Drives: Frs 2014
Dash blinker stay on after installing leds
How do i get them to turn off... I have the relay for leds installed too
And the tail light blinkers stay solid as well but blink when i use the signals Sent from my SGH-T989 using Tapatalk 2 |
#2 |
Bad flasher maybe? As easy as those things are to install it'd be hard to mess up.
#3 |
Drives: '13 WRB BRZ
What LED's did you replace?
I would also be guessing faulty flasher module.
In God We Trust - Hold No Faith That Violates Reason
#4 |
Drives: Frs 2014
Got it fixed, apparently having both front and back turn signals led amber messes with the car
#5 |
Drives: Scion FR-S Ultramarine
#6 |
Drives: Frs 2014
the vendors i bought from said that only switch backs work with another set of leds
so i put switch backs in the front and amber leds in the back and that fixed the problem having amber leds in front and back is what causes the problem |
#7 | |
guess i'll just contact the vendor i bought from and see what they have to say. @Diode Dynamics any ideas?
#8 | |
Drives: Frs 2014
#9 |
It might just be a bad flasher module or perhaps it's not creating enough resistance for the bulbs to operate correctly.
Our flasher module works with LED's up front and normal bulbs in the rear etc...so I'd PM the vendor and see if they will send you a new flasher Hopefully that helps a bit Nick C.
#10 |
Kouki-Monster
rats. I have buddy club tail lights and diode dynamics switchbacks to install. now I have to pick one...
Rich Anderson
EMPOWER AUTO |
#11 | |
Trogdor ftw
Drives: Asphalt FR-S M/T
I have the TapTurn flasher in atm that I installed before I got my Diode Dynamics switchbacks, but it won't be difficult to switch the BC flasher back in for a bit to test. Won't be able to do that until about noon tomorrow though. Sent from my Nexus 7 using Tapatalk |
#12 |
I have LEDs front and rear...no problems with resistors in at both ends.
Ultramarine 2013 Scion FR-S 6MT
#13 |
Kouki-Monster
So is it impossible to have LED's front and rear with only a flasher module? I have 2 I can try. The Buddy Club one and also the CF18 from Diode Dynamics.
Rich Anderson
EMPOWER AUTO |
#14 | |
Drives: Ultramarine FR-S
All you need is a flasher module designed for use with LED's, or inline resistors. One or the other, not both. (Although I'm not sure if it'll work with both). I have LED turn signals front and rear with an LED flasher module and all is well |
| FR-S / BRZ Turn Signal LEDs! No Resistors! Switchbacks! Plug & Play Install! | Diode Dynamics | Interior Parts (Incl. Lighting) | 158 | 08-08-2018 06:52 PM |
| <<< NEW Interior LEDs ~ FR-S + BRZ Domelight/Trunk/Packages (BRIGHTNESS OPTIONS)>>> | KI_ZN6 | Interior Parts (Incl. Lighting) | 939 | 02-18-2016 11:02 PM |
| Side Blinker Mod with SWITCHBACK LEDs | AG3NT_5CARFAC3 | DIY (Do-It-Yourself) Guides | 19 | 09-16-2015 08:12 AM |
| Crap lights on my dash after installing coilovers. | Eelusive | BRZ First-Gen (2012+) — General Topics | 43 | 02-12-2014 01:08 PM |
| Door Unlocked dash light coming and going after installing subwoofer | tbertran | Electronics | Audio | NAV | Infotainment | 0 | 01-01-2014 10:22 PM |
