Old 11-26-2013, 11:25 PM   #1
Sciby
Sciby's Avatar
Drives: 2013 MY14 WRB BRZ
Wheel Directory: Enkei Tenjin 18x8.5 +45/18x9.5 +45
Since I've used posts in here as reference, should only be fair that I post these photos up - I haven't seen any/many photos of Tenjins... forgive me for the fronts not being straight, but they're perfectly flush. The rears stick out a wee bit though. Suspension is stock. (yes, I know the parking is a shit effort. )
Wheels: Enkei Tenjin 18x8.5"/9.5" with +45 offset all round.
Tyres: Yokohama Advan AD08R's, 235/40R on the front, 265/35R on the rear.
Sciby is offline   Reply With Quote
The Following 2 Users Say Thank You to Sciby For This Useful Post:
Abdulla827 (12-01-2013), normancw (11-27-2013)
Old 11-27-2013, 02:29 AM   #2
FunCon5
FunCon5's Avatar
Very nice! Enkeis & Advans a match made in heaven! Perfect sized tires! Looks amazing!
FunCon5 is offline   Reply With Quote
The Following User Says Thank You to FunCon5 For This Useful Post:
Sciby (11-28-2013)
Old 12-01-2013, 09:11 AM   #3
Abdulla827
Drives: GT86
Excellent choice of rims, looking forward to some more pix!
Abdulla827 is offline   Reply With Quote
Old 12-02-2013, 05:35 PM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 03-03-2014, 04:51 AM   #5
MagicBobert
MagicBobert's Avatar
Drives: 2014 WRB BRZ Limited
What size tires for 18" Enkei Tenjins?
This is my first time doing wheels/tires, so I've been doing tons and tons of reading.
I'm looking at these 18" Enkei Tenjin's, with 18x8.5 in the front, 18x9.5 in the rear, +45 all around.
I'm on the stock suspension and have no intention of lowering the car. It's mostly a daily driver, but I'd like to try some AutoX this year. I'm leaning toward the Pilot Super Sport tires for a balance between these needs.
Some previous tire fitments I've found for this setup:
I've played around a bit with these different tire sizes on the fitment calculator. With my inexperience I'm not quite sure what I should be looking for when comparing them. Any thoughts? Am I overthinking this?
Thanks!
MagicBobert is offline   Reply With Quote
Old 03-03-2014, 06:29 AM   #6
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
225/40/18 for front on 8.5" wide and 255/35/18 on rear 9.5" wide wheels will do fine.
Note if you're stock height you're going to stick out on the ass end due to next to nill camber with 9.5" wide wheels, even at that offset. Also as you mention you'll be doing auto X do squared setup instead therefore 225/40/18 square in the mpss as you mention
Cheers
Old 03-03-2014, 08:40 AM   #7
IAmNotTheDriftKing
IAmNotTheDriftKing's Avatar
Drives: I own an FR-S. . . whatelse!
If you are planning on autocrossing, you may want a square set up all around. Otherwise you will notice more understeer while autocrossing.
IAmNotTheDriftKing is offline   Reply With Quote
Old 03-03-2014, 10:00 AM   #8
ZDan
ZDan's Avatar
Drives: '23 BRZ
IMO, 18s will look kinda goofy at stock ride height, I'd go 17s. Also recommend going same size all around as mentioned above. Low-powered car with front-biased weight distribution doesn't really want wider rear wheels/tires. I'd go 8" or 8.5" all around.
I'd make sure the tires are 25" or smaller in diameter (255/40-18 are 26"). Taller tires will hurt acceleration and overall performance.
I'd be looking at 8" - 9" wheels with 225/45-17 (225/40-18), 235/40-17 (235/35-18), or 245/40-17 (245/35-18).
The Tenjins are kinda heavy, too, which will impact performance a bit. If you really really want 18s and like the 9-spoke black w/ machined lip style, I'd get the O.Z. Allegerita 18x8: http://www.tirerack.com/upgrade_gara...14&showRear=no
Only $60 more per wheel vs. Tenjin, and 4 lb. lighter at 17.5 vs. 21.5.
Personally not a fan of black-painted wheels, though the machined lip does give some relief...
Old 03-03-2014, 02:48 PM   #9
MagicBobert
Thanks for the help guys!
Old 03-21-2014, 05:05 AM   #10
Lemar58
Drives: Scion FR-S
These are so nice. I'm sitting on eibach sport line springs lowers about 1.3". Any idea how these would look? Wheels are not my thing :/
Lemar58 is offline   Reply With Quote
Old 11-10-2014, 01:53 AM   #11
Sciby
Sciby's Avatar
So I thought I'd give you guys an update on these: I've had them on the BRZ since November 2013 and at first they were fine, but now I have a job in the city which I need my car for, so I'm in peak hour traffic, doing slow stop-start driving.
At first, i thought it was great, but while the wheels are fine, combining that size with sticky rubber wasn't that smart. They're noisy as hell, the ride is hard because the AD08R's have steel flippers in the side wall and they're very low profile, and worst of all... the rolling resistance is brutal at stock power/torque, so any time you take your foot off the throttle, it lurches forward and drags itself to a halt. Taking off is even worse.
For an experiment, I changed back to the stocker wheels and tyres (removed them two hours after delivery, so they're essentially 'new') and it feels like a new car. You can feel the lack of grip, but it drives *so* much better. It feels more natural, it turns in much easier, there's less tram-tracking, there's way less noise and the ride is more comfortable without giving up much on handling... it's just the overall grip that loses out.
Maybe it works for some people with big rubber and that's fine, but it's not for me. Lesson learned.
Anyone in Brisbane Australia want to buy some Enkei Tenjins?
calmtigers (11-10-2014), Leonardo (11-10-2014)
Wheel Directory: Enkei RSF5 18x8.0 +45 ericmpena Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 85 06-18-2022 05:07 PM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 11:30 AM
Wheel Directory: Enkei RS05RR 18x8.5 +42 dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 206 03-02-2018 06:23 AM
Wheel Directory: Enkei NT03+M 18x8.0 +35 Tunz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 45 06-17-2016 12:31 AM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 09:10 AM
