Old 01-25-2014, 07:39 PM   #211
jflogerzi
jflogerzi's Avatar
Originally Posted by shiv@vishnu View Post
It is unlikely that you will be able to return your stock ECU ROM back to 100% stock since your current flash has some unique license/customer info in an unused portion of the ROM image. So when you install the OFT, it probably won't be able to match your "stock" ROM with any of the actually stock ROMs in it's database. This means that it will not be able to automatically generate compatible tuning files. So you will have to load them manually. And if you want to run the new v1.5x tunes, you will need to download your "stock" map off the OFT and email it to me so I can add it to the database (.dev) file. I'll then post up an updated .dev file for download
Care to explain this a bit. Tonight I will flash back to my stock rom provided by my tuner. Do you need a copy of this or does it need to go through the otf first? Let me know so I am ready
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
Old 01-25-2014, 08:05 PM   #212
steve99
Drives: FT86
If its an Ecutek "stock" rom the tuning parameters are returned to stock specifications but their is a small "signature or license info" in the ROM presumably for ecutek to detect that its had an ecutek tune or license info ect.
Hence the ROM provided is not 100% the same as stock if you look with a HEX editor, but will perform in the car as a "stock" ROM. This signature/licience info is put in an area unused by the stock ECU but presumably it looked for by Ecutek software
however this extra info is enough for the OFT not to recognise its as a "stock" rom, so shiv will need to add it to the database, I believe they are working on a "stock" rom overwrite/upgrade feature to be released soon
Shiv@Openflash (01-25-2014)
Old 01-26-2014, 01:16 AM   #213
steve99
Drives: FT86
yes, it was great! You have email
Just for something different decided to do some economy runs on the new 1.53 tunes to and from work. Pretty flat run no highway light traffic
Can average around 6.5 l/100km too work and 7 on the way home diving like a "nun" on stock ROM (no offence to nun's intended)
With 1.5x tune it was actually better by about 0.5 litres per 100km. both ways ie 6 and 6.5 l/100km
Attribute that to better low down torque so can pull higher gear I have manual was pretty hot too 100F day.
http://datazap.me/u/steve99/easy-run...k?log=0&data=1
Shiv@Openflash (01-26-2014)
Old 01-26-2014, 04:04 AM   #214
8686
8686's Avatar
Drives: 86
Dear @shiv@vishnu
Is the 700K ROM going to be available soon as it is not availabe in 1.42 version.
Thank you
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 01-26-2014, 08:54 AM   #215
Victor Draken
Drives: Toyota Gt86
The OTS maps are not intended for big MAF housings. Nor do we currently have any maps for them so you'd probably be best off just putting in a standard diameter CAI. Not only would drivability likely be better, you'd also have access to more OTS maps to choose from. You can certain use our custom tuning service to dial in a particular map for your large MAF housing. But I think that's a waste of money since there is no benefit to 3" intake in an NA car.
Shiv one more question, what about EL high performance Aftermarket Header like Nameless/JDL/HKS?
Will you revise the stage 2 EL maps in some way, so that who bought these kind of headers will at least take advantages of these add-on?
I know you sell OFH and it's UEL etc. but I think a good chunk of ppl that use or will use OFT will buy nameless/jdl v2 EL header as well. Did you think about it?
Victor Draken is offline   Reply With Quote
The Following User Says Thank You to Victor Draken For This Useful Post:
8686 (01-26-2014)
Old 01-26-2014, 09:01 AM   #216
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
There are OTS tunes specifically for aftermarket EL headers already, I'm sure shiv will continue to refine them with feedback from owners.
- AdrianG
AdrianG is offline   Reply With Quote
Old 01-26-2014, 09:02 AM   #217
Malt
Drives: 2015 WRX
Why would he need to revise those maps since he's already made stage 2 maps for EL aftermarket headers? IIRC the first car he tuned for stage 2 had aftermarket EL headers then he started developing the OFH, which is why there is a distinction between EL and UEL stage 2 maps. One is optimized for EL then other for UEL.
Malt is offline   Reply With Quote
Old 01-26-2014, 09:17 AM   #218
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
I'm running a FA20club.com Equal Length Header with OFT v1.54 Stage 2 successfully, FA20club.com EL header is catted as well, going to remedy that soon with an uncatted header pipe from FA20club.com
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-26-2014, 09:42 AM   #219
Victor Draken
Drives: Toyota Gt86
If you read the release notes on the maps file it says: E85 EL map to be used with stock header running just E86.
Unless i read it wrongly I would say that the map
Is not really extracting the advantage of very good headers like NP/JDL/HKS.
The UEL map are much more refined in my opinion compared to EL one.
If I'm wrong shiv will of course explain it.
By the way what happened at shiv vendor tag?
Old 01-26-2014, 09:56 AM   #220
Malt
Drives: 2015 WRX
You are reading it wrong. There was testing done that showed running the stage 2 EL E85 maps was safe to run with the stock headers but it was designed for running with catless EL headers. Shiv has spent a considerable amount of time on the UEL maps lately but all the refinements on the learning and etc was also included in the EL maps as well with this latest map release.
As for his vendor tag being removed, the same thing happened a couple weeks ago. Its most likely a forum bug.
The Following User Says Thank You to Malt For This Useful Post:
Victor Draken (01-26-2014)
Old 01-26-2014, 12:46 PM   #221
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
unable to get read/ write to work. cal id za1jbooc. flashed it back to stock erased oft and uninstalled ofm and reinstalled everything and tried again still no go. any ideas anyone?
Liquid6 is offline   Reply With Quote
Old 01-26-2014, 12:50 PM   #222
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
How can you flash it back to stock if read/write doesn't work. Not sure I follow. But I can probably help you with more info.
Shiv@Openflash is offline   Reply With Quote
Old 01-26-2014, 12:52 PM   #223
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
i added the old stage 1 beta tune i got awhile ago from you guys that let me flash it back to stock
Old 01-26-2014, 04:04 PM   #224
Liquid6
Liquid6's Avatar
Drives: 2014 FR-S
any ideas yet @shiv@vishnu?
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 03:26 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 10:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
