Old 01-24-2014, 11:37 PM   #2885
JerryMichaels7
Drives: Whiteout FRS
I asked on facebook yesterday and they said they are shooting for febuary in regards to the 335
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 01-24-2014, 11:43 PM   #2886
Powersfrs
Drives: Frs
Wonder what kinda numbers it'll put down and if it'll be a bolt on like the 210 or if engine upgrades will be a must
Powersfrs is offline   Reply With Quote
Old 01-24-2014, 11:43 PM   #2887
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Originally Posted by xxscaxx View Post
It was easy for me to remove the back elbow, but then again I have the proper tool to do it, so if you don't then I can see it being a bigger PITA.
Well my coolant dropped down again....idk wtf is going on. I built up maybe 3 pounds of boost on my way into work today, it was full last night, so idk, maybe a coincidence, but i'm going to get into boost again a little on the way home and see if the level drops.
Either way this is annoying as hell. I am guessing the leak is in the intercooler, because there is no leak anywhere else, i've checked about 10 times already. Unless I just had a bunch of air in my system but I doubt it at this point. I have to check my subaru super blue coolant bottle and see how much left I have and compare it to the 2.2l the system takes.
Is your coolant holding now?
Ryan86 is offline   Reply With Quote
Old 01-24-2014, 11:54 PM   #2888
xxscaxx
Drives: 2013 SWP BRZ
I have to fess up and eat some crow, as I said I checked multiple times for leaks and didn't find any. Low and behold today, I found one. It's been so cold here that it was hard to smell/tell. The clamp on the coolant bottle line that connects to the plastic tee was leaking and I somehow didn't see it. Was leaking on the bottom. I repositioned it and tightened it down, so I will check it again but all seemed ok after a few checks. I can't tell if those pre clamped lines are leaking at all on the tee but I cleaned the area up and will check again next drive out. Thanks for following up.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
CK_Bladesmith (01-24-2014)
Old 01-25-2014, 12:08 AM   #2889
DriftEm
DriftEm's Avatar
Originally Posted by wrxgoose View Post
that's where we plan on doing it as well. how long is the line you used, and what hole did you go through? i plan on trying to go through the sound tube hole, just for now.
and iirc, the 335 was causing some engine problems. gotta look it up again ot be certain though
I got the P3cars gauge with optional boost sensor, so I got the sensor module in the engine bay and the wire going through the firewall hole to the gauge.
DriftEm is offline   Reply With Quote
Old 01-25-2014, 02:47 AM   #2890
TaroYamada
TaroYamada's Avatar
Drives: Toyota 86 RC
my friend car it also leak here! very bad design!
TaroYamada is offline   Reply With Quote
Old 01-25-2014, 09:12 AM   #2891
xxscaxx
Not so much design, but maybe if they provided the right clamps it wouldn't leak. Now if it's leaking from the preclamped fittings, then yes, bad design just need a crimp tool to tighten it.
Old 01-25-2014, 09:42 AM   #2892
Ryan86
Road Warrior
Ryan86's Avatar
Here are our test results from today on our dyno
Firstly the dyno is a Inertia dyno with 0 correction factor and does not give happy numbers
So I received @DeliciousTuning new tune which allows to change from 75mm down to 70mm. Bill has not received any logs to review tune on my car, so I mention this, as I noticed some timing being pulled at top maybe due to safety factor.
Sent in logs to correct.
I don't think I have seen these results posted yet all done same day on same dyno, Sprintex Intercooled kit.
All runs on 95 Ron = 91 Oct
My stock dyno run 154whp 135ftlb
75mm = .68 bar boost = 217whp 188ftlb
72.5mm = 0.73 boost = 225whp 189ftlb
70mm = 0.8 boost = 231whp 196ftlb
The above was done on the coast, summer conditions extremely hot today 36 deg c, so possibly lost 10% power due to the heat factor.
Mods if you would be interested
HKS intake duct
AFE pro dry DIF
Borla UEL
63mm overpipe
63mm performance exhaust, I added a small HPC to front pipe for noise reduction
Hope this info helps.
The Following 5 Users Say Thank You to Ryan86 For This Useful Post:
Alabang 86 (02-06-2014), Calum (01-25-2014), DeliciousTuning (01-25-2014), shaunsweeney (01-25-2014), swift996 (01-25-2014)
Old 01-25-2014, 10:48 AM   #2893
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
HKS intake duct
AFE pro dry DIF
Borla UEL
63mm overpipe
Hopefully you get some tweaks on your tune. Looks pretty promising and I have heard Bill is the guy to go to for a tune on this Innovate kit. I wanna see where you end up with some updates. What type of dyno and I assume this are un corrcted numbers?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 01-25-2014, 11:23 AM   #2894
Ryan86
Road Warrior
Ryan86's Avatar
Our dyno is a loading inertia dyno. 0 correction factor.
Im sure Bill will apply his magic.
Old 01-25-2014, 12:47 PM   #2895
swift996
swift996's Avatar
Based off your stock run your dyno might read about 4% lower than our US DynoJet.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
The Following User Says Thank You to swift996 For This Useful Post:
Ryan86 (01-25-2014)
Old 01-25-2014, 08:27 PM   #2896
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
HKS intake duct
AFE pro dry DIF
Borla UEL
63mm overpipe
Power differences are about what I would expect. Currently Ryan's car is the only one to have this tune. You are sort of my beta tester.
Ryan, I hate to say it is really picky when it comes to the tune and I love it. It really forces me to dial the tune. So I am working with Ryan to make sure the tune is ONLY better then the previous tune. Though the power numbers are what I would expect the low end light throttle from a dead sport have gone a little in the wrong direction. So I need to perfect this before releasing the tune to everyone else.
Thanks for the info Ryan.
Cheers,
William Knose
The Following 6 Users Say Thank You to DeliciousTuning For This Useful Post:
CK_Bladesmith (01-25-2014), Lawnik (01-25-2014), mikalem (01-25-2014), Ryan86 (01-25-2014), RyanITV (01-25-2014), shaunsweeney (01-25-2014)
Old 01-25-2014, 10:23 PM   #2897
xjohnx
Grip>Slip
xjohnx's Avatar
naaawce. I should be to a point where i can start datalogging and getting my intercooler tune tweaked. also considering a flex-fir...er..fuel kit. who do you guys recommend for hardware?
Old 01-26-2014, 06:25 AM   #2898
Calum
That Guy
Drives: 2013 asphalt FRS MT
Why not make your own? This was just a couple minutes of searching.
Harness to plug into the sensor, probably have to hack off the end you wont use.
http://www.gmpartsdirect.com/results...umber=13352241
Long tube sensor
http://www.gmpartsdirect.com/results...umber=13577394
Short tube sensor
http://www.gmpartsdirect.com/results...umber=13577379
Push on adapter
http://www.summitracing.com/int/part...4120/overview/
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
