Old 03-05-2014, 05:43 PM   #29
tomaszjanczak
Drives: Silver Subaru BRZ
If you follow the clutch travel all the way to the back, you'll see it hits a thin rubber piece. The hole is behind the rubber piece, you have to take it out to see it
tomaszjanczak is offline   Reply With Quote
Old 03-06-2014, 12:32 AM   #30
Vlady
Vlady's Avatar
Drives: Argento Scion FRS
Originally Posted by JDKane527 View Post
Home depot and Lowe's don't have the exact rubber stopper, but a quick browse on McMaster-Carr would get you what you need.
http://www.mcmaster.com/#9541k2/=qxu4k1
Pack of 25 for $11.26.
Thanks man! but what to do with the rest? Could change it 25 times.. but don't know about that.
Vlady is offline   Reply With Quote
Old 03-07-2014, 08:03 PM   #31
sanmarcosfrs
sanmarcosfrs's Avatar
Drives: 2013 asphalt frs
Originally Posted by enjoyminutemaid View Post
All hail the WORKS KICK CLUTCH PEDAL STOP!
I just bought this and installed it (it's a PIA if you have big fingers, but still less than 10 min). If you are the kind of manual driver who typically pushes the clutch all the way to the floor every time you shift - as opposed to only pushing it as far as necessary - then get this and install it. I am in love with the difference it makes. I know it seems silly in theory, and it's a lot of money for what it is, but I really like mindlessly pushing the clutch to the floor and getting quick, consistent engagement.
Thanks again for the write up! Bought another after 86 industries never sent me one... Anyways, makes the car so much better to drive! Wound up costing me nearly 80 bucks by the time I ordered another etc... Don't care, worth it!!
sanmarcosfrs is offline   Reply With Quote
The Following User Says Thank You to sanmarcosfrs For This Useful Post:
enjoyminutemaid (03-08-2014)
Old 03-07-2014, 08:10 PM   #32
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Has anyone combined this with the LOWERING of the actual engagement point? As seen in the DIY thread.
leicaboss is offline   Reply With Quote
Old 03-07-2014, 08:13 PM   #33
sanmarcosfrs
For me it's perfect with stock engagement point combined with the new stop. Faster shifts and much easier to drive smoothly around town. I have always hated the feel of the stock clutch until now
Old 03-07-2014, 08:29 PM   #34
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
So how much to send me one?
Old 03-07-2014, 08:37 PM   #35
rupert
Audio & Bacon Junkie
rupert's Avatar
Drives: 2013 WRB BRZ Ltd
+1
rupert is offline   Reply With Quote
Old 03-07-2014, 08:53 PM   #36
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
I'll have to get back to you guys if the forum will let me do a "groupbuy". I'm local to McMaster-Carr in Santa Fe Springs.
I've done this in the past with the JDM Underpanels without any issue. Just to get an idea, how many people would be interested in a complete clutch stop kit costing less than $10 with all necessary hardware including optional washers?
JDKane527 is offline   Reply With Quote
The Following 4 Users Say Thank You to JDKane527 For This Useful Post:
rupert (03-07-2014), Sportsguy83 (03-07-2014), starbot (04-11-2014), TM (04-24-2014)
Old 03-07-2014, 09:21 PM   #37
Sportsguy83
Drives: Limited BRZ
I'd do it for 10 shipped.
Whitefrs hates my phone signature
Old 03-07-2014, 09:53 PM   #38
rupert
rupert's Avatar
I'd be down for it as well.
Old 03-07-2014, 10:07 PM   #39
Cuchullain
Cuchullain's Avatar
Drives: 2013 GBS Subaru BRZ Limited
In for that!
Cuchullain is offline   Reply With Quote
Old 03-07-2014, 11:27 PM   #40
regal
Drives: Scion FR-S/Toyota Yaris
Is the clutch rlease switch down there, could be playing with fire if the ecu does see the switch and doesn't switch to the transient ignition retard table?
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-08-2014, 01:46 PM   #41
JDKane527
JDKane527's Avatar
It could be an issue if you aren't able to fully disengage the clutch with a higher clutch stop. Every car is different so if you did modify the travel, it may require adjusting the switch. It should be a 14mm nut on the switch that you need to adjust iirc.
Old 03-10-2014, 01:32 PM   #42
FR-Slide
Drives: 13 Whiteout 6MT
$10 shipped? Shut up and take my money
FR-Slide is offline   Reply With Quote
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 02:03 PM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
DI seal improved material radroach Engine, Exhaust, Transmission 21 01-16-2014 12:42 AM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
