Old 02-13-2014, 01:47 AM   #1
MaXimus
Meh!
MaXimus's Avatar
Drives: Satin White, 86, Manual
2,000-3,500k bogging power brapp noise.
Hey Guys,
Having an issue with my 86 and was hoping someone could chime in on what the issue could be. I first had the issue yesterday where I was in 3rd gear around 2.5k rpm and accelerated part throttle and the car felt like its bogging power wise also sounds weird. Best way to describe is brapp brapp brapp up to 3-3.5k rpm.
The only way I can replicate the issue is either from 1st or 2nd gear setting off as slow as possible and then WOT. Starts around 2.2k rpm and goes through to 3.5k rpm and feels like its bogging not just the usual torque dip.
I took a couple of videos which you find below but its hard to hear it on video. Mod’s wise just a track pipe and other than that stock.
Would really appreciate any feedback, I searched my A** off and could find anyone else with the same sound/issue.
[ame="http://www.youtube.com/watch?v=zGUREmX6iwo"]Bhrapp noise between 2.5 to 3krpm - YouTube[/ame]
Best I could get so far, will get the office professional mic.
[ame="http://www.youtube.com/watch?v=yk39XHs3GAk"]Engine noise - YouTube[/ame]
Best capture at 2:18
Cheers,
Sam
MaXimus is offline   Reply With Quote
Old 02-13-2014, 02:19 AM   #2
Texaz Boy
Drives: 2016 FR-S (RS-2 #734/1000) MT
Idk can't really hear what your talking about. How many miles you have on it?
Texaz Boy is offline   Reply With Quote
Old 02-13-2014, 03:17 AM   #3
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Just had a drive in the car and my best guess would be injector failure.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 02-13-2014, 06:04 AM   #4
MaXimus
Meh!
MaXimus's Avatar
Video shows 43,*** KM 0.o?
Old 02-13-2014, 11:09 AM   #5
Well, I can't hear or see anything that indicates bogging .....
Have you changed type (brand) of gas lately ... ??
Old 02-13-2014, 11:41 AM   #6
MaXimus
Meh!
MaXimus's Avatar
Filled up the morning it happened. Super 95 fuel.
RAYS TE37V 17X9 / MICHELIN 245/40/R17 / KW V3 / RACESENG TOP HATS / MOTUL 5.1 + BRAIDED LINES / FERODO DS2500 BRAKE PADS / NEXUS 7 IN DASH / VDS UEL HEADERS / CRAWFORD POWER BLOCKS/ K&N DROP IN FILTER / Custom 3 inch header back catless exhaust / Varex 3in Muffler / HT AUTO LIP KIT / VALENTI TAIL LIGHTS / MORIMOTO PROJECTOR + HID.
Old 02-13-2014, 11:47 AM   #7
lickitysplit
Don't care
Drives: 2013 Whiteout FRS
Very possible its bad gas, espeically in a car with 12.5:1 compression. See what happens with your next fill up, and use a different station. As a side note I don't hear anything strange, but its hard to tell in a video
lickitysplit is offline   Reply With Quote
Old 02-13-2014, 11:57 AM   #8
Yep, I agree ..... could be some funky gas. At least try a different pump, if your choise of stations is limited.
Old 02-14-2014, 03:33 PM   #9
FRiSson
Drives: FR-S MT
Try a can of quality dry gas (ethyl alcohol). It might not solve the bogging issue, but it is a very cheap way to find out if it may be bad gas.
FRiSson is offline   Reply With Quote
Old 02-16-2014, 01:46 AM   #10
MaXimus
Meh!
MaXimus's Avatar
[ame="http://www.youtube.com/watch?v=VEcIswXR_Xo"]Engine issue - YouTube[/ame]
Updated video much more noticeable.
I have also filled up this morning different station will super 95 so it wasn't a case of bad gas.
Cheers!
1.18sec you notice the change in noise around 2.5k
Old 02-16-2014, 02:18 AM   #11
Burrcold
Drives: Subaru BRZ Limited
I don't hear anything.
Old 02-16-2014, 05:11 AM   #12
CircuitJerk
Pull my finger...
CircuitJerk's Avatar
Drives: Silver Scion Slushbox
I have a similar thing happening. I don't think it's a fuel quality issue in my case.
I see that something is also happening for you right around 4500-5000 rpm like VTEC kicked in yo...
For me, it developed last spring and I had my plugs changed. It made a difference but it didn't go away entirely. I will add that I had some issues with a previous tune, then switched to another tuner and changed over to E85. It was almost imperceptible but then noticed it had become more pronounced when I switched back to pumpgas for the winter, and ultimately storage.
My car is garaged for the winter, but I do plan on revisiting this once spring hits.
Subscribed...
CircuitJerk is offline   Reply With Quote
Old 02-16-2014, 10:02 AM   #13
MaXimus
Meh!
MaXimus's Avatar
[ame="http://www.youtube.com/watch?v=14nJT9a6K4k"]2.5 - 3.5k weird sound - YouTube[/ame]
I request you put headphones on and listen, please tell me someone can actually hear it this time..
Not on the first rev, the second one after the air dump from the truck that passed me.
Cheers!
Old 02-16-2014, 11:08 AM   #14
CoupedUpSubie
Drives: 2013 BRZ Limited
How long have you had the track pipe on your car? The AVCS on these cars kicks in somewhere between 3500 to 4000 rpms also.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
Engine bogging down FRiSson Issues | Warranty | Recalls / TSB 6 08-14-2015 08:07 PM
Wheel bearing gone at 1,500k!? Muskokan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 10-02-2014 03:58 PM
Transmission Dry Sound & Bogging jjkerr626 Engine, Exhaust, Transmission 3 06-11-2013 12:10 AM
Bogging Question??!! Help needed... ScionFrsFan Engine, Exhaust, Transmission 36 02-05-2013 06:44 PM
