Old 02-21-2014, 01:28 PM   #29
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by alexisfire02 View Post
I take it you don't trust the water/meth injection kits?
Someones got to figure out how to cool with these big blowers
Its not the heat, its also the SHIT load of trq down low
Sent from my IBrick
Old 02-21-2014, 03:46 PM   #30
SmsAlSuwaidi
Boosted
Torque good. Heat Bad.
Torque is always good, but not down low and instantly
Sent from my IBrick
Old 02-21-2014, 03:57 PM   #31
SmsAlSuwaidi
Boosted
How so? Just curious.
Isn't that the main goal of a roots style SC?
I cant get very technical about it, but ill give it a shot
Yes it is the main purpose of a twin screw sc, but this block was never built to withstand a ton of torque down low which this huge sc does. My guess ur motor either detonated or the rods just let go
Im sure somebody more educated could chime in @King Tut @james @Sportsguy83 ?
Sent from my IBrick
Old 02-21-2014, 03:58 PM   #32
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I like your idea of a bigger and thicker heat exchanger. Perhaps you could also add a Killer Chiller type setup where the coolant is also chilled by the A/C system.
Old 02-21-2014, 03:59 PM   #33
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I am 100% sure it was his tune that killed the motor. I haven't seen any definitive proof that X amount of torque at X RPM kills an FA20 motor.
Old 02-21-2014, 04:17 PM   #34
King Tut
NASA SpecE30 Racer
King Tut's Avatar
If theres no cooling, and massive amounts of heat, no tune is going to help
Super high IATs will definitely lead to detonation, but how much boost were you running? Another common issue reported on the Innovate superchargers is not being able to accurately measure the IATs post blower either so adjusting the AFR/timing for IAT is difficult.
Old 02-21-2014, 05:19 PM   #35
SmsAlSuwaidi
Boosted
We were seeing just about 20 pounds at 6,000 rpm. timing was being pulled and revs were never able to be ran any higher than that.
Remember though, the car detonated with pump gas in it. Thats a whole lotta boost for pump gas.
Wtf 20 pounds on pump with an sc
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
solus (07-14-2014)
Old 02-21-2014, 05:23 PM   #36
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Why would you possibly drive the car under those conditions? Throw a larger pulley or a wastegate on that bad boy if you plan to run 93 octane.
Old 02-21-2014, 05:33 PM   #37
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Have a wastegate solution for this supercharger?
And there is no room for a larger pulley, would have to go smaller at the crank. This pulley rubbed a hole in the padding on the underside of my hood.
Sounds like it would have to be custom. Now I am understanding why they said this was for built motors only. I didn't realize it was putting out 20 psi at 6000 RPM. Do you have any boost plots for it?
Old 02-21-2014, 07:37 PM   #38
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Pretty much, it should also be noted that Sprintex and the other companies that sell this have done 0 testing on it.
They only decided to sell the thing because they found it fits on the manifold they made.
OP, either sell it and get a turbo build or sell it and any other supercharger.
This blower will require a lot of work to get working correctly, it seems you just want simple bolt on power.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 02-21-2014, 10:08 PM   #39
s2d4
s2d4's Avatar
Tuner and owner error.
Old 02-22-2014, 02:25 AM   #40
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
I've already got a turbo car. Not interested in selling this kit.
Methanol injection + heat exchange upgrades
Well, good luck i'll be damn impressed if you do get the 335 working on the stock block. If you do i'm sure Sprintex would be interested as well as they are adamant that it is impossible to do without a forged block.
Build thread
Old 03-07-2014, 04:29 PM   #41
knapper
knapper's Avatar
Drives: '13 Scion FR-S - Whiteout
Any video and dyno sheets?
I don't mean to be rude, but it kind of sounds like you have a whole lot of money ... a very few car brains.
knapper is offline   Reply With Quote
Old 05-03-2014, 05:36 PM   #42
JerryMichaels7
Drives: Whiteout FRS
this i can't wait to see
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Are you getting Manual or Auto? denverizzles Scion FR-S / Toyota 86 GT86 General Forum 134 08-15-2013 11:55 AM
Auto to manual ric342 Scion FR-S / Toyota 86 GT86 General Forum 135 04-11-2013 12:43 AM
Auto to Manual Obja Scion FR-S / Toyota 86 GT86 General Forum 14 02-04-2013 12:45 PM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 12:33 PM
