Old 02-08-2014, 03:02 AM   #281
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
That's it, I need to get my welder back out. I really want to get better and this is inspirational!
I really really like that front pipe. Where/how much to do this? I'd love to see something like this and the overpipe in one piece like the Nameless one. Pretty much all the other front pipes have sharper bends and I really feel the shops are trying to hard to duplicate the stock pipe routing and sell two pieces rather than just one that does the whole job better (I'm staying NA for a good while, so no fancy turbo routing).
Those shop dogs are awesome. My dog barks at the welder when it's just sitting out in the back yard...
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 02-08-2014, 04:53 AM   #282
mrk1
Drives: Sterling BRZ Ltd
^^Thanks. The 2.5" front pipe is pretty straight forward fit up like any other one out there. The 3" requires a 3" over pipe which is a huge pain to make and I think that's why most companies just skipped it and made the combo things. I know I've been procrastinating on building one.
And my dogs don't mind the welder but the printer scares the crap out of the the black lab sometimes. And they both get really excited when I use the floor jack. Weirdo's at least I get a laugh out of it every time, helps the day to by.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-10-2014, 02:08 PM   #283
mrk1
O2 bungs welded in, down pipes done.
Cut out the drivers side fog light, left a little meat on the bone since I dont know what Im going to do with this side yet.
Template of a block off plate.
The Build Thread
The Following User Says Thank You to mrk1 For This Useful Post:
Sportsguy83 (02-11-2014)
Old 02-11-2014, 12:25 PM   #284
mrk1
whole lot of fittings today, should tick a lot of things off the to-do list.
Remote line for oil pressure sensor,
Runs under the intake manifold to some mounting bracket I haven't made yet.
Shouldn't have any issues with melted or falling off vacuum lines, braided lines. Vacuum block with the stainless barbs are for the BOV, boost controller, and whatever else needs it.
The Build Thread
The Following 2 Users Say Thank You to mrk1 For This Useful Post:
SkAsphalt (02-17-2014), Sportsguy83 (02-11-2014)
Old 02-11-2014, 12:37 PM   #285
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The fitting table looks EXPENSIVE! I need to do a remote line for Oil pressure sending unit too. Not hooked up right now because it doesn't fit.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
mrk1 (02-11-2014)
Old 02-11-2014, 01:14 PM   #286
mrk1
yeah that wasn't cheap but neither is loosing a motor because a 2 cent line fell off.
The Build Thread
Old 02-11-2014, 01:40 PM   #287
Sportsguy83
Drives: Limited BRZ
Oh yes I agree! Just pointed it out because it looked similar to the table when we were completing my kit and it burned a hole in my pocket
Though I'm jealous and want braided WG lines!!
Old 02-11-2014, 01:45 PM   #288
mrk1
My last build I messed up a few times and ended up having to pay shipping on 1 or 2 little fittings. That a few times is what almost drove me broke, I hate paying shipping multiple times. This time around I have been compiling that order for a while and only pulled the trigger when I thought I had as much accounted for as I could.
The braided lines are like $12 a pop, not all that bad considering there are only 2
The Build Thread
Old 02-11-2014, 01:59 PM   #289
mrk1
Busted out the press to build the drain line for the air/oil separator.
The Build Thread
MannyO (02-11-2014), Sportsguy83 (02-12-2014)
Old 02-11-2014, 02:03 PM   #290
swift996
swift996's Avatar
Any plan for a drain system on the oil cooler? I got the Perrin kit and was wondering if there's something that can be rigged up. Unfurtantely, there isn't a drain plug. The lines have a decent amount of oil in them though.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 02-11-2014, 07:27 PM   #291
mrk1
No plans, If I have to remove it I will just cap the ends of the lines.
The Build Thread
Old 02-12-2014, 10:55 AM   #292
mrk1
Rather then spider the wiring for gauges and what not into the cars electrical system I am going to install an ancillary fuse box to run anything I may ad to car. Radar detector, boost controller, gauges, should make things much easier in the long run.
The Build Thread
The Following 4 Users Say Thank You to mrk1 For This Useful Post:
F1point4 (02-24-2014), shaunsweeney (02-12-2014), Sportsguy83 (02-12-2014), trd87t (02-15-2014)
Old 02-12-2014, 11:28 AM   #293
Sportsguy83
Drives: Limited BRZ
Rather then spider the wiring for gauges and what not into the cars electrical system I am going to install an ancillary fuse box somewhere to run anything I may ad to car. Radar detector, boost controller, gauges, should make things much easier in the long run.
Much clean, Many impress, Such WOW
Old 02-12-2014, 11:47 AM   #294
mrk1
I'm supposed to get another snow storm tomorrow so no excuse to not take my time. I just build on my past experiences and always make the next one better then the last.
The Build Thread
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 07:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 11:53 AM
