Old 03-05-2014, 12:07 PM   #351
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
Originally Posted by Jesse@JDLAutodesign View Post
I'm gonna get my car on the lift over the weekend and check it out. We've been slammed getting orders out. I'm anxious to know.
I'm anxious to hear if the EL will work with the KW as well. I'm in the market for Header and 3" all the way back. Need to talk to you guys about 3" OP and FP at a minimum since you dont have a CBE yet.
digital_assassin is offline   Reply With Quote
Old 03-05-2014, 12:20 PM   #352
nelsmar
Originally Posted by DAN_BRZ View Post
how accurate are virtual dynos? those number are impressive considering you still have the stock op/fp.
Depends on driving conditions, how flat the road is, accuracy of car data etc. I was doing virtual dyno set to 'dynojet' on a specific piece of road before putting my car on a MAHA (reads quite low) and with the settings I was using it was within a few %. But I was using slightly different settings than others and it seems now that it is colder it may be less accurate. If the pulls are on the same road, and in the same climate conditions fairly close together then it can actually show a realistic difference. I have used it from time to time on street tuning but doesn't work for very minor adjustments.
So using it as before & after, as long as temperature is the same (verify your atmospheric pressure & temperature and take notes) if its more than a few % difference than it can be seen as a positive way to check for gain. But using it for actual WHP #'s is not very dependable.
I also notice that your running a good half a point and or more AFR richer in the "after" plot. If by chance it is fuel trim related then once it leans out gains may be better.
My flickr - Canibeat
Local magazine scout
The Following User Says Thank You to nelsmar For This Useful Post:
DAN_BRZ (03-07-2014)
Old 03-06-2014, 11:53 PM   #353
SpatulaCS
SpatulaCS's Avatar
Drives: 2013 Scion FR-S Ultramarine
Installed the UEL headers today and took the car for a quick spin. Initial impressions were good. I haven't received the OFT yet so this is based just on the header but the difference in power is noticeable. Revs through the powerband much quicker and the torque dip definitely feels smaller.
The sound though.......wow! The car is a little louder than I was hoping for but I was expecting this due to removing a cat from the system. That subie rumble is fierce. Still no drone but open up the throttle and prepare to change your pants! Sounds very clean and crisp with no rasp. Definitely happy with it.
Unfortunately, I have a leak somewhere. I'm assuming it's due to the inner bolts connecting the header to the engine as, even with an elbow joint, they are difficult to tighten down. The car didn't throw any codes though but I'm not entirely sure if it would with a small leak there. I'll give all the bolts a once over tomorrow and hopefully that'll take care of it.
Once the OFT shows up and I get the new tune on there, I'm sure this car will really come alive!
SpatulaCS is offline   Reply With Quote
Old 03-07-2014, 12:13 AM   #354
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
I think I also have a leak in the headers. I hear a slight ticking on partial throttle but not at WOT or idle. I am not 100% sure if it is leaking or not though. Anyone know how to tell for sure, and is it bad to drive a few hundred miles on a leak, I can't get to it til next weekend!
Also, I got a CEL for a missing cat. I have heard that this shouldn't cause issues, but is it true? I am planning on getting a tune in May sometime.
IAmNotTheDriftKing is offline   Reply With Quote
Old 03-07-2014, 01:38 AM   #355
Pen.suhl
Drives: 2013 WRB BRZ Limited
What is you're order number? We have 6 shipping tomorrow. I'm betting you're probably one of those if its been 6 weeks.
#1306?
Pen.suhl is offline   Reply With Quote
Old 03-07-2014, 02:11 AM   #356
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
Called the coater on that today. Will be shipping tomorrow
JDLAutoDesign is offline   Reply With Quote
Old 03-07-2014, 02:13 AM   #357
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Anybody else shipping tomorrow?
BatStig is offline   Reply With Quote
Old 03-07-2014, 02:20 AM   #358
JDLAutoDesign
Drives: 13 FRS
A bunch of UELs. We have the ELs being built
Old 03-07-2014, 02:41 AM   #359
SpatulaCS
SpatulaCS's Avatar
I also have the ticking (mine is fine at idle and low partial throttle but starts ticking at maybe 50-100% throttle) along with exhaust smell from the engine bay. I'm hoping I'll be able to tighten the bolts more but if not I'll be SOL.
I have an o2 spacer and haven't gotten the CEL so you may want to look into that if you don't want the light.
Old 03-07-2014, 02:52 AM   #360
IAmNotTheDriftKing
You are usually supposed to retighten the header bolts after a week or so. I can't do it this weekend, but next weekend I definitely will! Try getting some thicker gaskets as that can fix the problem as well.
And doesn't a spacer mess with AFR readings?
Old 03-07-2014, 03:41 AM   #361
SpatulaCS
SpatulaCS's Avatar
I put new Grimmspeed gaskets in for the engine/header connection. The provided gasket for the overpipe doesn't instill much confidence. I don't believe that is the source of the leak though but I'll check anyway.
I'm pretty sure the primary o2 sensor is for the AFR readings, not the secondary, so a spacer on the secondary o2 sensor should be fine. I'm not an expert though so somebody else may have a better answer. A lot of people seem to use them without issues though.
Old 03-07-2014, 06:55 AM   #362
FR-S Matt
That ticking noise you hear on cold start I believe is normal. I have all Grimmspeed gaskets on the header, OP in both spots. I get the noise only on cold start. 0 exhaust smell. I believe it's due to the thinner walls of the header.
Wish there was a better tool to use to torque the bolts on the header. I was using knuckle joints to get to some of them.
Old 03-07-2014, 10:30 AM   #363
JDLAutoDesign
Drives: 13 FRS
We had a similar ticking with a local car. I loosened the nuts on the head flanges, torqued the pass side first (stating with the single nut then working to the 2 rear), then the same thing on the drivers side. That cleared up the ticking.
The Following 5 Users Say Thank You to JDLAutoDesign For This Useful Post:
BatStig (03-08-2014), FR-S Matt (03-07-2014), Freeman (03-07-2014), Ryan P (03-07-2014), SpatulaCS (03-07-2014)
Old 03-07-2014, 11:25 AM   #364
FR-S Matt
Looks like you gave me something to do this weekend. I thought it was my gaskets so I got the best ones. May just need a good proper torquing. The 20 ft lbs sure feels light connected to the block. I'll give this a shot and report back. If there is a leak, it is extremely minor and I cannot smell anything at all. Only occurred during cold start.
Also Ronnie/Jesse, what tool are you guys using to torque these nuts around the crazy bends on the runners? 0 issues getting to two of them, but there's one on both sides that is rough to hit with an extension and knucklejoints.
JDL Auto Design ft_sjo User/Vendor/Sponsor Reviews, Feedback, Comments 58 04-28-2017 11:13 AM
JDL Auto Design alexand3r User/Vendor/Sponsor Reviews, Feedback, Comments 4 12-11-2013 01:05 PM
New Scion FR-S products by Coverking are now at TAP Auto parts TAP Auto Parts Interior Parts (Incl. Lighting) 9 06-06-2013 08:43 AM
Check out some of the new products from Auto Finesse DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 05-08-2013 09:42 AM
JDL Auto Design...What We Do JDLAutoDesign Announcements, Contests, Giveaways 21 10-30-2012 10:05 PM
