Old 03-06-2014, 02:57 PM   #3837
Grantmac
Drives: 2001 NB MX-5
Originally Posted by zoth View Post
Ready to buy, just want to make sure to get in for the 2nd batch. Not unless he will produce a bunch of them. Also interested in the bigger q*300. Just like I told him on the e-mail. I think my hot & humid location in S. Texas would be a great test are for the kit.
The TQ300 is likely at least 8 months away. It's just in the beta phase right now.
-Grant
Grantmac is offline   Reply With Quote
Old 03-06-2014, 04:06 PM   #3838
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
-Grant
Any guesstimate on how much it will be to upgrade from TQ250 to TQ300?
robwbright is offline   Reply With Quote
Old 03-06-2014, 04:10 PM   #3839
fenton
No idea. Rob has said there will be a upgrade option. The main thing is that you have the beefier control box that can do 5.5kw. So far everyone except for a couple of the very early testers have the bigger controller.
Once you have the controller it is a simple compressor swap.
The only catch is that the draw of the tq300 means you need more battery capacity and recharge capacity to run it as long as the 250.
For all these reasons it is still in testing. If you are on the fence about the 250 don't worry, Rob is a fair guy and will have a upgrade / swap plan for those looking for more
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
The Following 3 Users Say Thank You to fenton For This Useful Post:
DAEMANO (03-06-2014), Gums (03-06-2014), robwbright (03-06-2014)
Old 03-06-2014, 04:15 PM   #3840
robwbright
Thanks for the quick response. I'm guessing I'd be satisfied with the 250+header+tune...
But you never know.
It's not so much a matter of on the fence as that while I work full time as in house counsel for a corporation, I'm funding car upgrades on the little bit of work I do on the side. Waiting on 3 checks to get here before I make a final decision on what upgrades to buy.
The Following User Says Thank You to robwbright For This Useful Post:
fenton (03-06-2014)
Old 03-06-2014, 04:22 PM   #3841
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Luckrider View Post
Porque no los dos?
Seriously, I would be interested to find out if someone could make them work together efficiently so you get gobs of low end torque with plenty of top end power that continues to build rather than taper. THAT would be an impressive track monster.
http://www.wildweasel.ca/HowTo/Auto/eturboTest.aspx
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 03-06-2014, 04:37 PM   #3842
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by mid_life_crisis View Post
I did actually read that and that is what makes me think it would work well with this car.
-Thomas
Luckrider is offline   Reply With Quote
Old 03-06-2014, 05:32 PM   #3843
Robftss
Drives: VW
Name:  harness improv.JPG
@BuTang and I installed this new harness.
- auto on/off relay integrated into cable
- tint/diffuser on digital display
- one wire with ATM fuse for switched +.
We found a great switched source located in the fuse box under and to the left of the steering column. The ATM fuse just plugs into a vacant spot! The relay sits in the pass-through in the center console about 2 1/2' from the fuse box.
I will be adding this to the kits as well as routing instructions to the install manual.
THANKS BUTANG!!! (~10 mins for him to install and tuck/ zip tie)
Robftss is offline   Reply With Quote
The Following 9 Users Say Thank You to Robftss For This Useful Post:
Bu-Tang (03-11-2014), DAEMANO (03-06-2014), dnavas (03-12-2014), Gums (03-06-2014), keen as (03-06-2014), s2d4 (03-08-2014), SloS14 (03-06-2014), waterbison777 (03-06-2014), WRB5titch (03-06-2014)
Old 03-06-2014, 05:34 PM   #3844
TM
TM's Avatar
Drives: DGM BRZ 6MT
Nicee. Excited for when the second batch becomes available
TM is offline   Reply With Quote
Old 03-06-2014, 06:21 PM   #3845
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Robftss View Post
Attachment 69424
Nice work.
Installed Mods:
Old 03-06-2014, 08:35 PM   #3846
waterbison777
Attachment 69424
Will this be available for the early adopters who already purchased a kit?
Sent from my Nexus 4 using Tapatalk
waterbison777 is offline   Reply With Quote
The Following 2 Users Say Thank You to waterbison777 For This Useful Post:
DAEMANO (03-06-2014), raven1231 (03-06-2014)
Old 03-06-2014, 09:27 PM   #3847
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Do you have a waiting list for the second batch? If you do I would like to be on it.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 03-06-2014, 10:06 PM   #3848
Sojhinn
Sojhinn's Avatar
Got the parts rob! And look I can follow directions! Name:  ImageUploadedByTapatalk1394161582.112869.jpg
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Robftss (03-07-2014)
Old 03-06-2014, 10:54 PM   #3849
raven1231
This?
Old 03-06-2014, 11:11 PM   #3850
SimplePortal
Drives: Hot Lava
does this require an aftermarket header, or can it just work with the stock header and OFT?
SimplePortal is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
