#225 |
blowhard
Drives: frs, project forester
Been heavily considering this solution the last number of months, combined with a better radiator in new england it should be more than adequate. I recently installed the kw kit and have been hoping no items would clash.
Looking at pics found one conflict. Looks like the hard pipe running down front of engine shares mounting holes with the lower kw bracket.
| The Following User Says Thank You to utekineir For This Useful Post: | normancw (02-15-2014) |
#226 |
Drives: vrooom...
I can't see what is on the other side of the bracket but if there is nothing in the way there, you can still run this set up. You don't have to run the hard line pipe, you can just run a rubber coolant hose all the way down.
#227 | |
blowhard
just atleast one change that would have to be corrected for. and it would have to be secured considering the potential for being destroyed if it flapped around ![]() kinda wondering if it would be better just to bend the tabs and mount onto the side of the bracket. Last edited by utekineir; 02-15-2014 at 07:35 AM. |
#228 |
Drives: 2005 Toyota Camry
![]() I'm doing this slightly different. The M14x1.5 > -8AN fitting off the block drain plug goes straight into a -8AN heater hose setup. My friend's shop suggested this since this is a popular way for aftermarket turbo coolant hoses to be run. The hoses are Goodyear, rated for 300PSI. More flexible than normal steel-braided hoses too. The heater hose pipe I have is PN 14050AB090, different than what everyone else is using. But apparently it's the same part. Unfortunately I won't have time to install this today, but will have a post-install writeup/pictures to share. -alex |
#229 |
CHECK ENGINE
Drives: 2004 STi
14050AB090 is the same as 14050AA970
In production of the 2014 FXT they used AA970 from 10/12 to 07/13 then switched to AB090 for 07/13 - current production. Not sure why the new part number because they seem like the same piece, and have an identical price.
i don't cry about crickets
| The Following User Says Thank You to CARNZ For This Useful Post: | mav1178 (02-15-2014) |
#230 | |
Drives: '13 FR-S Argento
M14x1.5 to -8AN adapter 45 degree -8AN to -8AN hose end fitting (-8AN is used to describe the compression fitting as well as the hose diameter, -8AN hose is close enough to 1/2" ID hose) 1/2" heater hose I ended up ordering the adapter and the hose end fitting from summitracing.com FRA-460814-BL RUS-624093 1/2" heater hose can be sourced from local auto parts stores. I have a radium catch can kit and I'm hoping there will be enough excess 1/2" hose from that kit to be used for this as well. |
| The Following User Says Thank You to DM7 For This Useful Post: | normancw (02-17-2014) |
#231 |
Drives: 2013 SWP BRZ
The water pump on the intercooled kit for the Innovate supercharger also shares the same mounting spot as the front pipe on the motor. No issues though with that (have this installed).
| The Following User Says Thank You to xxscaxx For This Useful Post: | normancw (02-17-2014) |
#232 | |
Boosted Noob
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
If it shares the same spot how difficult did it make the install? I just bought the pieces for this OEM Forester Oil Cooler and want to eventually get the Innovate/Sprinter IC or JR/KW S/C kits but not sure about interference. Did you also upgrade your radiator? |
#233 | |
Radiator is stock. |
#234 |
Boosted Noob
Put in the order on Subaru Online Parts on Friday evening. Got this email from them this morning: "THANK YOU FOR YOUR ORDER BUT 14050AA970 PIPE COMPLETE WATER is temporarily unavailable and may not be available for 4-6 weeks."
#235 |
Keep in mind that pipe is not 100% necessary. If you don't mind Teeing into the stock line, you can set it up like I did and just run a tee into the line instead of replacing that pipe. I did this because it was backordered as well.
| The Following User Says Thank You to xxscaxx For This Useful Post: | mit_peid (02-17-2014) |
#236 | |
Boosted Noob
I think I will go down this path as well and save ~$55 in the process. Thanks! |
| The Following User Says Thank You to mit_peid For This Useful Post: | xxscaxx (02-17-2014) |
#237 | |
I also tried to not drain the coolant out which made quite a mess, so if you don't mind filling up the system again i'd just empty the coolant out lol. Or, make sure to pinch both sides of that line you splice into. Just hard because of the limited room. |
#238 | |
Boosted Noob
805918010(Qty:3) - HOSE, CLAMP 092315002(Qty:2) - HOSE, CLAMP |
| Tags |
| brz, fxt, oil, oil cooler |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| Bought a 2014 Subaru Forester | EAGLE5 | Other Vehicles & General Automotive Discussions | 10 | 10-02-2013 12:54 PM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| BRZ 2.0L Turbo in 2014 Forester | Sleeperz | BRZ First-Gen (2012+) — General Topics | 37 | 03-21-2013 06:42 PM |
| Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… | 2013GTRNate | BRZ First-Gen (2012+) — General Topics | 12 | 02-01-2013 12:29 PM |
