Old 02-21-2014, 03:08 PM   #323
mrk1
Drives: Sterling BRZ Ltd
Its amazing how the FedEx man can turn your day around,
These are the new HKS SP coilovers, I'm told this is one of the first set in the country! Now if it wasn't winter and my car was running.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
Mr. (02-21-2014), shaunsweeney (02-21-2014)
Old 02-21-2014, 05:41 PM   #324
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
shaunsweeney is offline   Reply With Quote
Old 02-21-2014, 09:11 PM   #325
mrk1
Whats in that box labeled turbo, GTX3576R
The 3576 uses the 30 compressor housing so its no larger then the t04e I have built the kit around so with just some new coolant lines this GTX35 should drop right in. The car will be fired up on the 50 trim and used to shake out the bugs.
GTX35 compared to a td04, thats a 02 WRX stock turbo.
HKS SP's installed
The Build Thread
Old 02-21-2014, 09:49 PM   #326
AirborneDeth
Regular Guy
AirborneDeth's Avatar
Drives: '13 FRS '97 Jeep Cherokee
Awesome build.
AirborneDeth is offline   Reply With Quote
Old 02-21-2014, 10:42 PM   #327
Evil Jesus
Evil Jesus's Avatar
Drives: '13 FR-S Raven 6MT
This thread gives me wood.
Evil Jesus is offline   Reply With Quote
Old 02-21-2014, 11:23 PM   #328
shaunsweeney
Must see new coilovers in person
Old 02-22-2014, 11:36 AM   #329
mrk1
Plotting points for 7,10,18,22 psi on pump
7 is really only on there because thats the waste gate spring pressure, just like to see that its still on the map even though it will only be used as a limp home and start up as needed.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
Sportsguy83 (02-23-2014)
Old 02-23-2014, 04:42 AM   #330
shaunsweeney
That thing looks like it will make good power even at 10psi! 18psi looks really nice though.
Old 02-23-2014, 03:33 PM   #331
bama_brz
bama_brz's Avatar
Drives: '14 SWP BRZ
As someone who welded their way through college, you've got more guts than I. Momma's lessons paid off! Think I'll stick to repairing farm equipment and building fences, but absolutely LOVE what you've done.
bama_brz is offline   Reply With Quote
The Following User Says Thank You to bama_brz For This Useful Post:
mrk1 (02-23-2014)
Old 02-24-2014, 03:29 PM   #332
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Originally Posted by mrk1 View Post
vacuum manifold mounted, really having a hard time locating these where it looked ok and was accessible.
Grommet I installed in the fire wall. Not to much fun punching a hole in the car but it was needed. I will put some sealant around the grommet when Im done fishing the wires through.
Fishing wires through the fire wall has always been something I hated doing so this time I added this designated grommet.
Rather then spider the wiring for gauges and what not into the cars electrical system I am going to install an ancillary fuse box to run anything I may ad to car. Radar detector, boost controller, gauges, should make things much easier in the long run.
Love the fuse setup and mounting location for that and the vibrant block. I may have to poach the vibrant setup for my car. Here's mine so far
20130623-PasswordJDMUltimateStrutTowerBracePackage-029 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 02-25-2014, 02:55 PM   #333
mrk1
My 3rd brake light decided to die on me and while back, I forgot about it for a while but now I need a sticker. A local BRZ owner came by my shop with one of these on his car so he made me one.
The Build Thread
2point0 (02-25-2014)
Old 02-25-2014, 05:39 PM   #334
mrk1
GTX35 11 blade, so pretty
The Build Thread
midnight23 (03-03-2014), solidONE (02-25-2014)
Old 02-25-2014, 11:15 PM   #335
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I'd love to see how that gets carved out by a CNC. Must be a really fancy machine that made this.
Old 02-26-2014, 07:46 AM   #336
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
5 axis CNC
kask2_6.0 is offline   Reply With Quote
The Following User Says Thank You to kask2_6.0 For This Useful Post:
solidONE (03-02-2014)
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 07:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 11:53 AM
