit close to 2k idle on start up if it's really cold outside, and if I leave it idle I don't think it gets any lower than 1500 until I've started moving.
Nevermore is offline   Reply With Quote
Old 03-07-2014, 11:17 AM   #61
troek
troek's Avatar
Drives: 2012 Toyota 86
its fairly well accepted that the extra loud period is just to warm up the cat. i dont give a crap about my cat, i just wana be able to start my car in the morning without feeling like a jerk, while enjoying a nice exhaust set up. i WILL figure out how to remove this lol.
troek is offline   Reply With Quote
Old 03-07-2014, 11:51 AM   #62
mad_sb
Lol, I'm with you. The thing is the cold start logic is not exposed in the rom deff's yet. You can change the base ignition timing during the soaked cold start (stock is -15 i think but it has been a couple weeks since i looked at that param) and you can change the target idle once you have exited the soaked cold start.
But you cannot disable the soaked cold start logic yet or modify the SOI point during this phase. So, you end up over shooting the target high idle, taking longer to "light" the cat off and kick down to a lower fast idle, and triggering any of a number of CEL's from post start ignition timing error to idle control malfunction. You can turn off those codes but it still does not have the desired effect of going back to a more traditional cold start sequence.
I think it will require a rom patch to disable the logic.
Old 03-07-2014, 07:14 PM   #63
troek
troek's Avatar
Yeah i hear ya, im just hoping someone will reverse engineer that part of the ecu so we can disable it.
Old 03-08-2014, 06:12 AM   #64
Kodename47
Kodename47's Avatar
Drives: UK GT86
It is possible with ECUtek. I have it on my car and I've put it onto someone else's car too. There's a fair few tables you need to adjust though to make it work properly.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-08-2014, 07:48 AM   #65
regal
@mad_sb I changed the thermostat (OEM and the old one never ove heated anyway), bled it, the car still has the shitty stock 2012 ECU/ROM and after sitting over night below 15F it idles at 900rpm for 10 minutes it takes a about 13 minutes of driving 2k-4k rpm to fully warm up. The car is 100% stock. The temp guage works and holds steady at 50% once warmed up. At -3F one morning it idled at 900 rpm and didn't stumble at all smooth as butter.
I'm not about to go the dealer only to be told the latest flash (with the DI fix) is unavailable so I guess this is the final straw in getting BRZ Edit or trying rom/raider/ecuflash. Any other advice?
Thanks
Mods:
Old 03-08-2014, 07:53 AM   #66
arghx7
Drives: car
Thanks
Are you starting it with the engine in neutral or in gear (guessing it's a manual)?
Old 03-08-2014, 08:08 AM   #67
mad_sb
Thanks
So, after sitting over night in 15 degree temps, as soon as it fires up it immediately drops down to 900 rpm? No 20 - 30 seconds of 1500 rpm loud fast idle before it kicks down to 900?
Once warmed up fully, does it idle between 650 and 750?
If it is doing what it sounds like your describing I'm at a loss. If it really doesn't do the normal cold start sequence it should throw a code for sure, possibly multiple codes. Since it does not sound like it's coding either, your best bet might be to take it to the dealer (as much as that sucks) if you can make it stock enough. Even if they don't fix it they can at least document it in case it becomes a bigger issue latter on. It would have to sit over night and they would need another car for a cold start comparison.
Lemme know if you figure out what the issue is, sounds interesting for sure.
Old 03-08-2014, 08:22 AM   #68
troek
troek's Avatar
i dont think these tables are available in RomRaider yet.
Old 03-08-2014, 12:04 PM   #69
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Care to share which tables?
Td-d is offline   Reply With Quote
Old 03-08-2014, 12:13 PM   #70
regal
yes 900 from the get-go. The only thing not stock are 16" WRX winter tire wheels sans the air pressure senders. I think I may buy the equipment to flash to the latest factory tune as my only trip to the dealer was for that early CEL flash that had to do with idle. I want to be able to DIY as much as I can anyway.
Mods:
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-12-2015 11:53 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 06:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 01:35 PM
