Old 08-31-2013, 01:18 PM   #1
jamesm
Rev Works turbo kit 2k mile update
I just turned over 2000 miles with the turbo installed, so I figured I'd give you all a brief update.
The tuning is 95% complete at this point, and the car is making great power (260whp on a mustang @ 7psi). There is one issue remaining, which i'll detail in a minute. The guys at the shop are continuing to make improvements to the kit as we learn, and one of those will be a new charge pipe with relocated MAF going on next week, that should improve the stability of the MAF output. The initial design put the sensor a bit too close to the diameter change. Once this is on... we'll move on to solving the last bugging tuning issue:
Stalling. This car is driving me nuts for this reason alone. It's extremely weird behavior. Here's my best description:
- You know how when you cold start your car it idles kinda high for a few seconds than settles down? well, mine runs super rich and has to maintain super high load to keep idling, and even the rpms dip to ~500rpm.
- immediately after it settles down, the car will hunt up and down a couple hundred rpms for about 30 seconds to a minute, then settle into a perfect idle and run great.
- now the weird part: if you drive away (or even give it any throttle) before the hunting bit is complete, the car will stall repeatedly when you come to a stop and run like crap until you key it off/on and start the process over. if you wait until the hunting is complete (a minute or so after starting the car initially), everything runs perfect and the car never stalls. it's a beast.
I've been pouring over logs for weeks trying to figure out what the switch is that is causing this distinct change in behavior. I have a number of theories, probably none of which are 100% correct. But it's very clear: if you pull away to soon, it stalls and runs like poo. if you don't, it doesn't. Any ideas?
Beyond that everything is great. The kit is holding up great. No cracks, leaks, etc. I've recently added a Motiv overpipe and will be turning up the boost once the MAF pipe upgrade is finished. I can't wait!
The Following User Says Thank You to jamesm For This Useful Post:
charged86 (08-31-2013)
Old 08-31-2013, 02:50 PM   #2
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
A nice update, great that you are enjoying you car.
I'm no expert in tuning but these symptoms are really weird ! I guess when you pull away while it's hunting within the rough idle the car sticks with that idle issue ?
I'm no expert that's just a random ass guess, nevertheless keep on enjoying it
Sent from my phone
Old 08-31-2013, 05:11 PM   #3
Adeets
OEDC
Adeets's Avatar
Drives: Vortech 8.5psi 274WHP 2013 BRZ
Originally Posted by jamesm View Post
So I just turned over 2000 miles with the turbo installed, so I figured I'd give you all a brief update.
The tuning is 95% complete at this point, and the car is making great power (260whp on a mustang @ 7psi). There is one issue remaining, which i'll detail in a minute. The guys at the shop are continuing to make improvements to the kit as we learn, and one of those will be a new charge pipe with relocated MAF going on next week, that should improve the stability of the MAF input. The initial design put the sensor a bit too close to the diameter change. Once this is on... we'll move on to solving the last bugging tuning issue:
Do you have a light weight crank pully, or light weight flywheel?
I do and am tuned to idle at 900-700, it got rid of my weird hunting issues.
As a reference before I lightweighted my drive train I was idling between 700-600 ish.
As reference I have LWCP, LW flywheel, CF drive shaft, and 15.4lb wedsports.
My BRZ FI Build
Visconti is like a Tick that sucks as much blood(money) as he can before you figure out he's there.
please make sure to leave your experiences with visconti on his feedback thread located here: Visconti feedback
Adeets is offline   Reply With Quote
Old 08-31-2013, 05:28 PM   #4
jamesm
It does have an act streetlite flywheel. The idle, when it's settled, is around 900rpm. They raised it to accommodate the flywheel when the clutch was installed I believe.
@mad_sb have you found anything in your investigation into the ecu that may help understand what's going on?
Old 08-31-2013, 05:33 PM   #5
mike the snake
Maybe the cams need to settle in to their adjustments or initial settings. I read here that someone always let their car idle after starting to allow the cams to do their things.
