Old 02-15-2014, 01:28 AM   #57
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Use a stylus if you're not going to use the dock.
I'm on my phone so if I make mistakes, blame Sportsguy83
^GT5 Replay Photo Mode^
Old 02-15-2014, 10:47 AM   #58
DJCarbine
Thupercharged
DJCarbine's Avatar
11:38
Blame Valentine's day
Flash (0-100%) takes 1:30
Basically each percent is slightly less than one second of real time
Complete (pressing flash, flashing, all the DTC checking/resetting and ignition key shenanigans) around 2:00
Not sure how people are timing, just the flash or the entire process
OTG adapter
[ame="http://www.amazon.com/gp/product/B00932N46S/ref=ox_ya_os_product_refresh_C"]Amazon.com: IVSO® Nexus 7 Tablet Micro USB Host OTG Cable - Micro USB B/Male to USB2.0 A/Female OTG Host Cable for Nexus 7 (Black): Computers & Accessories[/ame]
2 port USB hub
[ame="http://www.amazon.com/gp/product/B005HKIDF2/ref=ox_ya_os_product_refresh_C"]Amazon.com : Plugable USB 2.0 2 Port Hub : Network Hubs : Computers & Accessories[/ame]
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
Sportsguy83 (02-15-2014)
Old 02-15-2014, 10:49 AM   #59
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
OTG adapter
2 port USB hub
When your GF is the one on the avatar, i have no problem waiting for you my friend!!
Thanks a LOT!! I bought it
Old 02-15-2014, 12:06 PM   #60
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
FWIW, the OFT takes about 3-5 minutes to flash. And it's likely an ARM processor with a tiny bit of ram.
So wtf speeds writing roms up to 1-2 minutes?
86-tundra is offline   Reply With Quote
Old 02-15-2014, 12:51 PM   #61
jamesm
It has to be the usb chipset drivers. Nothing else makes sense given the info we have.
The Following 3 Users Say Thank You to jamesm For This Useful Post:
86-tundra (02-15-2014), Sportsguy83 (02-15-2014), wparsons (02-24-2014)
Old 02-15-2014, 02:39 PM   #62
DJCarbine
Thupercharged
DJCarbine's Avatar
I'm going to take my ecutek cable apart today and see if there is a serial/usb chip
Its a boring day lol
2013 FRS
Vortech V3 11psi
Old 02-15-2014, 03:36 PM   #63
DJCarbine
Thupercharged
DJCarbine's Avatar
As suspected an FTDI IC was in the cable, so its definitely some sort of USB to Serial conversion I believe
Found specs on the IC
Transfer Data rate to 1M Byte / Sec - D2XX Drivers
• Transfer Data rate to 300 Kilobyte / Sec - VCP
Drivers
Seems like you get a slower transfer rate with virtual com port (VCP), and higher with a more direct method with their own D2XX drivers
Not sure which ecutek uses, or if virtualization/hardware factors determine which drivers are used
Also not sure if this helps lol
2013 FRS
Vortech V3 11psi
Sportsguy83 (02-17-2014)
Old 02-15-2014, 03:37 PM   #64
DJCarbine
Thupercharged
DJCarbine's Avatar
Another thing, I'm fairly confident that if the USB cable ever DID get damaged, it would be very easy to replace it with a soldering iron. The USB cable is actually fitted with a 4 pin connector that plugs into the control board in the green plastic casing of the ecutek cable. It would be trivial to cut the connector off the bad cable and solder it onto a doner USB cable.
2013 FRS
Vortech V3 11psi
Old 02-15-2014, 03:38 PM   #65
jamesm
it definitely seems as though logging speed is improved with the t100 over parallels, though it doesn't scale linearly with the flashing speed. flashing is ~3x faster, where logging speed seems to be increased by about 30-40% (it's hard to tell, really given all the variables involved).
The Following User Says Thank You to jamesm For This Useful Post:
Old 02-16-2014, 12:18 PM   #66
stugray
Drives: 2013 GBS BRZ Limited
On devices that use the micro USB cables, the cables usually contain a FTDI chip.
These chips convert USB interfaces to RS232 protocol signals and often perform voltage level shifting to/from 3.3V/5.0V.
On these devices that require the USB to FTDI converter chip the transfer speeds will be much slower than USB is capable of.
The FTDI chips at typically limited to 1-3 MBPS.
So switching from USB 2.0 to USB 3.0 should make no difference.
If you do see a difference, it probably means that there was some sort of USB driver issue before switching from 2.0 to 3.0.
Old 02-16-2014, 12:52 PM   #67
SirBrass
SirBrass's Avatar
My 90 second flashing time is over the micro USB port though. So, it doesn't seem throttled by that port.
The Following User Says Thank You to SirBrass For This Useful Post:
Old 02-16-2014, 06:08 PM   #68
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Even on USB 1.1 the file could be transferred in ~8 seconds.
- AdrianG
AdrianG is offline   Reply With Quote
Old 02-16-2014, 06:34 PM   #69
Bigmaxy
Drives: Pegasus GTS86
@Sportsguy83 Probably a bit late since you have replaced your mac but did you get the latest bootcamp drivers from Apple?
I know I've had a world of pain getting my Macbook Air (2011) running Windows 8.1 via Bootcamp to work at all. Had to run the ProECU app before plugging the cable in or it would crash. Quite often I would get an error enumerating vehicle. This is not confidence inspiring when flashing.
I've just rebuilt it with a fresh install of Windows 8.1 and Bootcamp drivers last night so hoping it fixes any driver issues. Otherwise I'll be joining some of you and purchasing a new device. (I like the look of the Sony Vaio duo and flips)
Bigmaxy is offline   Reply With Quote
Old 02-17-2014, 09:56 AM   #70
Sportsguy83
Drives: Limited BRZ
I did not try to get the latest drivers. I set up bootcamp like two months ago and got whatever drivers where the latest at that moment.
Excelerate Performance: Now Selling EcuTek and Flashing Visconti Tunes!!! ExcelerateRep Engine, Exhaust, Bolt-Ons 13 06-11-2014 10:52 AM
Laptop for tuning needs mrk1 Software Tuning 105 04-01-2014 04:38 PM
SOLD: Toshiba C855D Laptop swift996 Miscellaneous 0 01-10-2014 06:06 PM
Robispec * FTD and new Fastest Triplet time at Auto Center Speedway robispec Tracking / Autocross / HPDE / Drifting 16 02-25-2013 10:13 PM
ALIENWARE LAPTOP brichard0625 Off-Topic Lounge [WARNING: NO POLITICS] 68 11-06-2012 01:01 PM
