Old 01-22-2014, 11:38 PM   #183
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by jflogerzi View Post
Order processed for competitive discount on a OFT. Looking forward to the OTF. The service you provide is top notch. Also the regular updates are great! Can't wait. What kind of shipping do you guys use? Hoping I can get it by Friday since I live in CA
Mine came USPS Priority Mail. 3 days total to NY (it was scheduled as 2 day, but was 3 due to weather delays slowing all shipments down). USPS has a priority map, but if I had to guess, 1 day shipping for you. Most of CA was (except for splotchy patches).
Luckrider is offline   Reply With Quote
Old 01-22-2014, 11:40 PM   #184
jflogerzi
jflogerzi's Avatar
Perfect! Time for some fun this weekend. Reinstall stock air box, update to shiv's new tune, and bed my new Project Mu HC+800 brakes. Its going to be a busy weekend!
Old 01-22-2014, 11:46 PM   #185
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Thanks for the order! Your OFT should ship out tomorrow and you should have it on Thursday or Friday depending on USPS
Don't forget that you need to flash your ecu back to stock prior to OFT install. So you'll have to get a stock file from your ecutek tuner.
Shiv@Openflash is offline   Reply With Quote
Old 01-22-2014, 11:52 PM   #186
jflogerzi
jflogerzi's Avatar
Already have my stock File. I will flash it tomorrow after work. Thanks for the reminder.
Old 01-23-2014, 12:29 AM   #187
Luckrider
Luckrider's Avatar
I data logged on the way home. If you zoom in properly, you can see the couple of times I went WOT in 6th gear (1000 RPM rise taking 15 seconds anyone?) and some good rev matching getting off the highway. If you also look really carefully and know what to look for, you can see towards the end of the log where the car was breaking traction in 1st gear from a roll. It was so cold today that less than 2500RPM with an aggressive roll of the throttle from start was enough to get the rear loose... and this was on winter tires. I am thinking I might switch back to 93 tomorrow till the super cold weather is gone and I get some new tires. Heck, the car had a nice light feint in the rear getting on the highway at ~50mph in second under WOT.
Edit: A link might be nice: http://www.datazap.me/u/luckrider/e8...-tune-5%C2%B0f I am still noticing large fluctuations in the LTFT. I am not sure if this is because the computer is compensating for the low E fuel or if it has to do with the amount of time it has had to learn.
Old 01-23-2014, 02:31 AM   #188
Shiv@Openflash
Drives: 2013 FRS
It is unlikely that you will be able to return your stock ECU ROM back to 100% stock since your current flash has some unique license/customer info in an unused portion of the ROM image. So when you install the OFT, it probably won't be able to match your "stock" ROM with any of the actually stock ROMs in it's database. This means that it will not be able to automatically generate compatible tuning files. So you will have to load them manually. And if you want to run the new v1.5x tunes, you will need to download your "stock" map off the OFT and email it to me so I can add it to the database (.dev) file. I'll then post up an updated .dev file for download
Old 01-23-2014, 08:54 PM   #189
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Shiv
V1.54 EL A01D Gas is amazing, just returned from the first drive. What a difference a tune can make! V1.42 was such a huge step in the right direction for this car, the V1.54 is even better. More responsive, pulls harder and quicker to red line.
Didn't tell my daughter, just sent her out for a quick drive, she needed a study break anyway. The smile was huge, the question though was a real pisser, "if you didn't change anything why didn't it run like this before"? The truth can hurt.
Need to dyno this car before the heat returns to South Florida.
Thank you for the excellent tuning.
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 01-23-2014, 09:43 PM   #190
Luckrider
Luckrider's Avatar
@shiv@vishnu, you have a PM about some IPW testing.
Old 01-23-2014, 11:07 PM   #191
freedumb512
freedumb512's Avatar
Drives: Raven FR-S MT
Ordered mine today!
Shiv, my car is stock aside from an Injen CAI. I honestly have no clue how to tune a car, but OFT seems pretty user friendly and just by reading through these forums I think help will be easy to come by.
freedumb512 is offline   Reply With Quote
Old 01-23-2014, 11:50 PM   #192
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
Stage 1 data log done on 1.53b, 55 miles after flash, 91 oct, header back + intake mod.
All instances of WOT were in 3rd gear.
Comments appreciated as always.
http://www.datazap.me/u/danklvr/153b...t-55mi-1-23-14
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
Old 01-24-2014, 02:13 AM   #193
Shiv@Openflash
Drives: 2013 FRS
It looks quite good. Can't really think of any other comments to make. Which is a good thing
Old 01-24-2014, 02:14 AM   #194
Shiv@Openflash
Drives: 2013 FRS
With the OFT, you don't need to know how to tune a car. If you can use an iPod, you overqualified to use the OFT to flash your ECU now that it comes with pre-loaded tune files
Old 01-24-2014, 02:15 AM   #195
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by tonystewart View Post
Shiv
Thanks! We love getting feedback like this. Keep enjoying your car
Old 01-24-2014, 02:21 AM   #196
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
When should us non .dev format users expect to see the .bin files for the new tunes?
garfull is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 03:26 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 10:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