Old 08-31-2013, 05:37 PM   #6
jamesm
I thought I had read that as well and suspect it may have something to do with it. I can't find that old post, though.
Old 08-31-2013, 06:59 PM   #7
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
I'm not forced induction so I have no right to chime in here, but my car exhibits the same behavior NA. Even if I started out after that first large RPM drop, the car would have really large trims, high load, stall if I came to quick stops and generally run like hell for an extended duration even after coming fully up to temp. Letting it warm up to the first notch above bottom before proceeding and it's fine every time. I know you're aware that fixes it, just thought I'd mention it may not be related to your specific configuration. I too remember reading the post about the cam angles adjusting themselves at startup, but wasn't that only for post-reflash, or are they always seeking initially? At least in my logs, I don't see the intake/exhaust angles moving around much from startup to warm.
Apologies if this isn't useful or germane to topic. Thanks for the update, and hope you find a resolution!
Nightbringer is offline   Reply With Quote
Old 08-31-2013, 07:48 PM   #8
Adeets
OEDC
Adeets's Avatar
Random question but do you have all the OEM patches installed in your tune? Your NA problem sounds like one I had before moto-mike updated me with the new patches.
My BRZ FI Build
Old 08-31-2013, 08:02 PM   #9
jamesm
The car is only a few months old and was flashes with any updates up to that point. I haven't taken it in to the dealer since I bought it.
Old 08-31-2013, 08:04 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
These symptoms don't make any sense to me. I have had my fair share of stalling problems from my Tial Q BOV opening at idle to the car stalling when I would put the clutch in and let the RPM drop at speed, but never any kind of issue like that.
Old 08-31-2013, 08:07 PM   #11
jamesm
Thanks for the input, definitely useful. I notice high trims like you describe as well.
I noticed today that if I get in and drive away immediately and can manage to not stall it (generally by not coming to a stop) in the first few minutes it'll almost go back to normal, not stalling anymore, but still hunting when I eventually do stop. If I wait 20-30 seconds for it to stop hunting then, it'll be perfectly fine thereafter. I'm stumped, but it definitely seems like some ecu routine getting interrupted by my driving too soon.
Old 08-31-2013, 08:15 PM   #12
Nightbringer
Drives: Scion FR-S
Yeah I was hopeful the A01 update post-tune would cure it but no dice. Two dealerships have stated it is "operating as intended." lol
Maybe does this have something to do with mad_sb's theory on the overly extended cold loop? I don't see how it would, as the trimmings normalize afterwards, just postulating out loud that perhaps there are other systems staying in an altered state for too long as well. Anything notably different in timing advance or cam angles from cold to warm idle? Mine seem to be more or less unchanged. Only variabls I'm seeing with any kind of delta are the trims, but I'm a newbie to all this.
Old 08-31-2013, 08:16 PM   #13
Adeets
OEDC
Adeets's Avatar
Your tuner should be keeping the OEM patches up to date with his tunes, I think the patch I'm talking about was 3 months ago?
My BRZ FI Build
Old 08-31-2013, 08:23 PM   #14
mike the snake
I read somewhere that when our cars start cold, the ECU is in closed, or open-loop, and after it warms up a little it goes to open, or closed-loop (not sure which), and I wonder if maybe by not letting the car complete that changeover it's doing what your cars are doing?
Treadstone Performance Turbo Kit Update! kmbkk Forced Induction 277 01-16-2020 11:15 PM
BRZ + Supercharger = ??? 1/4 mile girlracer Forced Induction 38 09-11-2014 11:28 AM
Turbo Market and Technology Update circuithero Forced Induction 9 06-26-2013 08:27 AM
10,000 mile update jeebus BRZ First-Gen (2012+) — General Topics 23 05-28-2013 06:59 PM
YES! AWD Turbo BRZ in the works for sure!!! ngabdala BRZ First-Gen (2012+) — General Topics 155 06-25-2012 09:15 AM
