Old 07-08-2013, 07:26 AM   #1
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Side Blinker Mod with SWITCHBACK LEDs
This is another video of the side blinker mod with switchback LEDs...
MY VIDEO:
[ame="http://www.youtube.com/watch?v=_41waF0gvW0"]FRS Side Blinker Switchbacks - YouTube[/ame]
FIRST YOU MUST DO THE SIDE BLINKER MOD FOUND HERE:
http://www.ft86club.com/forums/showt...=side+blinkers
Then I installed a Switchback LED found here:
http://autolumination.com/switchback.html
This is the diagram/extra step of how you would have to wire it to get SIDE MARKERS AS TURN SIGNALS like a "ViciousLED-like" switchback LED.
to go from WHITE-AMBER-WHITE-AMBER when the lights are ON.
to go from AMBER-WHITE-AMBER-WHITE when the lights are OFF.
However, I don't have this relay installed yet but maybe somebody else will.
PARTS YOU WILL NEED:
Qty. (2) - 12VDC/10A DPDT Plug-in Relay
Radio Shack Model: 275-218 | Catalog #: 275-218
Qty. (8) - 3 Amp Diodes
Radio Shack Model: 1N5402 | Catalog #: 276-1143
Qty. (16) - 1/4" Insulated Female Spade wire connectors
Qty. (6) - butt connectors
16 Gauge Wire
Soldering Iron w/Solder
Wire strippers
INSTRUCTIONS:
Pins 7 & 5 get diodes and go to ground.
Pin 8 goes to the turn signal wire harness on the headlight housing and gets spliced into the turn signal (+) wire.
Pin 6 also goes to the turn signal wire harness and gets spliced into the park light (+) wire with a diode.
Add a diode from pin 8 to pin 6.
Pins 3 & 2 get wired together and go to the 194 socket. This will be the wire that operates the amber side of the switchback.
Pins 4 & 1 get wired together and also go to the 194 socket. This will be the wire that operates the white side of the switchback.
You basically wired the relay as a stand alone unit with the diodes attached to it and the wire leads that have to run to ground, the turn signal harness and 194 socket terminated with disconnects that allow them to be spliced in or connected.
cut the the original 194 wires about 4" back from the socket and attached the wires that run from pins 1 & 2 to those 4" wires. Connect your ground and then splice into the turn signal harness. Plug the switchback bulb into the socket and test it out. If the bulb lights up amber for parking or white for turn, just pull it out and turn it around.
I hope this all makes some sense. It's not as complicated as I probably made it sound.
Hope this helps!
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 07-08-2013, 07:54 AM   #2
rba
Drives: Whiteout FR-S
How much blinker fluid is needed?
rba is offline   Reply With Quote
Old 07-08-2013, 08:47 AM   #3
FriedRicr
Woop Dee Woop Woop Woop
FriedRicr's Avatar
Drives: Raven 6MT FR-S
Great stuff man! its me r3dbuddha or friedricr from instagram the other day !
FriedRicr is offline   Reply With Quote
Old 07-08-2013, 08:50 AM   #4
AG3NT_5CARFAC3
Drives: Toyota GT86
good to see you on the forums bro! are you gonna be doing this mod?
Old 07-08-2013, 08:52 AM   #5
FriedRicr
FriedRicr's Avatar
it something i will most likely venture into down the road! i'm still iffy.
Old 07-08-2013, 08:55 AM   #6
AG3NT_5CARFAC3
Drives: Toyota GT86
totally understandable. If you have any questions on anything let us know; we will help the best we can! :happy0180:
Old 07-08-2013, 08:56 AM   #7
FriedRicr
FriedRicr's Avatar
thanks i appreciate that!
Old 07-08-2013, 09:19 AM   #8
sklimo
MY VIDEO:
http://web.stagram.com/p/495427446406997821_221961112
16 Gauge Wire
Wire strippers
INSTRUCTIONS:
Hope this helps!
Bout time dammit!!!!! LOL
Old 07-08-2013, 09:35 AM   #9
AG3NT_5CARFAC3
Drives: Toyota GT86
Just for you bro!
Old 07-08-2013, 09:40 AM   #10
sklimo
Just for you bro!
Now help me do it!!!!!!!!!!
Old 07-08-2013, 09:42 AM   #11
AG3NT_5CARFAC3
Drives: Toyota GT86
no problem! you been PM'd :happy0180:
Old 07-08-2013, 01:27 PM   #12
turbos86
Drives: 2014 Zenki 37J
Question: If I use a regular 194 LED in the side marker, single color on/off type that's not a switch back, do I still have to follow this DIY or simply follow the Side blinker mod DIY?
turbos86 is offline   Reply With Quote
Old 07-08-2013, 02:17 PM   #13
AG3NT_5CARFAC3
Drives: Toyota GT86
@Turbo86 just the side blinker mod. If you dont use a switch back LED, then the side blinks on the off phase.
Video here with non-switch back:
VIDEO CREDIT: @boonFRS
Old 09-12-2013, 02:29 PM   #14
Apotheosis
Drives: 13’ WRB BRZ
Anyone have a working video of this? Right now I'm just waiting on my bulbs to arrive. Otherwise I have everything waiting for them. I just wanted to see pictures of the working signals. Thanks.
Apotheosis is offline   Reply With Quote
FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! Diode Dynamics Interior Parts (Incl. Lighting) 158 08-08-2018 06:52 PM
** INTRO PRICING** JWM Switchback Turn Signal LEDS For FR-S Owners JWMotoring Exterior Parts - Lighting 212 04-06-2014 11:24 PM
LED DRLS + Switchback LEDS + Gramlight 57drs on!!!! eddieEndo FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 4 09-02-2013 11:46 PM
FS: Clear front side markers with built in LEDs turbos86 Canada Classifieds 2 06-10-2013 03:49 AM
DRLs, HID Kits, and Switchback LEDs TheGuyWithTheFireStorm Cosmetic Modification (Interior/Exterior/Lighting) 14 01-28-2013 11:50 PM
