Old 12-06-2013, 08:07 AM   #1
alexisfire02
Drives: 2013 Pearl White FRS
My car builds. One Auto, One Manual
First off, before I go too much into starting my build threads, is this the right place? It does appear that most of the car builds are here.
And if I have 2 cars, should I seperate them into 2 threads? One is a FA20Club turbo kit 10 series FRS. The other is the automatic with a bigger twin screw supercharger kit.
alexisfire02 is offline   Reply With Quote
Old 12-06-2013, 08:31 AM   #2
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
You are in the right place! As far as separate threads goes, that is up to you. If you are organized you could probably do one and keep the mods separated as far as what is on each car. You would have to be careful to not confuse those that are following your build(s).
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 12-06-2013, 12:07 PM   #3
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Which are you preferring to drive? On the TC, ya man ya better get a filter quick, I would be scared shitless driving that thing without filteration, that is unless where you live there is zero dust and bugs..
Old 12-06-2013, 12:50 PM   #4
OICU812
Just a dude
OICU812's Avatar
Originally Posted by alexisfire02 View Post
Right now I can only drive the Manual (Turbo).
Would you have (anyone) have any suggestions on where to look for a filter for the turbo?
The Auto is not running at the moment.
I would get in touch with someone like LJ at Full Blown Motorsports or Hal at Dynasty Turbo, those guys should for sure be able to get you something that would work. Just have your inlet ID's and all your clearances figured out prior to phoning and I am certain you will be off to good days ahead!
Old 12-06-2013, 01:03 PM   #5
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
This is very cool to experience an MT and AT with FI when you feel like it. Congrats to you and welcome to the forum.
TRD_07 is offline   Reply With Quote
Old 12-10-2013, 02:35 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
And I'm still trying to find an air filter for the turbo that'll fit.
Take some measurements and go here:
http://www.knfilters.com/universal/universal.htm
Old 12-10-2013, 03:38 PM   #7
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
so you were running the 335 supercharger? didnt they recommend not running that supercharger unless internals were built up?
UltraMarine86 is offline   Reply With Quote
Old 12-10-2013, 10:30 PM   #8
UltraMarine86
The larger supercharger that sprintex/innovate has. Just assumed since you said larger supercharger
Sent from my SCH-I605 using Tapatalk
Old 12-11-2013, 11:59 AM   #9
UltraMarine86
http://www.ft86club.com/forums/showthread.php?p=1300168
Old 12-12-2013, 08:08 AM   #10
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Here is the dyno chart for my manual with the FA20club turbo kit car.
Are you driving it at 20 PSI or you dialed it down after the dyno run?
Old 12-12-2013, 09:01 AM   #11
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
this !
and how are you putting this power to the ground ?
What clutch are you using ?
what injectors do you have ?
are you using a DW65 pump or what pump are you on because i thought its a limiting factor at 4xx.
Old 12-12-2013, 11:23 AM   #12
SmsAlSuwaidi
Boosted
Regarding manual/turbo car
Getting the wheels to hookup is quite a challenge at the moment.
I do have 18x8 wheels on there with drag radials on the rear. Not that that is enough....
I move the boost up and down depending on my mood. Usually its not near 20.
The fuel management was taken care of by Toni and the FA20club kit.
Also have the clutch Toni recommended.
care to expand on the "fuel management and clutch " or you're not entirely sure ?
Old 12-12-2013, 08:13 PM   #13
Lonewolf
Lonewolf's Avatar
Drives: Moped
This thread has so much potential...I will be checking this often...
Old 12-12-2013, 11:04 PM   #14
Sportsguy83
Drives: Limited BRZ
I'm looking lol.
I am using the DW65 with Injector Dynamics 850cc Fuel Injectors on the Automatic car.
On the manual car that Toni did the turbo kit, I'll have to ask him and verify, but,
I believe the fuel pump is a Walbro 400 LPH with 770cc injectors.
The clutch is the ACT SB7-HDG6
You shipped the car to South FL and they installed it here?
Are you getting Manual or Auto? denverizzles Scion FR-S / Toyota 86 GT86 General Forum 134 08-15-2013 10:55 AM
Auto to manual ric342 Scion FR-S / Toyota 86 GT86 General Forum 135 04-10-2013 11:43 PM
Auto to Manual Obja Scion FR-S / Toyota 86 GT86 General Forum 14 02-04-2013 11:45 AM
SWP and WRB Limited/Manual, WRB Premium/Manual + SS Prem Auto available in Colorado huma BRZ First-Gen (2012+) — General Topics 15 06-14-2012 11:33 AM
