Old 02-11-2014, 10:23 PM   #1177
steve99
Drives: FT86
Originally Posted by shiv@vishnu View Post
Hi Shiv,
Was just reading about an ECUTeck failed flash.
If a flash failed using OFT ie car battery low or for some reason you unplugged cable or something silly causing flash to fail.
could you just write over failed/partial flash it or is it likely to cause more dramatic issue ?? assuming you were using OFT trying to write over a non locked tune ie an OFT/rom Raider/Tactrix/ecuflash created tune.
Old 02-11-2014, 10:29 PM   #1178
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi Shiv,
All you would have to do in such a situation is restore OFT connection (or recharge battery) and write to the ECU again. Nothing dramatic since there is software license involved with OFT.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
steve99 (02-11-2014)
Old 02-11-2014, 10:36 PM   #1179
steve99
Drives: FT86
So their is no chance of trashing boot loaders or anything, your only writing to the flash ram section of the ECU.
Old 02-11-2014, 10:40 PM   #1180
Shiv@Openflash
Drives: 2013 FRS
You can theoretically brick your ECU by writing a corrupt file (i.e., by editing areas of the ROM that contacts boot data, not mapping data.) It takes work to do that however.
Old 02-11-2014, 10:50 PM   #1181
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Being .bin files you would be surprised. My computer opens them natively in notepad and I could really mess things up if I screwed around. You would be surprised how long it takes to open one file though that way.
Luckrider is offline   Reply With Quote
Old 02-11-2014, 10:54 PM   #1182
steve99
Drives: FT86
sounds like it would be worth removing the file association ".bin" from notepad
Cross (02-16-2014)
Old 02-11-2014, 11:21 PM   #1183
Nardi330
Nardi330's Avatar
Drives: 86
You are probably best off with a stage 1 tune since you haven't opened the exhaust enough to gain the benefits of the no cat tune, but you should still make a tad bit more power than those with factory headers.
Thanks.
Originally Posted by tonystewart View Post
I running Stage 2 EL header with HTC, front pipe is catted as well
good to know someone tried it with good experience. Thanks.
Either the Stage 1 or Stage 2 tune will work well with a catted aftermarket header. You'd just have try both and see which one you prefer. It's hard to know which one is definitely better matched without visiting a dyno unfortunately. But both will work much better than the stock tune
Thanks. I will try both and data log.
Originally Posted by Burn View Post
Just do a WOT logging on both ROMs and see which AFR on WOT is closer to 12
Thanks.
Nardi330 is offline   Reply With Quote
Old 02-16-2014, 07:21 PM   #1184
Mixlplix
Shiv,
I think u have a great product and plan on buying one soon. Just wanted to know if you offer a map for 93 octane. I've read u dont have a map 93 octane , but that doesnt seem to make sense to me. Can u help me out here?
Mixlplix is offline   Reply With Quote
Old 02-16-2014, 07:42 PM   #1185
stevo585
Drives: White 2014 BRZ
Same here as most of the country is has 93 available. At the least maybe a suggestion on a few things that could be tweaked?
stevo585 is offline   Reply With Quote
Old 02-16-2014, 09:13 PM   #1186
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Cali has the worst gas in the lower 48...acn(Arizona California Nevada)
As far as I know you could add in a little more timing but from what I've read it won't make a huge difference without a good tuner and a dyno to notice where you can add. (could be wrong)
Any chance of releasing a version two EL header tune for JDL and nameless? I don't mind paying for the e-tune but I can't really get cam settings dailed in that way.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 02-16-2014, 11:12 PM   #1187
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Any "tuning" done without a dynamometer is a shot in the dark. All we can do right now is tune for anti-knock and AFR with the logging capabilities we currently have.
On a side note, I've noticed some buggyness with the latest OFT update. With the OFT plugged in at start up I've gotten warning lights in the dash come on several times. Namely the ABS the traction control and today the airbag light. It goes away upon shutting off the car then restarting. This never happened before the update. Anyone else get this?
Old 02-17-2014, 12:08 AM   #1188
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Mixlplix View Post
Shiv,
All our gasoline (non-E85) maps are intended for 91-93oct. 91oct users may see their Advance Multiplier float a bit from time to time. But 93-94oct users will see it stay put. 93-94oct guys really have it lucky. Then again us 91oct folks get to enjoy sunny CA while the rest of you get snow
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
omegared19 (02-21-2014), Shinobi (02-21-2014)
Old 02-17-2014, 12:10 AM   #1189
Shiv@Openflash
Drives: 2013 FRS
With the OFT plugged in, all it is doing is drawing a tiny bit of power from the 12v supply in the OBD2 socket. It doesn't even do any active communications unless you request by going to datalogging or writing or getting info. So I don't see how plugging it in can cause any of the dash lights you are reporting. This has not been my experience at all and is the first time I'm even hearing about it.
Old 02-17-2014, 12:59 AM   #1190
solidONE
solidONE's Avatar
I will take a photo or video next time I get this again.
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
