Old 01-26-2014, 10:25 PM   #1
Fr-Sheila
Drives: Frs 2014
Dash blinker stay on after installing leds
How do i get them to turn off... I have the relay for leds installed too
And the tail light blinkers stay solid as well but blink when i use the signals
Sent from my SGH-T989 using Tapatalk 2
Fr-Sheila is offline   Reply With Quote
Old 01-26-2014, 11:26 PM   #2
FirestormFRS
Bad flasher maybe? As easy as those things are to install it'd be hard to mess up.
FirestormFRS is offline   Reply With Quote
Old 01-27-2014, 02:12 PM   #3
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
What LED's did you replace?
I would also be guessing faulty flasher module.
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
Old 01-30-2014, 04:39 AM   #4
Fr-Sheila
Drives: Frs 2014
Got it fixed, apparently having both front and back turn signals led amber messes with the car
Old 01-30-2014, 11:32 PM   #5
phanguy
phanguy's Avatar
Drives: Scion FR-S Ultramarine
i have the same problem. what's your "fix"?
phanguy is offline   Reply With Quote
Old 01-31-2014, 01:47 AM   #6
Fr-Sheila
Drives: Frs 2014
the vendors i bought from said that only switch backs work with another set of leds
so i put switch backs in the front and amber leds in the back and that fixed the problem
having amber leds in front and back is what causes the problem
Old 01-31-2014, 02:15 AM   #7
phanguy
phanguy's Avatar
i already have switchbacks. guess i'll just contact the vendor i bought from and see what they have to say. @Diode Dynamics any ideas?
Old 01-31-2014, 02:27 AM   #8
Fr-Sheila
Drives: Frs 2014
yea you should probably ask them, idk they also work with one set of leds in the back and stock bulbs up front
Old 01-31-2014, 12:20 PM   #9
Diode Dynamics
Diode Dynamics's Avatar
It might just be a bad flasher module or perhaps it's not creating enough resistance for the bulbs to operate correctly.
Our flasher module works with LED's up front and normal bulbs in the rear etc...so I'd PM the vendor and see if they will send you a new flasher
Hopefully that helps a bit
Nick C.
John C.
Diode Dynamics
Old 02-04-2014, 11:39 PM   #10
empower-auto
Kouki-Monster
empower-auto's Avatar
rats. I have buddy club tail lights and diode dynamics switchbacks to install. now I have to pick one...
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 02-05-2014, 12:26 AM   #11
Burninator
Trogdor ftw
Burninator's Avatar
Drives: Asphalt FR-S M/T
The flasher that comes with the Buddy Club tails should be a LED capable relay (the one that came with my BC tails is) that technically should work fine.
I have the TapTurn flasher in atm that I installed before I got my Diode Dynamics switchbacks, but it won't be difficult to switch the BC flasher back in for a bit to test. Won't be able to do that until about noon tomorrow though.
Sent from my Nexus 7 using Tapatalk
"Hell hath no fury like a driver stuck behind a Toyota Prius."
Burninator is offline   Reply With Quote
Old 02-05-2014, 07:06 AM   #12
CaptainSlow
CaptainSlow's Avatar
I have LEDs front and rear...no problems with resistors in at both ends.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
Old 02-05-2014, 11:47 AM   #13
empower-auto
Kouki-Monster
So is it impossible to have LED's front and rear with only a flasher module? I have 2 I can try. The Buddy Club one and also the CF18 from Diode Dynamics.
Rich Anderson
EMPOWER AUTO
Old 02-05-2014, 02:07 PM   #14
jonzhuxD
Drives: Ultramarine FR-S
All you need is a flasher module designed for use with LED's, or inline resistors. One or the other, not both. (Although I'm not sure if it'll work with both). I have LED turn signals front and rear with an LED flasher module and all is well
jonzhuxD is offline   Reply With Quote
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
<<< NEW Interior LEDs ~ FR-S + BRZ Domelight/Trunk/Packages (BRIGHTNESS OPTIONS)>>> KI_ZN6 Interior Parts (Incl. Lighting) 939 02-18-2016 11:02 PM
Side Blinker Mod with SWITCHBACK LEDs AG3NT_5CARFAC3 DIY (Do-It-Yourself) Guides 19 09-16-2015 08:12 AM
Crap lights on my dash after installing coilovers. Eelusive BRZ First-Gen (2012+) — General Topics 43 02-12-2014 01:08 PM
Door Unlocked dash light coming and going after installing subwoofer tbertran Electronics | Audio | NAV | Infotainment 0 01-01-2014 10:22 PM
