Old 02-05-2014, 09:43 PM   #15
86_Otaku
86_Otaku's Avatar
Drives: 2013 BRZ Limited-SWP
I see a trip to the local Home Depot also. It should cost me about $2
86_Otaku is offline   Reply With Quote
Old 02-05-2014, 11:46 PM   #16
JB86'd
JB86'd's Avatar
Drives: JAWS
@enjoyminutemaid Did you use any spacers or just the rubber stop itself? I've never trained myself to not press the clutch pedal all the way to the floor, so I think this could be a great mod for me. I did however adjust my clutch pedal height, still above the height of the brake pedal.
JB86'd is offline   Reply With Quote
Old 02-15-2014, 06:40 PM   #17
sanmarcosfrs
sanmarcosfrs's Avatar
Drives: 2013 asphalt frs
Just bought mine! How many of the spacers did you use?
Originally Posted by enjoyminutemaid View Post
All hail the WORKS KICK CLUTCH PEDAL STOP!
I just bought this and installed it (it's a PIA if you have big fingers, but still less than 10 min). If you are the kind of manual driver who typically pushes the clutch all the way to the floor every time you shift - as opposed to only pushing it as far as necessary - then get this and install it. I am in love with the difference it makes. I know it seems silly in theory, and it's a lot of money for what it is, but I really like mindlessly pushing the clutch to the floor and getting quick, consistent engagement.
sanmarcosfrs is offline   Reply With Quote
The Following User Says Thank You to sanmarcosfrs For This Useful Post:
JB86'd (03-10-2014)
Old 02-15-2014, 10:10 PM   #18
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
I didn't use any of the spacers. Don't think it would be a good idea with oem clutch.
enjoyminutemaid is offline   Reply With Quote
The Following User Says Thank You to enjoyminutemaid For This Useful Post:
sanmarcosfrs (02-15-2014)
Old 03-02-2014, 09:35 PM   #19
tomaszjanczak
Drives: Silver Subaru BRZ
@enjoyminutemaid Could you post the instructions that came with the works kick clutch pedal stop? Or could someone else post a DIY. The only site that sells the kit comes out to over $40 shipped, pretty crazy. I went to Home Depot and tried to do it myself but the parts I got aren't ideal and I was killing myself trying to install it, and it didn't work. Any help?
tomaszjanczak is offline   Reply With Quote
Old 03-02-2014, 11:21 PM   #20
sanmarcosfrs
I bought mine from 86 industries.... Pretty sure I got ripped off. Haven't heard anything in two weeks
Old 03-03-2014, 06:13 AM   #21
FR-S Matt
He got banned from the forums for shady business practices and false promises. You probably did.
Old 03-03-2014, 07:41 PM   #22
enjoyminutemaid
Damn, I guess I got in before the lock on that guy. Even at $40 it would still be worth it to me, regardless of its home depot origins. Maybe contact Works directly?
Old 03-03-2014, 07:52 PM   #23
tomaszjanczak
That is what I did. I ordered from them today. $35 shipped.
Old 03-03-2014, 08:12 PM   #24
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Home depot and Lowe's don't have the exact rubber stopper, but a quick browse on McMaster-Carr would get you what you need.
JDKane527 is offline   Reply With Quote
Old 03-03-2014, 09:36 PM   #25
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
got any pics or diy to how to post this up?
subiestyle is offline   Reply With Quote
Old 03-04-2014, 07:05 PM   #26
tomaszjanczak
I'll try to post something up once I get mine.
Old 03-04-2014, 08:32 PM   #27
enjoyminutemaid
There really isn't much to it as it's basically just a bolt with that goes through a hole and you put a nut on the back end to secure it, but you will find things much easier if you can figure out a way to pin the clutch to the floor but still have two free hands.
Old 03-04-2014, 10:54 PM   #28
subiestyle
subiestyle's Avatar
which hole does it go through?
whining/whirring noise during high load/rpm clutch engagement 7thgear Issues | Warranty | Recalls / TSB 105 06-19-2017 11:04 AM
clutch Engagement Issue? Bu-Tang Issues | Warranty | Recalls / TSB 68 02-19-2017 02:03 PM
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
DI seal improved material radroach Engine, Exhaust, Transmission 21 01-16-2014 12:42 AM
Clutch Pedal Engagement Adjustment denverizzles Scion FR-S / Toyota 86 GT86 General Forum 1 07-25-2012 05:01 PM
