Old 02-07-2014, 10:49 AM   #99
8686
8686's Avatar
Drives: 86
Originally Posted by Ondreiko View Post
I like your max engine speed
But afr seems a bit rich on WOT - mine became about 0.5 higher on 1.55
Stage 1.
Probably it could learn for better afr later. But your max engine speed - i don't think i could ever reach the same numbers as your 7591 - was it a kind of downhill drive?
I also noticed that my afr became rich with 1.55
I think that @shiv@vishnu did that intentionally to have a safer tune for all of us.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 02-07-2014, 10:50 AM   #100
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Stage 1.
Hi Ondreiko,
It's straight flat road and I did this log after clocked about 100km+ on 1.55B rom
Burn is offline   Reply With Quote
Old 02-07-2014, 11:15 AM   #101
Vmax911
Drives: WRB BRZ
I noticed that my 1.55b tune is also richer under wot conditions than 1.42. It actually puts it back inline with the stock tune, as far as AFR is concerned. So from me!
Vmax911 is offline   Reply With Quote
Old 02-07-2014, 11:49 AM   #102
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by Burn View Post
Hi Ondreiko,
Hi!
Then how did you get that 7591RPM?
Some mods that i don't know about or did you modify your tables for higher revving?
Just to compare heres my WOT 1.55 log
http://datazap.me/u/ondreiko/010214-...log=0&data=1-9
Same G-series (A00G) and same 98 octane. But it is winter here
Ondreiko is offline   Reply With Quote
Old 02-07-2014, 11:51 AM   #103
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Hi!
Changing the RPM Fuel Cut can do that. This is the Shiv set limit. Mine is set to 7650 and I have seen it as high as 7630 before in the logs.
Luckrider is offline   Reply With Quote
Old 02-07-2014, 12:23 PM   #104
Ondreiko
RWD addicted
Ondreiko's Avatar
Strange, mine is set to 7600/7550 on/off but i don't reach that limits during my wot pulls - have to investigate why when the roads are dry.
Old 02-07-2014, 12:39 PM   #105
Luckrider
Luckrider's Avatar
I usually only see it in first gear. Mine is set to 7650/7550 on/off and it rarely breaks 7600 RPM.
Old 02-07-2014, 12:47 PM   #106
Ondreiko
RWD addicted
Ondreiko's Avatar
Are hp/tq rising upto your 7600 or dropping earlier? Whatever gear it is.
Old 02-07-2014, 12:49 PM   #107
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
His soft rev limiter is probably progressive so conditions will impact when it tops out. Better to be 50-100 rpm short than it would be to sometimes over rev I would think.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
Shiv@Openflash (02-07-2014)
Old 02-07-2014, 12:51 PM   #108
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That is correct. Since we implemented the soft rev limiter, torque will fall off 50rpm shy of he max rev value. So it will take a few seconds to hit the fuel cut from that point on. You would have probably shifted by then
Shiv@Openflash is offline   Reply With Quote
Old 02-07-2014, 12:53 PM   #109
Luckrider
Luckrider's Avatar
Read what the guys are saying below. I mostly did it because the is a slightly more noticeable (but not obnoxious) feel when on the limited. I noticed a few times where I was in part throttle and on the limiter but couldn't feel it because it was so smooth.
Old 02-07-2014, 01:14 PM   #110
Ondreiko
RWD addicted
Ondreiko's Avatar
Hi Shiv!
This is probably the case - i do not like hp/tq drop and shift before it happens...
my average highest value is about 7400 rpm in logs.
Old 02-07-2014, 01:28 PM   #111
Ondreiko
RWD addicted
Ondreiko's Avatar
And i have one more doubt with my ROMs definitions - they are MILES and FAHRENHEITS in accordance with RomRaider tables - please confirm if it should work correctly with my metric car and ECU?
Or is it just RR.xml definitions feature?
Old 02-07-2014, 06:49 PM   #112
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Hi @shiv@vishnu
I managed to do a 3rd gear WOT as follows http://datazap.me/u/burn/155b-oft-3r...7-8-9-10-11-12 Is it normal ?
Seems like my AFR dropped from 11.9+ to 11.2+ with more richness after comparing 1.42B vs 1.55B
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
