Old 04-22-2013, 01:35 PM   #43
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Originally Posted by smbstyle View Post
Any update or writeup on how this brake duct kit performed? I'm looking to run some track pads (DTC-60's) with the stock rotors and calipers and am looking seriously at getting this cooling kit. I'm at Sebring about once a month if you need someone to test it under heavy stress conditions....
@ATL BRZ should have some feedback using this kit with PMU HC+ pads soon.
Touge Factory is offline   Reply With Quote
Old 04-22-2013, 02:46 PM   #44
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
soon....
The Following User Says Thank You to ATL BRZ For This Useful Post:
Touge Factory (04-22-2013)
Old 04-22-2013, 03:42 PM   #45
Touge Factory
Drives: ZN6
The white BRZ above had some fun here with the DBA rotors / Stoptech Lines / Ferodo DS1.1 pads and our cooling kit and on AD08's
Old 04-29-2013, 12:55 PM   #46
ATL BRZ
ATL BRZ's Avatar
I ran four full 25 minute sessions at Atlanta Motorsports Park last weekend with no incidents, car ran great, all the recent mods made it feel AWESOME! The TF Brake Cooling kit did its job and kept rotor temps under control all day (no, I didn't measure temps) based on the 9/10ths driving with the Project Mu pads I experienced zero fade and the front rotors look surprisingly good. Can't catch a fingernail on anything and they are wearing pretty even. The PMU HC+800 pads are great for hard track driving. They took a beating! The bite was excellent cold and hot; they did NOT fade ever!
Video footage: http://www.ft86club.com/forums/showp...4&postcount=56
Touge Factory (04-29-2013)
Old 12-29-2013, 04:44 PM   #47
iDerek
iDerek's Avatar
Drives: Subaru BRZ
Send a message via MSN to iDerek
@Touge Factory, will you ship to Canada?
An idea should be like a skirt, long enough to cover the details and short enough to keep everyone's attention.
iDerek is offline   Reply With Quote
Old 12-30-2013, 04:39 PM   #48
Touge Factory
Drives: ZN6
Absolutely!
We can ship worldwide.
Old 01-24-2014, 09:05 AM   #49
normancw
normancw's Avatar
Drives: 128i
Question Do these fit the AP Racing Sprint big brake kit?
@Touge Factory
Does the backing plate work with the AP Racing Sprint big brake kit?
normancw is offline   Reply With Quote
Old 01-24-2014, 03:59 PM   #50
diss7
Drives: AE86, 2x GT86, TE27
Originally Posted by normancw View Post
@Touge Factory
I don't think it will. However I'm not sure.
However I'd like to know if different backing plates will be made to suit different brake kits.
I'd also like to know if this would work with the ducts that come with the AP Endurance kit. I can seem to find an actual picture of the duct in the AP End. kit to determine that for myself.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
normancw (01-24-2014)
Old 01-24-2014, 04:13 PM   #51
normancw
normancw's Avatar
Drives: 128i
I just chatted with TF via the website and they said that they could make backing plates that would fit the AP Sprint brakes for an additional $40 (it would take about a week to ship).
Here's a pic of the AP Endurance bracket - not sure what duct size would fit.
http://www.essexparts.com/shop/compl...86-bundle.html
The Following User Says Thank You to normancw For This Useful Post:
diss7 (01-24-2014)
Old 01-24-2014, 05:51 PM   #52
Touge Factory
Drives: ZN6
I'd assume a standard high temp hose would work, however you will need to find the total circumference of that oval shape to get the correct size hose diameter.
We will be making the backing plates for Wilwood brakes soon, but if you guys need, get us the inner diameter of the rotor on the Ap kit.
The Following 3 Users Say Thank You to Touge Factory For This Useful Post:
diss7 (01-25-2014), normancw (01-24-2014), RehabJeff86 (02-02-2014)
Old 01-24-2014, 06:38 PM   #53
normancw
normancw's Avatar
Drives: 128i
Thanks! Here is the rotor AP Racing CP3862 rotor used in the AP Sprint kit. The diagram shows an inner diameter of 213.70 mm - I'll confirm when I receive the brake kit is the next week or so.
http://www.essexparts.com/media/down...62-104~5ga.pdf
http://www.essexparts.com/11-75-x1-2...ight-hand.html
Old 01-25-2014, 05:08 AM   #54
diss7
Thing is, if you've got a ap sprint kit, and sink $450 into a brake duct kit, you might as well have gotten the endurance kit.
normancw (01-25-2014)
Old 01-25-2014, 05:25 AM   #55
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I don't know if the weight saving is noticeable/significant but I'm thinking the Sprint Kit with ducting is still lighter than the Endurance Kit.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
Icanfaptothis86 (08-06-2015), normancw (01-25-2014)
Old 01-25-2014, 07:36 AM   #56
normancw
normancw's Avatar
Drives: 128i
This is true, the weight savings per wheel is 5lbs for Endurance vs 10lbs for Sprint. The list of supported rims for the Endurance kit is also smaller - I have RPF1 17x9 35 rims which aren't listed. Also, the cost of replacement rotors is $249 for Endurance vs $158 for Sprint.
However it is a good point though, if I didn't already have the rims, I might have chosen the Endurance kit.
Arrows Japan Brake Duct Cooling Kit & Suspension BPAuto Brakes, Suspension, Chassis 65 06-22-2013 09:35 AM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
Carbon Fiber Brake Cooling Duct JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 7 10-25-2012 12:03 AM
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
