Old 02-04-2014, 01:23 PM   #85
Doctor Who
Equinsu Ocha
Doctor Who's Avatar
Drives: SWP BRZ Limited
Still getting the hang of data logging...This is a 3rd gear 2500-6000 rpm pull, stage 1, 91 Oct. I realize I probably should have gone up to 7k but traffic was heavy. Only mods are drop-in filter and perrin inlet tube. Any gurus care to chime in?
http://www.datazap.me/u/rbutler33/of...log=0&data=1-9
Doctor Who is offline   Reply With Quote
Old 02-04-2014, 01:26 PM   #86
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Find an empty road in the middle of the evening
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 02-04-2014, 01:32 PM   #87
jeebus
what's with your throttle? Are you actually doing a pull or are you part throttle and lifting???
jeebus is offline   Reply With Quote
Old 02-04-2014, 01:37 PM   #88
Kodename47
Kodename47's Avatar
Drives: UK GT86
Plus ideally you want to repeat the same runs a few times. I personally find a flat road and do a pull back and forth twice. Then you have 4 runs to compare and see how the car reacts.
.: Stealth 86 :.
Kodename 47 DJ:
Old 02-04-2014, 01:56 PM   #89
PMok
Codename: Stitch
PMok's Avatar
yeah, in order to provide meaningful info on the log you should be flooring it from 2000-7500rpm the whole way. Which means you should not be doing this in traffic. Find an empty road to do this, not on a busy street or freeway.
Old 02-04-2014, 02:22 PM   #90
Doctor Who
Equinsu Ocha
Doctor Who's Avatar
I was in traffic and found an opening in another lane, then while in 3rd gear accelerated up to 6k. I realize conditions werent optimal and will do some more logging tonight when the roads are less congested.
Old 02-04-2014, 10:50 PM   #91
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
my first datalog
http://datazap.me/u/vr46/e8520140204
First tank of E85, this is 70 miles after flashing the E85 tune.
BRZ 6AT, Borla UEL, Tsudo catted front pipe, OpenFlash Stage 2 UEL E85 A01D 1.54b map. 2nd gear.
VR46 is offline   Reply With Quote
Old 02-04-2014, 11:01 PM   #92
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Looks fine but 2nd gear goes by too fast to get the best possible data. Try to capture a few 3rd gear 2000-7500rpm WOT runs next time
Shiv@Openflash is offline   Reply With Quote
Old 02-05-2014, 09:07 PM   #93
VR46
are you Jeff Vader?
VR46's Avatar
http://datazap.me/u/vr46/e8520140205
Third gear this time - decided I was in the wrong spot to do more than one
Old 02-05-2014, 09:20 PM   #94
Shiv@Openflash
Drives: 2013 FRS
That's more like it. Beautiful!
Old 02-05-2014, 11:32 PM   #95
dom
86 owner
Drives: Toyota 86 GT
Hi, this is a 3rd gear pull with 1.55b, my 86 is using K&N air box, catless frontpipe and HKS exhaust, do you know if those readings are normal? Thanks
http://datazap.me/u/dom/3rd-gear-pull
dom is offline   Reply With Quote
Old 02-05-2014, 11:39 PM   #96
Shiv@Openflash
Drives: 2013 FRS
Looks fine for a ECU that hasn't adapted. I'm guessing this log was taken shorted after flashing since LTFTs are still 0. With some more driving, they will go a few % positive and AFR will hit the targets nicely. Just do another log in a few days and we can confirm this.
Old 02-07-2014, 08:04 AM   #97
Burn
Slack Bum
Burn's Avatar
Drives: FT86
Hi @shiv@vishnu
I managed to do a 3rd gear WOT as follows http://datazap.me/u/burn/155b-oft-3r...7-8-9-10-11-12 Is it normal ?
Burn is offline   Reply With Quote
Old 02-07-2014, 10:42 AM   #98
Ondreiko
RWD addicted
Ondreiko's Avatar
Drives: BRZ 6MT OFT OFH
Originally Posted by Burn View Post
Hi @shiv
I like your max engine speed
But afr seems a bit rich on WOT - mine became about 0.5 higher on 1.55
Stage 1.
Probably it could learn for better afr later. But your max engine speed - i don't think i could ever reach the same numbers as your 7591 - was it a kind of downhill drive?
Ondreiko is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
FS: Openflash Tablet Sgt.Beardface Engine, Exhaust, Bolt-Ons 8 01-04-2014 11:12 AM
FS: Openflash tablet nguyen_er Engine, Exhaust, Bolt-Ons 6 12-30-2013 12:31 PM
new OpenFlash tablet autobrz Engine, Exhaust, Bolt-Ons 5 12-23-2013 09:05 AM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
