go_a_way1
Old 02-04-2014, 06:12 PM   #2115
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by Cypher2 View Post
I was under the impression that the first number (225) referred to the width of the tire, and the 45 referred to the height (tall). I chose 45 to match the height of the stock wheels specifically so that I did not change anything to do with the gearing.. am I mixing it up?
Not exactly. The "45" sidewall is a ratio of the width. So it's really: 225mm x .45 = sidewall height. So a wider tire with the same ratio figure will actually be taller.
Check out any tire size calculator online to see the difference. Such as: http://www.1010tires.com/Tools/Tire-Size-Calculator
Someone on here made a tire/wheel fitment page specific to our cars. It might be in one of the stickies.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 02-05-2014, 01:47 AM   #2116
Cypher2
Drives: 2013 Ultramarine FR-S
Thanks for the info.. saved me from making a silly mistake on my tire selection. You said you run spacers but other people on these boards seem to not like running large spacers, I assume they negatively affect the handling?
Cypher2 is offline   Reply With Quote
Old 02-05-2014, 03:37 AM   #2117
hotpanda1
hotpanda1's Avatar
Drives: 2013 scion FRS
245/40/18 Nitto NT05 on a 18x9.5 +40 wheel dropped on RS*R coils i wanted to get 255/35/18 but Nitto does not make that size anymore, will be ordering tires tomorrow just wanted to make sure there won't be any issues.
thanks.
hotpanda1 is offline   Reply With Quote
Old 02-05-2014, 04:30 AM   #2118
pghfan19
Drives: honda civic ex
I'm completely new to the wheel world and needed help. I'm interested in putting on enkei nt03+m 18x9.5 +40. My FR-S is used as my daily driver and I only plan on lowering with springs. I'm interested in a squared set up and want to avoid any issues related to rubbing/fitment. What tire size would you recommend? Will these wheels fit with lowering springs or would I need to consider coil overs? Any help is greatly appreciated! Thanks
pghfan19 is offline   Reply With Quote
Old 02-06-2014, 12:12 PM   #2119
Verbal21
Verbal21's Avatar
Drives: 370Z
I plan on ordering Rota Torques(5x100/e48/56.1) w/ Ventus V12s(225/40/18 FRS) all around as soon as my income tax gets in, will I have no issues with that setup? Also, will it be flush with my sidewalls or would you guys recommend any spacers?
Verbal21 is offline   Reply With Quote
Old 02-06-2014, 12:52 PM   #2120
2point0
2point0's Avatar
Please do some more research. I don't think you can fit that without spacers (front spring perch is wide). If you have coilovers, they are much smaller in diameter so you can fit more wheel/tire towards the inside (high offset).
Old 02-06-2014, 12:53 PM   #2121
2point0
2point0's Avatar
You didn't mention wheel width or what suspension you have (springs or coilovers).
Old 02-06-2014, 12:54 PM   #2122
2point0
2point0's Avatar
thanks.
Look up Jive Turkey and King Tut. Their threads have useful info for this sizing.
The Following User Says Thank You to 2point0 For This Useful Post:
hotpanda1 (02-07-2014)
Old 02-06-2014, 01:15 PM   #2123
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
Has anyone fit
275/35/18 RS3?
Old 02-06-2014, 01:58 PM   #2124
Verbal21
Verbal21's Avatar
Drives: 370Z
Rota's will be 18x8 and I will be lowered on Eibach Sportlines (unless the pro-kit's are "better" for this setup)
Old 02-06-2014, 02:18 PM   #2125
2point0
2point0's Avatar
Seriously? People, SEARCH. At least read the stickies.
Just do the math. Same offset as stock, but one inch wider. That means only 1/2" bigger outside and 1/2" inside. I was on 17x9 +28 wheels at stock height and slightly taller tires (235/45-17). No rubbing anywhere. These fenders have tons of room.
And yes, your intended setup will have more than enough room in every direction, aside from the fact that those springs are arguably too low. Pro Kit would be a better handling setup, whereas Sportlines are more about looks. There are threads on this topic as well.
Old 02-06-2014, 02:29 PM   #2126
DAMotorsports
Drives: 2013 Scion FRS "Raven"
They will fit but you will need coilovers. We set up a car with the same riom and 265's without the owner reporting any rubing. we run 275's
DAMotorsports is offline   Reply With Quote
The Following User Says Thank You to DAMotorsports For This Useful Post:
2point0 (02-06-2014)
Old 02-07-2014, 12:03 AM   #2127
hotpanda1
hotpanda1's Avatar
thanks i actually just went with the Nitto Invo 255/35/18 theres a guy on here with the exact wheels, and coil overs, and this is the size of tire he runs with out any issues
Old 02-07-2014, 12:22 AM   #2128
FLIPs_FR-S
KCCO
FLIPs_FR-S's Avatar
Drives: 2013 Raven Scion FR-S, AT
18x10 +44 245/35R18 with RS*R lowering springs = almost 2" lower. Without fender mods.
Sent from my SAMSUNG-SGH-I527 using Tapatalk
Alabama state head for Southeast 86
https://www.facebook.com/groups/Southeast86/
FLIPs_FR-S is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
