#43 |
Drives: SC RB FRS
another way to calculate it is to use the offset calculator
stock size: 7 width and +48 offset http://www.1010tires.com/Tools/Wheel-Offset-Calculator my current setup +94 in the front +117 in the rear -2 camber all around. it sits flush, it doesn't poke, its a functional setup. i track it often. up to +80 front and +100 rear would make a nice setup. anything pass +95f +120r is gonna poke and youre gonna get that hellaflush look or run massive amounts of negative camber. |
#44 |
Drives: 2013 Scion fr-s - pearl white
rocket bunny wheel specs
Hey did you guys use spacers at all? And did you have any issues with full wheel lock on the front wheels>
#45 |
Drives: 2013 Rocketbunny GT86
BTW, I love this car!
My rears came out to -35 EO and My fronts are -5 E0 I might change up te front, as of right now i am waiting on tires to show up to check the clearance. |
#46 |
#47 |
I'm surprised nobody is running super wide wheels with these kits. I'm on a 9/10 setup under stock fenders, and based off the added width of the kit you could easily go another 3" wider. I'd love to see someone do one of these with an 11" front and 12" or larger rear and some 3xx width tires... now THAT would be wild. :P
#48 |
Drives: 13 CSB BRZ Ltd
What's the point? I'm running 265/35/18 all the way around on stock fenders. If you have a RB kit, why wouldn't you go for 315 or 325 out in the rear?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread |
#49 |
Drives: '14 SWP BRZ Limited
Wider track should provide more grip in theory. Unless you're putting down a ton of power I really don't think you'd ever be able to take advantage of it.
#50 |
Are you 20/20?
Drives: Hopes and dreams
Quick thinking, here:
If you're not putting down a massive amount of power, you probably don't want a heavy tire putting more rotational mass in the name of grip.
#51 |
Drives: LexusGS,Lotus Exige S240,LexusLX570
Has anyone have an idea about using a 265/35 tire on 18x10.5 wheels, iv been told that there might be an issue with rubbing.
#52 | |
Drives: Rocket Bunny FR-S
Im running 18x10.5 rear with 275/35 right now
#53 |
Im going 18x10.5 all around and im not to into the stretched tire look, so i was wondering if 265/35 would be an issue in the front.
#54 |
Drives: Asphalt FRS
Thinkin about going with a set of 18x11 +20 square. Would these fit the rocketbunny fenders? or would I have turning radius problems up front?
#55 |
Drives: Asphalt FRS <3
So if I want to run 17s or 18s I should go 18x9.5 +0 or -10 & 18x10.5 -30 to fit? I don't want to be slammed but no wheel gap.. What are some cheap wheels that will fit. BBS style
#56 |
Are you 20/20?
Look at those specs. Nothing will be "cheap".
If you want to spend less money, used wheels would be your best bet. Edit: I've seen your build. Why would you want to put cheap wheels on that nice car?
| Replica rocket bunny | crildz | Cosmetic Modification (Interior/Exterior/Lighting) | 103 | 05-09-2014 04:35 PM |
| Rocket Bunny FRS in Dubai | TAP Auto Parts | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 49 | 12-04-2012 01:39 PM |
| Red Rocket Bunny FR-S - Speedhunters | RaceR | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-12-2012 12:48 AM |
| Rocket Bunny or Modelista? HELP!!! | ShowstoppersUSA | Cosmetic Modification (Interior/Exterior/Lighting) | 21 | 08-16-2012 01:23 PM |
| GReddy/Rocket Bunny Wheels? | Coultergeist | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-15-2012 02:39 AM |
