Old 02-06-2014, 01:58 AM   #295
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by Indestruct View Post
I copied Luckrider & Jsimon's cranking tables... still only starting on the second time cranking... I wonder what it takes to get it on the first one? I'm using that crazy propel.
What temp?
Luckrider is offline   Reply With Quote
Old 02-06-2014, 03:04 AM   #296
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I have different a to e tables from luckrider. I also am using a different rom. His didn't have all the same tables defined. I will post later today when I get into the office where I left the laptop. You can pm me your email and I can send you a rom with the edits. I am on propel and it works great. So far five perfect starts.
Old 02-06-2014, 03:14 AM   #297
Indestruct
Drives: 2013 SWP Limited BRZ, MT
Originally Posted by Luckrider View Post
What temp?
I'm in Oakland, temp ranges from 40-60s right now.
PM Sent! Thanks
Indestruct is offline   Reply With Quote
Old 02-06-2014, 11:46 AM   #298
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
We really must be getting generous blends out here in Utah. Aside from a bit of bumble at first idle, I have had no cold start issues in temps as low as 12deg.
I should measure the ethanol content in my e85 soon.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 02-06-2014, 01:32 PM   #299
EAGLE5
Dismember
EAGLE5's Avatar
I have not measured the ethanol content. Need to find a tube of some kind. Still, I believe the Propel fuel is very high in ethanol because mixing in a gallon of gas in a full tank made a massive difference in start up. E85 is also 2.99 a gallon as of last night, which I like.
I have not calculated the mpg by fill up and miles, but the computer thingy says I'm getting 27.5 or so, which is about .5mpg less than it read for 91 octane. I have no idea if it becomes inaccurate with e85. Depends how it's calculated, I guess.
Old 02-06-2014, 02:43 PM   #300
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
It is absolutely wrong in fact.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
EAGLE5 (02-06-2014)
Old 02-06-2014, 04:56 PM   #301
EAGLE5
Dismember
EAGLE5's Avatar
Shhh! I'm just going to lie to myself, OK?
Old 02-09-2014, 04:08 PM   #302
EAGLE5
Dismember
EAGLE5's Avatar
FYI, I tried the 155b rom and had the worst startup ever. 4 tries. I have made changes to the RPM table and will try later today when my car is cold again. If that stumbles, I will try all my old (and relatively rich) settings on the new ROM and see if it works. Propel should change their name to Grumpy.
How many of you guys are using e85 ROMs and having poor cold startup?
Old 02-09-2014, 04:31 PM   #303
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Me. I use Propel and live in San Diego. On 60 degree mornings it takes 6 or 7 sputter-failing tries to finally get a good start. My neighbors think I drive a beater...
1 gallon of 91 clears it up for the most part. I'm waiting for Shiv to incorporate the good work of the forums to fix the E85 start issues
nlowell is offline   Reply With Quote
Old 02-09-2014, 05:32 PM   #304
DAEMANO
Time Traveller
Using the same tune I pump 2-3 gallons of 91 and the rest Propel e85 and have no cold start issues (in OC) 45-55 degree mornings. Give it a shot.
Old 02-10-2014, 12:37 AM   #305
EAGLE5
Dismember
EAGLE5's Avatar
Well, I keep experimenting and have a ROM that does start up every time on Propel. I have upgraded to the newest 155b ROM just today. The settings did not result in successful first startup, nor did running a more aggressive cranking RPM IPW table with the other settings as is. I have since changed the ROM to my old settings, though I will be playing around with somewhat leaner ones as I fear it is still over rich.
PM me with an email address if you want to see the 01c ROMs and settings I have been using.
And using a gallon or 2 of 91 does totally make a difference. Then the stock Vish settings seem to work fine. However, I want to move away from 91 as much as possible because I think it introduces too much variability in the gasoline content. Also, I want to run renewable as much as possible.
The Following User Says Thank You to EAGLE5 For This Useful Post:
DAEMANO (02-10-2014)
Old 02-10-2014, 02:43 PM   #306
Cross
It's the Mad Cow
Cross's Avatar
I am still having issues to I was better on 1.42 than 1.55 which is giving me more issues. I am thinking seriously about going back to my 1.42 setup.
I will check my changes vs. the changes @Luckrider and @jsimon7777 did. Thanks to both of you for the information you have shared it is a great thing to see being done in the community!
Luckrider looking through the tunes changes I was curious, what intake are you using?
Old 02-10-2014, 02:56 PM   #307
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
As far as E85 maps to, there isn't much difference the v1.55 maps and the v1.42 maps. Using the file comparison feature in Rom Raider will reveal all.
Shiv@Openflash is offline   Reply With Quote
Old 02-10-2014, 05:35 PM   #308
Luckrider
Luckrider's Avatar
Stock intake, same filter that shipped in the airbox all the way from Fuji Heavy Industries in Japan. Literally the only mods are:
1. Custom Startup Screen (my profile pic).
2. OFT.
3. I guess General Altimax Arctic 215/45R17 if you count winter tires as a mod
I have used two different e85 stations (and there is a third one that isn't far away that I might consider trying). My primary one appears to be lower e% based on the LTFTs (probably 70%-80%) whereas the other station I tried is probably at about 85%. I have only had it fail to start on the first push of the button twice and each time it fired right up on the next try.
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
