Old 02-09-2014, 12:53 AM   #29
jamesm
Originally Posted by OICU812 View Post
Good report. On your negatives list as far as ports etc are Revworks addressing this items prior to releasing final production for sales??
i have no idea. i'm sure they'd add them by request if nothing else. it's pretty specific to each setup. in either case it's a pretty simple thing to do. i didn't notice at the time or i'd have just had them add it to mine. the car had a hallman pro mbc on it before (actually it still does until my grimmspeed ebcs arrives) so i didn't need the compressor nipple until now, and the intake bit i don't need anyway because i plan to use their new dual vented catch can.
Old 02-09-2014, 02:20 AM   #30
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Originally Posted by SmsAlSuwaidi View Post
When you do upgrade to a 3076 will you do the bigger ar or go with a .63 ?
I did some testing with this turbo. The .82 reached boost onset quicker and made 30whp on the same 24psi. I didn't notice any degradation in throttle response either on an SR20.
Playing around with this turbo I found that the 6-blade non-gtx compressor sounds incredible. Like a jet engine spooling. The GTX doesn't make any noise. The T30 turbine does seem to be pretty restrictive given the size of the compressor. The GTX3576r is a better match overall, the smaller ar housings will want more boost to compensate.
I like to keep the exhaust free-flowing, it lowers backpressure, EGTs, reduces pumping losses etc. The T350 turbine in the GTX3576r is much better suited for what the GTX wheel can flow. Don't forget that improving the exhaust backpressure will also improve VE, and depending on the engine can offset the loss of transient response gained by going to a larger volute. At least, this is what my personal testing shows.
Coheed is offline   Reply With Quote
Old 02-09-2014, 06:00 AM   #31
JP
Backyard Fabricator
Drives: JZX83, SF5 GT, ZZE82 turbo
you could always weld a -3 or -4 AN fitting to the compressor housing or the cooler pipe, then run Teflon braided lines for your plumbing. That's what I've been doing with my setups for the last few years now and never have to worry about melted hoses etc
JP is offline   Reply With Quote
Old 02-09-2014, 12:51 PM   #32
jamesm
thanks for the info.. appreciated. i have to contradict your statement on the gtx30r's 11-blade wheel being quiet. @Sportsguy83's definitely has the jet engine noise . not so much as @Ironsquid's 35r, which is insane, but it's definitely there and noticeable.
i haven't really decided for sure what i'll do for the turbo. the 3576r actually sounds like a decent option as well, and more people are pushing me towards the .82 housing. decisions decisions...
Old 02-09-2014, 12:59 PM   #33
mrk1
Drives: Sterling BRZ Ltd
what 35 is Ironsquid running? I havent seen any 35's other then fbm
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 02-09-2014, 01:05 PM   #34
jamesm
full blown stage 2... gtx3582r
Old 02-09-2014, 01:36 PM   #35
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Hi, build in sig.
Ironsquid is offline   Reply With Quote
Old 02-09-2014, 01:53 PM   #36
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
After reading the report...you say cooling isnt an issue, even in florida, where is the turbo mounted, if not the front?
Old 02-09-2014, 02:49 PM   #37
jamesm
It's in the front. People's cooling issues don't come from where the turbo is mounted. They come from removing both of the stock fans and replacing them with slimlines that flow much less air. This kit retains one of the oem fans, which apparently makes a world of difference.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
MAPerformance (02-10-2014), TRD_07 (02-19-2014)
Old 02-09-2014, 03:30 PM   #38
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Interesting. good to know there is still hope for "cool" front mounted kits...my jokes suck I know.
The Following User Says Thank You to cdrazic93 For This Useful Post:
jamesm (02-09-2014)
Old 02-09-2014, 04:29 PM   #39
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
So when can we see some more detailed photos of this layout/design and some dynos? Eta to market sale?
Old 02-09-2014, 04:39 PM   #40
jamesm
They had an announcement thread a while back with all the build pics. A search should turn it up. Dynos were posted way back when as well, made 260whp on a mustang off the wategate (~8psi). Recent dyno showed around the same... 257 on an md-150 @8-8.5psi. Pretty much the same as any other kit with a 28r.
Old 02-09-2014, 04:39 PM   #41
Frs300
Frs300's Avatar
Drives: Pile of junk
next friday or the friday after next muahahha
EDIT: sorry i had to say it
Frs300 is offline   Reply With Quote
The Following User Says Thank You to Frs300 For This Useful Post:
jamesm (02-09-2014)
Old 02-09-2014, 10:00 PM   #42
diss7
Drives: AE86, 2x GT86, TE27
How much increased snatch should one expect with this kit?
That should always be a major consideration with any modification.
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
Ironsquid (02-09-2014), jamesm (02-09-2014)
Treadstone Performance Turbo Kit Update! kmbkk Forced Induction 277 01-17-2020 12:15 AM
MAPerformance Turbo Kit Officially Released! MAPerformance Forced Induction 633 07-26-2014 11:42 PM
Revworks turbo kit initial review jamesm Forced Induction 31 02-10-2014 07:42 PM
Rev Works turbo kit 2k mile update jamesm Forced Induction 35 09-06-2013 02:17 PM
Turbo Market and Technology Update circuithero Forced Induction 9 06-26-2013 09:27 AM
