Old 02-01-2014, 10:53 PM   #855
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Originally Posted by tbertran View Post
Did you check the 1st post? Also on their web page for the UEL header.
Haha definitely thought it was just a dyno vid
Hopefully some Perrin CBE peeps put some videos out though, would love to hear some rumble with that combo
calmtigers is offline
Old 02-01-2014, 10:54 PM   #856
JaguarXJ6
JaguarXJ6's Avatar
Drives: 2015 GT-R, 1993.5 Supra, 1995 XJR
FT-86 SpeedFactory Catted UEL Header
Originally Posted by calmtigers View Post
Interior video with full stock and UEL?
Or even more preferably (but probably not possible) resonated Perrin Catback? Just bought one of these from you guys would love to match with your UEL!
Once mine comes in will have full Perrin CAI and resonated exhaust with cats headers back with this installed. It already sounds amazing and can't wait for the header to factor in.
2015 GT-R Pearl White with Ivory, Premium | Stock, DD
1995 Jaguar XJR | Turquoise Metallic | I6 4.0L | Eaton M90, 11psi | 4L80E | 1 of 12 of 400
1993.5 Supra Turbo | Baltic Blue | 6spd | 3.77 Torsen LSD | SP57 | RPS manifold | ViPEC V88 | 525/500rwhp/tq
JaguarXJ6 is offline
The Following 3 Users Say Thank You to JaguarXJ6 For This Useful Post:
calmtigers (02-03-2014), Cjymiller (02-02-2014), JVQJR (02-03-2014)
Old 02-01-2014, 10:56 PM   #857
sharris721
sharris721's Avatar
Drives: BRZ 6MT
Have the exact same setup, cant wait.
sharris721 is offline
The Following User Says Thank You to sharris721 For This Useful Post:
calmtigers (02-02-2014)
Old 02-02-2014, 01:37 AM   #858
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
I'll be running a Nameless Axleback plus their catted and resonated OP/FP combo.
leicaboss is offline
Old 02-02-2014, 12:25 PM   #859
icebär
icebär's Avatar
Drives: Toyota GT86
Does the ECU try to correct the Torque Dip that the UEL Catted Header fills? Or does it work well like the guys always tell us, install and have fun + more Power/Torque?
Thanks, Jan
icebär is offline
Old 02-02-2014, 01:48 PM   #860
tbertran
tbertran's Avatar
Drives: Subaru BRZ (6027xx) Premium Manual
Thanks, Jan
You're assuming the torque dip is something the ECU would strive to achieve... As far as I understand it's simply a limitation of the engine/exhaust configuration, not a desired result.
FT86SpeedFactory catted UEL Header / GReddy EVO3 Catback / Cosworth Drop-in air filter / Shifteck short throw shifter / Kartboy pulley / Rear bumper diffuser / Perrin shorty antenna / Raceseng Slammer knob / Carsmo armrest / Clear side markers / 10" CustomSubEnclosure|Rockford R500X1D|Rockford P3D4-10 / Perrin Inlet Hose / GrimmSpeed front strut bar / Valentine V1 with BlendMount / All LED Inside
tbertran is offline
The Following User Says Thank You to tbertran For This Useful Post:
icebär (02-03-2014)
Old 02-02-2014, 04:48 PM   #861
icebär
icebär's Avatar
Drives: Toyota GT86
So the new FT86 Header will not 'lose' it's function of filling the torque dip, because the ECU tries to work against it?
The ECU will lern and say, "yeah I've got more torque and power to deliver at that rpm, let's do it!"?
icebär is offline
The Following User Says Thank You to icebär For This Useful Post:
eddieEndo (02-02-2014)
Old 02-03-2014, 09:30 AM   #862
JHarperFRS
JHarperFRS's Avatar
Drives: 2013 Scion FR-S "White Out"
Right now, I have a Perrin over pipe, Invidia catless front pipe, and Invidia ss catback...waiting on my FT86 catted uel header to come in. Should be loud. ...Hopefully not too loud or raspy, if so I'll be getting an Invidia catted front pipe.
JHarperFRS is offline
Old 02-03-2014, 11:08 AM   #863
jwbrocloud
Drives: Raven MT
If anyone bought this an has the ARK Grip catback please post a vid once you have it installed
jwbrocloud is offline
The Following User Says Thank You to jwbrocloud For This Useful Post:
Propaganda (02-03-2014)
Old 02-03-2014, 11:24 AM   #864
nelsmar
Thanks, Jan
The ecu does have a load limiter at lower RPM values.
Respecfully at:
RPM ENGINE LOAD
800 0.880
1000 0.900
1200 0.890
2000 0.919
2200 0.919
2400 1.070
2500 1.109
3000 1.099
3200 1.299
If your vehicle pushes over these load limits it will us methods to limit timing, and iirc fueling. However the torque dip starts right after this point. A large difference in the torque dip is made by tuning the cams in the car. Most headers let you tune the cams further and gain some additional power in that region.
My flickr - Canibeat
Local magazine scout
nelsmar is offline
Old 02-03-2014, 11:50 AM   #865
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Woah... FT86 SpeedFactory released a header and it didn't take them a year to produce a dyno sheet? Sorry but we know that good headers take time.
/s
campy is offline
The Following 2 Users Say Thank You to campy For This Useful Post:
FT-86 SpeedFactory (02-04-2014), shaunsweeney (02-04-2014)
Old 02-03-2014, 11:58 AM   #866
icebär
icebär's Avatar
Drives: Toyota GT86
Respecfully at:
RPMENGINE LOAD
8000.880
10000.900
12000.890
20000.919
22000.919
24001.070
25001.109
30001.099
32001.299
So if the load will not be over these numbers the header will produce more power that stock!?
I just want to make sure, that I don't have to flash or modify the ECU after installing the ft86 UEL Catted header!
icebär is offline
Old 02-03-2014, 12:21 PM   #867
nelsmar
I have no idea how much gain you will get from a catted header without a tune. Test it and find out for us! Headers can increase flow, and also lower egt allowing a more aggressive tune. So if you are not getting a massive increase in flow and mostly a lower egt then the gains would be minimal. Considering that the cat is a high flow cat... i would assume some flow change will occur giving some gains.
nelsmar is offline
Old 02-03-2014, 12:26 PM   #868
icebär
icebär's Avatar
Drives: Toyota GT86
I will do for sure!!!
But the guys said it will be no tune necessary, so header install and the torque dip is gone.
We'll see in march
icebär is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
