Old 02-02-2014, 04:16 PM   #1
qtwre
Drives: White FR-S
Which Blowoff/Bypass Valve do you use?
I haven't seen a discussion anywhere about which BOVs people are using. I'd be interested to hear what the favourite options are and maybe some constructive discussion as to why one is prefered over another.
I'm thinking of the AVO kit and for now I think I may just go with a plastic Bosch.
qtwre is offline   Reply With Quote
Old 02-02-2014, 04:39 PM   #2
DAMotorsports
Drives: 2013 Scion FRS "Raven"
Well there are a lot of choose you can use. we use the Turbosmart Universal dual port BOV its pricy but we get 4 choose on how to set it you. also the GFB works great with the AVO kits. feel free to PM me if you have more questions.
DAMotorsports is offline   Reply With Quote
Old 02-02-2014, 05:01 PM   #3
mrk1
Drives: Sterling BRZ Ltd
I ran a Tial Q on my last STI and could never get it to perform consistently. On this BRZ build I have now switched to a TurboSmart VeePort Pro, haven't yet to run it but very impressed with it so far.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
MAPerformance (02-03-2014)
Old 02-02-2014, 05:41 PM   #4
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Short of how it looks, if you haven't run it, how can you be impressed?
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
The Following User Says Thank You to Hawaiian For This Useful Post:
FRS-HHH (02-03-2014)
Old 02-02-2014, 05:44 PM   #5
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
If you're going to run the AVO kit, I would suggest just getting the AVO BOV. You can get an OEM style 100% recirc or an adjustable one that will allow you to go 50/50 recirc.
protpibe is offline   Reply With Quote
Old 02-02-2014, 05:49 PM   #6
protpibe
protpibe's Avatar
I should also mention that going with the AVO setup on an AVO Turbo kit will mean you don't have to get any custom flanges welded on to the charge pipe.
Top Tier Imports - Check out my build journal HERE
Old 02-02-2014, 06:11 PM   #7
mrk1
Physical build quality and construction. Good instructions, things like that. I also had a hard time mounting the Tial because it was so large, the Vee Port is much smaller so thats much more freedom in terms of where to mount it.
The Build Thread
Old 02-03-2014, 12:00 AM   #8
qtwre
Drives: White FR-S
That for sure is the most fool-proof route but I'm not entirely sure what makes it worth the cost as compared to a less expensive alternative.
It would be great if everyone could state what they have and why they chose it for future searchers. There are a lot of turbos on the forum.
Old 02-03-2014, 09:20 AM   #9
jamesm
Turbosmart is where it's at. I've owned many a BOV and it's by far the best I've owned. Sounds awesome, it's nice and small so it'll fit just about anywhere, v-band connections, very high quality machine work and the customer service is insane.
I had an issue where they didn't list a spring stiff enough for the vacuum my engine pulls. I called Turbosmart and they had one overnighted to me for free the next day. I didn't even have to ask. I was calling to see if I could buy one and they were just like "oh no, it's on us, and it'll be there tomorrow morning". Best customer service experience I've had on a car part, ever.
Old 02-03-2014, 12:09 PM   #10
sid3way5
Drives: 13 wrb brz greddy evo3 catback.....
Im running the tial q on the fa20club 60trim kit it wouldn't open until I installed a vibrant vacuum line block now it works fine I tried to change springs but they were to soft so the valve would leak
fa20 kit
303/250
sid3way5 is offline   Reply With Quote
Old 02-03-2014, 12:23 PM   #11
MAPerformance
Drives: Asphalt FRS
We have always had great results with Turbosmart products. We are using either the Veeport or Raceport BOV, and Comp Gate 40 waste gate on our kits. Their quality is top notch for sure.
MAPerformance is offline   Reply With Quote
Old 02-04-2014, 05:14 PM   #12
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I had similar issues. I ended up with an 11 psi spring and a couple aluminum washers to keep it closed at idle. I believe they now make a 12 psi spring for the Q as well.
sid3way5 (02-09-2014)
Old 02-09-2014, 07:45 PM   #13
qtwre
Drives: White FR-S
I think I've settled on this GFB Respons TMS BOV. It has the capability to go from full recirc to full blow off with anything inbetween by adjusting a collar on the body.
I don't know anything about the company but those Australians seem to make good products. Any opinions?
Here's a video about it.
[ame="http://www.youtube.com/watch?v=ECkvx-YWgQI"]GFB Respons Blow-off valve - YouTube[/ame]
Old 02-09-2014, 08:04 PM   #14
jamesm
The important thing is just that if you have a draw through maf you use a recirc, and if it's blow through use whatever you want. Other than that it's pretty much personal preference. I'll always use turbosmart from now on though.
BRZ Back-up Camera and NAV Bypass SOLVED Flat Black VW Electronics | Audio | NAV | Infotainment 167 02-13-2018 12:45 AM
BRZ Nav Bypass lxsedan CANADA 43 03-30-2015 07:44 AM
BRZ NAV/DVD bypass Scooby South Electronics | Audio | NAV | Infotainment 88 02-24-2014 03:41 PM
US BRZ NAV bypass idea Zoti Electronics | Audio | NAV | Infotainment 7 12-17-2013 11:03 PM
Thunderhill (bypass) w/ GDS 4/9/2013 sw20kosh Tracking / Autocross / HPDE / Drifting 13 04-11-2013 06:55 PM
