#99 | |
Drives: 86
I also noticed that my afr became rich with 1.55 I think that @shiv@vishnu did that intentionally to have a safer tune for all of us. Sent from my iPhone using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#100 | |
Slack Bum
Drives: FT86
It's straight flat road and I did this log after clocked about 100km+ on 1.55B rom |
#101 |
Drives: WRB BRZ
I noticed that my 1.55b tune is also richer under wot conditions than 1.42. It actually puts it back inline with the stock tune, as far as AFR is concerned. So
#102 | |
RWD addicted
Drives: BRZ 6MT OFT OFH
Then how did you get that 7591RPM? Some mods that i don't know about or did you modify your tables for higher revving? Just to compare heres my WOT 1.55 log http://datazap.me/u/ondreiko/010214-...log=0&data=1-9 Same G-series (A00G) and same 98 octane. But it is winter here Last edited by Ondreiko; 02-07-2014 at 11:54 AM. Reason: addition |
#103 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
Changing the RPM Fuel Cut can do that. This is the Shiv set limit. Mine is set to 7650 and I have seen it as high as 7630 before in the logs.
#104 |
RWD addicted
Strange, mine is set to 7600/7550 on/off but i don't reach that limits during my wot pulls - have to investigate why when the roads are dry.
#105 |
#106 |
RWD addicted
#107 |
Fanboy
Drives: 2013 ultramarine frs
His soft rev limiter is probably progressive so conditions will impact when it tops out. Better to be 50-100 rpm short than it would be to sometimes over rev I would think.
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#108 |
Drives: 2013 FRS
That is correct. Since we implemented the soft rev limiter, torque will fall off 50rpm shy of he max rev value. So it will take a few seconds to hit the fuel cut from that point on. You would have probably shifted by then
#109 |
Read what the guys are saying below. I mostly did it because the is a slightly more noticeable (but not obnoxious) feel when on the limited. I noticed a few times where I was in part throttle and on the limiter but couldn't feel it because it was so smooth.
#110 | |
RWD addicted
This is probably the case - i do not like hp/tq drop and shift before it happens... my average highest value is about 7400 rpm in logs.
#111 |
RWD addicted
And i have one more doubt with my ROMs definitions - they are MILES and FAHRENHEITS in accordance with RomRaider tables - please confirm if it should work correctly with my metric car and ECU?
Or is it just RR.xml definitions feature? |
#112 | |
Slack Bum
Drives: FT86
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 11:12 AM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 12:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 09:05 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
