Drives: Subaru BRZ Limited
Best/Preferred gauges for monitoring.
So just wondering, what are others using for gauges, and what are they monitoring. Currently using AEM failsafe for AFR and boost. Looking to add oil and cooling.
Brands, and what are you monitoring? Also, what are you all using to get the feeds to the gauges? |
#2 |
Thupercharged
p3cars vent gauge
Adding in an aftermarket wideband to the gauge aux input
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| The Following User Says Thank You to DJCarbine For This Useful Post: | ecko04 (01-24-2014) |
#3 |
Drives: Sterling BRZ Ltd
Innovate dual oil pressure/temp, TurboSmart eboost2, probably will get Innovate AFR
| The Following User Says Thank You to mrk1 For This Useful Post: | Sportsguy83 (01-24-2014) |
#4 |
Drives: 4-Runner Sport - 13' BRZ SportTech
Aem fail safe and innovate mtx oil temp and pressure ... 2 gauges, 4 important readings
Top Tier Imports - Check out my build journal HERE
| The Following 3 Users Say Thank You to protpibe For This Useful Post: |
#5 |
Where and how are you guys getting the oil temp and pressure.
#6 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Just Greddy Multi D/A boost gauge at the moment, I will add a few more sensors later on to the gauge (Oil temp)
#7 |
I put the pressure sensor in place of the stock oil pressure switch, and the temp probe in another spot on top of the block. You need a fitting from Subaru they call an oil gallery plug which has a 1/8 PT thread. Or you could use a sandwich plate with fittings. I am using the Greedy Multi D/A as well with four sensors hooked up. It will monitor/alarm on three at one time. |
| The Following User Says Thank You to xwd For This Useful Post: | misooscar (06-09-2014) |
#8 |
Living the dream
Drives: Fensport AVO Turbo GT86
As he said, I have the same, still need to fit the Innovate gauge, though.
#9 | |
Seems Legit
Drives: Toyota
This! P3Cars vent gauge for oil temp, coolant temp, boost & vacuum. Innovate LC-2 wideband wired to aux 1 of the P3Cars gauge for AFR. AEM oil pressure sensor wired to aux 2 for oil pressure. Over boost protection programmed into the tune.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#10 |
Seems Legit
Drives: Toyota
https://www.subarugenuineparts.com/p...roducts_id=961 Right beside the throttle body there is a hex plug. Unscrew it, screw in the galley, screw in your sensor and wire it. http://www.ft86club.com/forums/showp...95&postcount=8
| The Following 5 Users Say Thank You to ecko04 For This Useful Post: | Bramick (11-23-2014), GT86_PRAGUE (10-26-2015), SirBrass (02-25-2014), that_guy (01-26-2014), TIE Pilot (01-24-2014) |
#11 |
The PLX gauge can be anything you want. You just buy whatever module you need for any particular function. The gauge itself can scroll through a bunch of different functions.
http://www.plxdevices.com/ |
#12 | |
I Love custom Turbo kits
Drives: Limited BRZ
I have Robispec sandwich plate and it has two ports for each pressure and temp. Like dwx said, you can tee into the stock oil pressure sensor (use aluminum fitting brass can break too easily) and the port on top of the block for oil temp http://www.fastwrx.com/oilgalleryplug.html
#13 | |
Living the dream
Thanks, Dave |
#14 | ||
Drives: Limited BRZ
| S> Unichip + Download Cable ($300), Socal Preferred | l0aded | Engine, Exhaust, Bolt-Ons | 1 | 01-05-2014 06:17 PM |
| Gauges - The best in monitoring devices! | Rev Works | Interior Parts (Incl. Lighting) | 1 | 07-28-2013 09:28 AM |
| WTB: 2x Stock FRS/BRZ wheels (with tires preferred) LA area | retrosmiths | Wheels and Tires | 1 | 07-18-2013 04:21 AM |
| Tyre Pressure Monitoring Systems | Fish Eagle | AFRICA | 3 | 07-14-2013 04:52 PM |
| New Tire Pressure Monitoring Sensors? | Kochinopride | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 04-14-2013 08:51 PM |
