#57 | |
Drives: 2013 Asphalt FR-S
Sounds like you have a tune that messed with the cold start routine or fault with the cold start system. Might also check coolant levels and make sure there is no air in the system and check your thermostat is not stuck open.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | jcw99 (08-08-2016) |
#58 | |
Drives: Scion FR-S/Toyota Yaris
Thanks I a ready changed the thermostat, wasn't it. In hindsite it reaches op temp at about the same spot every day. I bought it new though so I can't imagine the ecu being messed with. Will bleed the coolant it does point to air entrapment. thanks.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
#59 |
Mine definitely idles higher when it is colder outside, (30-40 degrees) and idles much lower when warmer (60+). Figure it's just trying to get fluids up to operating temperature quicker based on outside temp. I wouldn't try removing this feature.
#60 |
Wayward Member
Drives: Hot Lava 86
Yeah, mine will hit close to 2k idle on start up if it's really cold outside, and if I leave it idle I don't think it gets any lower than 1500 until I've started moving.
#61 |
Drives: 2012 Toyota 86
its fairly well accepted that the extra loud period is just to warm up the cat. i dont give a crap about my cat, i just wana be able to start my car in the morning without feeling like a jerk, while enjoying a nice exhaust set up. i WILL figure out how to remove this lol.
| The Following User Says Thank You to troek For This Useful Post: | Chad86 (05-09-2016) |
#62 | |
But you cannot disable the soaked cold start logic yet or modify the SOI point during this phase. So, you end up over shooting the target high idle, taking longer to "light" the cat off and kick down to a lower fast idle, and triggering any of a number of CEL's from post start ignition timing error to idle control malfunction. You can turn off those codes but it still does not have the desired effect of going back to a more traditional cold start sequence. I think it will require a rom patch to disable the logic.
~Namaste~ |
| The Following User Says Thank You to mad_sb For This Useful Post: | Chad86 (05-09-2016) |
#63 |
Yeah i hear ya, im just hoping someone will reverse engineer that part of the ecu so we can disable it.
#64 |
Drives: UK GT86
It is possible with ECUtek. I have it on my car and I've put it onto someone else's car too. There's a fair few tables you need to adjust though to make it work properly.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Chad86 (05-09-2016) |
#65 | |
I'm not about to go the dealer only to be told the latest flash (with the DI fix) is unavailable so I guess this is the final straw in getting BRZ Edit or trying rom/raider/ecuflash. Any other advice? Thanks
#66 | |
Drives: car
#67 | |
Once warmed up fully, does it idle between 650 and 750? If it is doing what it sounds like your describing I'm at a loss. If it really doesn't do the normal cold start sequence it should throw a code for sure, possibly multiple codes. Since it does not sound like it's coding either, your best bet might be to take it to the dealer (as much as that sucks) if you can make it stock enough. Even if they don't fix it they can at least document it in case it becomes a bigger issue latter on. It would have to sit over night and they would need another car for a cold start comparison. Lemme know if you figure out what the issue is, sounds interesting for sure.
~Namaste~ |
#68 |
#69 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
#70 | |
yes 900 from the get-go. The only thing not stock are 16" WRX winter tire wheels sans the air pressure senders. I think I may buy the equipment to flash to the latest factory tune as my only trip to the dealer was for that early CEL flash that had to do with idle. I want to be able to DIY as much as I can anyway.
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-12-2015 11:53 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 01:35 PM |
