Old 02-13-2014, 12:37 AM   #43
pitstops
Drives: SC RB FRS
another way to calculate it is to use the offset calculator
stock size: 7 width and +48 offset
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
my current setup
+94 in the front
+117 in the rear
-2 camber all around. it sits flush, it doesn't poke, its a functional setup. i track it often.
up to +80 front and +100 rear would make a nice setup.
anything pass +95f +120r is gonna poke and youre gonna get that hellaflush look or run massive amounts of negative camber.
pitstops is offline   Reply With Quote
Old 02-14-2014, 09:09 PM   #44
rookczc
rookczc's Avatar
Drives: 2013 Scion fr-s - pearl white
rocket bunny wheel specs
Hey did you guys use spacers at all? And did you have any issues with full wheel lock on the front wheels>
Originally Posted by Speed Element View Post
BBK fitment will depend on the face of the wheel. You can pm us if you have any other questions.
here is the specs of our wheels:
Work Meister S1R 2 Piece in White
Front: 18×9.5 -15
Rear: 18×10.5 -40
Hankook V12 tires:
Front: 235-40-18
Rear: 265-30-18
rookczc is offline   Reply With Quote
Old 02-15-2014, 10:49 AM   #45
Maverick22
Maverick22's Avatar
Drives: 2013 Rocketbunny GT86
BTW, I love this car!
My rears came out to -35 EO
and My fronts are -5 E0
I might change up te front, as of right now i am waiting on tires to show up to check the clearance.
Maverick22 is offline   Reply With Quote
Old 02-17-2014, 02:29 PM   #46
Speed Element
Speed Element's Avatar
Drives: FR-S, Evo X, IS-F, 335i, STi, LS460
Send a message via AIM to Speed Element
15mm spacer up front. no issue with full lock
-Ryan
Speed Element is offline   Reply With Quote
Old 02-18-2014, 06:59 PM   #47
dmarkey
I'm surprised nobody is running super wide wheels with these kits. I'm on a 9/10 setup under stock fenders, and based off the added width of the kit you could easily go another 3" wider. I'd love to see someone do one of these with an 11" front and 12" or larger rear and some 3xx width tires... now THAT would be wild. :P
dmarkey is offline   Reply With Quote
The Following User Says Thank You to dmarkey For This Useful Post:
hmong337 (08-31-2014)
Old 02-20-2014, 06:28 PM   #48
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Front: 18×9.5 -15
Rear: 18×10.5 -40
Hankook V12 tires:
Front: 235-40-18
Rear: 265-30-18
What's the point? I'm running 265/35/18 all the way around on stock fenders. If you have a RB kit, why wouldn't you go for 315 or 325 out in the rear?
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
The Following User Says Thank You to Acree For This Useful Post:
Old 02-21-2014, 03:49 PM   #49
Ouhei
Ouhei's Avatar
Drives: '14 SWP BRZ Limited
Wider track should provide more grip in theory. Unless you're putting down a ton of power I really don't think you'd ever be able to take advantage of it.
Ouhei is offline   Reply With Quote
Old 02-22-2014, 02:06 AM   #50
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Quick thinking, here:
If you're not putting down a massive amount of power, you probably don't want a heavy tire putting more rotational mass in the name of grip.
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 02-25-2014, 07:00 AM   #51
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
Has anyone have an idea about using a 265/35 tire on 18x10.5 wheels, iv been told that there might be an issue with rubbing.
mnsayer is offline   Reply With Quote
Old 02-25-2014, 05:10 PM   #52
deedz
Drives: Rocket Bunny FR-S
in the rear? Rear there is a part of the over fender that tends to rub but i trimmed it down a bit and its not really a problem anymore.
Im running 18x10.5 rear with 275/35 right now
Rocket Bunny Vinyl Wrapped Build Page:
http://www.ft86club.com/forums/showthread.php?t=33573
deedz is offline   Reply With Quote
Old 02-26-2014, 03:15 AM   #53
mnsayer
mnsayer's Avatar
Im going 18x10.5 all around and im not to into the stretched tire look, so i was wondering if 265/35 would be an issue in the front.
Old 03-23-2014, 06:27 PM   #54
CodyFRS
CodyFRS's Avatar
Drives: Asphalt FRS
Thinkin about going with a set of 18x11 +20 square. Would these fit the rocketbunny fenders? or would I have turning radius problems up front?
CodyFRS is offline   Reply With Quote
Old 04-10-2014, 02:24 AM   #55
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
So if I want to run 17s or 18s I should go 18x9.5 +0 or -10 & 18x10.5 -30 to fit? I don't want to be slammed but no wheel gap.. What are some cheap wheels that will fit. BBS style
Scalzo is offline   Reply With Quote
Old 04-10-2014, 02:30 AM   #56
AznKirby
Are you 20/20?
AznKirby's Avatar
Look at those specs. Nothing will be "cheap".
If you want to spend less money, used wheels would be your best bet.
Edit: I've seen your build. Why would you want to put cheap wheels on that nice car?
2014 FR-S Monogram
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
Jason@DSG (06-03-2014)
Replica rocket bunny crildz Cosmetic Modification (Interior/Exterior/Lighting) 103 05-09-2014 05:35 PM
Rocket Bunny FRS in Dubai TAP Auto Parts FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 49 12-04-2012 02:39 PM
Red Rocket Bunny FR-S - Speedhunters RaceR FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 10-12-2012 01:48 AM
Rocket Bunny or Modelista? HELP!!! ShowstoppersUSA Cosmetic Modification (Interior/Exterior/Lighting) 21 08-16-2012 02:23 PM
GReddy/Rocket Bunny Wheels? Coultergeist Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-15-2012 03:39 AM
