| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2013 Subaru BRZ & 99' Ford Explorer
max tire size (height)
hey guys. i want to get some more ground clearance for my brz. right now i have 245/45/17 tires. i want a bigger side wall (taller tire)....
whats the largest tire (height not width) i can fit on a brz with a stock suspension? |
#2 |
You know you're screwing up your speedometer and odometer readings by upsizing your tires?
#3 |
Drives: '13 FR-S
Not that I recommend it, but I had 245/50R17 snow tires on for a week. They're about 26.3", more than an inch and a half taller than stock. Fit fine, no rubbing with stock suspension. Gearing sucked, turn in in sucked, speedo was wrong. I wouldn't pay to put tires that size on my FR-S, and probably wouldn't do it again even with freebies.
If you want more sidewall, why not go to a 16"? |
#4 |
#5 |
yes if it was just slap them on and go. but i had my ecu adjusted for a bigger tire. so it reads correctly for 245/45/17 (stock is much smaller). with a bigger tire i will only be off by a hair.
#6 | |
Do you think an even taller tire would fit? or was yours super close? |
#7 |
#8 | |
most of all the gearing. if your car is putting out the stock 200hp or ~150whp i wouldnt recommend a tall tire like this either. but im not stock. full bolt-on's and ecutek tune. also light weight rims. so my car is quick enough that the stretched out gears are actually a bonus for me. i stay with my boys sti while running 245/45 tires. |
#9 |
#10 |
the speedo wasnt that far off anyway before the tune.
unless your doing 100mph which in that case does it really matter how fast your going? my speedo only went up to 120mph on my explorer and the stock ecu wouldnt let you go past 110mph. although it would go faster than that even when it was stock. but i had lots of goodies in that exploder and ive had the speedometer pegged as far as it could go. idk what top speed ive hit in that truck but does it really matter? |
#11 | |
Reverse Burnouts
Drives: 2013 Argento FRS
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#12 | |
#13 |
so im getting new winter tires tommorow. im getting the largest diameter tire possible w/ a small contact patch. it should be better than the shitty primacys and should give me some height/ground clearance. ill post pics soon when there on the brz.
#14 |
is there any cheap way to lift the car besides a bigger diameter tire?
| Tire size help | sharris721 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 06-19-2014 12:03 AM |
| Appropriate tire size for 250-350 whp | Tiz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 07-12-2013 02:40 PM |
| 225/35/18 Tire Size? | stoneman155 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-29-2013 08:09 PM |
| Tire Size help! | J-Money | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 02-04-2013 12:04 PM |
| Wheel gap - from suspension height or tire diameter? | CaptainSlow | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 01-27-2013 12:48 PM |
