Old 01-26-2014, 06:46 AM   #2899
s2d4
s2d4's Avatar
It needs to turn into 0-5V so that's why the Zeitronix ECA helps.
Old 01-26-2014, 08:54 AM   #2900
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by Calum View Post
Why not make your own? This was just a couple minutes of searching.
Harness to plug into the sensor, probably have to hack off the end you wont use.
http://www.gmpartsdirect.com/results...umber=13352241
Long tube sensor
http://www.gmpartsdirect.com/results...umber=13577394
Short tube sensor
http://www.gmpartsdirect.com/results...umber=13577379
Push on adapter
http://www.summitracing.com/int/part...4120/overview/
I'd prefer buying a kit with the proper fittings/hoses for our car, after the flex-fire.
Old 01-26-2014, 09:04 AM   #2901
Calum
That Guy
Drives: 2013 asphalt FRS MT
From what I can tell the flex fire was due to using cheap adapters at the sensor. The adapters I linked are different, and should be very secure. The only reason I looked at all is because I realized I don't know of any shops selling a kit now that both Toni and John have gone down the toilet. I have a faint memory of someone saying they were working on a kit, might have been Delicious, but I'm not sure. If you're not dead set against putting your own together, check the haltech forums. They had some good info on it. They recommended a speedflow fitting that's pretty much identical to the russel I linked, I just found the russel for about 2/3 the price.
Either way man, keep us updated.
Old 01-26-2014, 10:51 AM   #2902
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
91 octane and heat will certainly hurt the smaller pulley gains even intercooled. On good fuel and/or cooler temps you should see about 10-15 hp each 2.5 mm of pulley difference.
Originally Posted by Ryan86 View Post
Here are our test results from today on our dyno
Firstly the dyno is a Inertia dyno with 0 correction factor and does not give happy numbers
So I received @DeliciousTuning new tune which allows to change from 75mm down to 70mm. Bill has not received any logs to review tune on my car, so I mention this, as I noticed some timing being pulled at top maybe due to safety factor.
Sent in logs to correct.
I don't think I have seen these results posted yet all done same day on same dyno, Sprintex Intercooled kit.
All runs on 95 Ron = 91 Oct
My stock dyno run 154whp 135ftlb
75mm = .68 bar boost = 217whp 188ftlb
72.5mm = 0.73 boost = 225whp 189ftlb
70mm = 0.8 boost = 231whp 196ftlb
The above was done on the coast, summer conditions extremely hot today 36 deg c, so possibly lost 10% power due to the heat factor.
Mods if you would be interested
HKS intake duct
AFE pro dry DIF
Borla UEL
63mm overpipe
63mm performance exhaust, I added a small HPC to front pipe for noise reduction
Hope this info helps.
Xero-Limit is offline   Reply With Quote
Old 01-26-2014, 11:12 AM   #2903
xjohnx
Grip>Slip
xjohnx's Avatar
@moto-mike - do you have a flex fuel kit? working on one?
Old 01-26-2014, 02:55 PM   #2904
xxscaxx
Drives: 2013 SWP BRZ
@xjohnx - hit up @PrimeMotoring, they have a flex fuel kit that I bought. Very hight quality parts and none of that fire business
Just to confirm, my coolant leak is coming from the preclamped tee fitting on the intercooler hose off the back of the supercharger that connects to the coolant bottle. I have to get a crimping tool to try to tighten them.
xxscaxx is offline   Reply With Quote
Old 01-26-2014, 03:04 PM   #2905
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Working on one.
Old 01-26-2014, 03:43 PM   #2906
xjohnx
Grip>Slip
xjohnx's Avatar
Originally Posted by DeliciousTuning View Post
Working on one.
Thought I remembered hearing something about that. Glad to hear it. Definitely let me know when you're ready to start selling them!
Old 01-26-2014, 04:27 PM   #2907
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Yes please let me know as well
Sent from my DROID RAZR using Tapatalk
Area86 is offline   Reply With Quote
Old 01-26-2014, 04:43 PM   #2908
DeliciousTuning
There will be a few more features on this FlexFuel Kit, so I am sure everyone will like it.
Cheers,
William Knose
Old 01-26-2014, 07:59 PM   #2909
xjohnx
Grip>Slip
xjohnx's Avatar
IC install finished, no leaks that we can see. only driven it long enough for a shakedown run and to get some datalogs for William @DeliciousTuning, but she feels good so far!
Old 01-26-2014, 09:04 PM   #2910
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Originally Posted by normancw View Post
Great thread - thanks to all owners for their contributions. I'm very interested in getting this kit. I've gone through most of the thread and think these are the things to watch out for when installing:
Anything else to watch for?
I posted these links on page one for future installation reference.
@stockysnail, do you have a new dyno sheet for me to post?
Old 01-27-2014, 12:41 AM   #2911
stockysnail
Just the tip
stockysnail's Avatar
Yes it's in my build thread
Old 01-27-2014, 09:26 AM   #2912
xjohnx
Grip>Slip
xjohnx's Avatar
If I only get one, should I get the "PCV Valve" kit? Are there diminishing returns for getting the 2nd catch can?
Here's Radium's explanation on what each can does:
The "Crankcase Vent" kit mounts on the left side of the engine bay. This catch can runs inline with the 1/2" breather port. At low loads it experiences atmospheric pressure, but when the engine is at high load (WOT), this hose will experience vacuum and would normally be drawing unwanted crankcase vapors, unspent fuel, and oil sludge into the air filter intake pipe.
The "PCV Valve" kit mounts on the right side of the engine bay. This catch can runs inline with the 3/8" PCV (positive crankcase ventilation) valve. When the intake manifold pressure is close to or greater than atmospheric pressure, the PCV "check" valve closes and, thus, this hose experiences no flow. Conversely, the PCV hose will experience "metered" vacuum when the engine is idling, steady state cruising, and decelerating. This would normally draw unwanted crankcase vapor, unspent fuel, and oil sludge into the intake manifold immediately after a high load run. Note: Because the Radium catch cans are pressure sealed, they are great for boosted applications as well so connecting to the intake manifold is permitted.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
