Old 01-24-2013, 03:58 PM   #1
CaptainSlow
CaptainSlow's Avatar
Wheel gap - from suspension height or tire diameter?
Only real thing I don't like so much about the FRS is the wheel gap. Honestly, though, the car looks pretty low as it is, but I don't know if that's just an optical illusion or what. To me, it looks like the stock tires are really low-profile...lower than they probably should be.
So my question, I guess, is can the wheel gap be solved with just some taller tires, even on the stock wheels? If so, does anyone have an example picture, and possibly the tire size used? Or is this a "problem" that can only be solved with a wider wheel and/or suspension upgrades?
Not my car, obviously
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 01-24-2013, 04:10 PM   #2
madcap
Drives: 2013 Hot Lava FR-S
I thought the stock wheels with stock suspension looked awful. I changed to a larger & wider rim and thinner tire, and the combo is just barely larger than stock diameter.
Here it is and I don't mind the gap now, I actually like it.
madcap is offline   Reply With Quote
Old 01-24-2013, 04:15 PM   #3
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
My car is lowered 1" w/ stock tires. There's still some gap, but not nearly as bad as before. I'm thinking I'll just get 225/45/17 tires because they're .5" taller and it'll look perfect.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 01-26-2013, 06:45 PM   #4
86•BRZ
86•BRZ's Avatar
Drives: 86 GTS
but then your car will be slower
86•BRZ is offline   Reply With Quote
The Following User Says Thank You to 86•BRZ For This Useful Post:
dori. (01-27-2013)
Old 01-27-2013, 05:56 AM   #5
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
if you are keeping the stock wheels then getting lowering springs is the way to go
getting a taller tire is gonna make it look silly and throw your speedo off a bit
dori. is offline   Reply With Quote
Old 01-27-2013, 07:43 AM   #6
Stance86
Drives: Toyota 86 GTS
It's a ride height problem. Bigger tyres on the stock wheels will of course close the gap a little (won't make a huge difference)... but it will signifigantly increase ride height.. so you will still have a wheel gap and the car will be riding higher...
Try lowering springs.
Stance86 is offline   Reply With Quote
Old 01-27-2013, 12:48 PM   #7
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
My gap is a little better with the 235/45/17s I have on there now, but I only used them because I had them sitting around. Switching to 225/45 soon, so just a tad taller than stock, but close enough. Although the stock speedo isn't going to be all that accurate anyway, it's better to handle gap with suspension.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
WTB: 1 OEM wheel with or without tire #87 Wheels and Tires 11 01-31-2013 01:21 AM
tire/wheel setup? kosoku Tracking / Autocross / HPDE / Drifting 0 11-25-2012 09:53 PM
wheel/tire sites... rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-20-2012 06:46 AM
wheel/tire purchase help sitandspin Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-18-2012 12:08 AM
