Old 01-23-2014, 09:03 PM   #1
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Best/Preferred gauges for monitoring.
So just wondering, what are others using for gauges, and what are they monitoring. Currently using AEM failsafe for AFR and boost. Looking to add oil and cooling.
Brands, and what are you monitoring? Also, what are you all using to get the feeds to the gauges?
gdrider77 is offline   Reply With Quote
Old 01-23-2014, 09:07 PM   #2
DJCarbine
Thupercharged
DJCarbine's Avatar
p3cars vent gauge
Adding in an aftermarket wideband to the gauge aux input
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
ecko04 (01-24-2014)
Old 01-23-2014, 09:22 PM   #3
mrk1
Drives: Sterling BRZ Ltd
Innovate dual oil pressure/temp, TurboSmart eboost2, probably will get Innovate AFR
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Sportsguy83 (01-24-2014)
Old 01-23-2014, 10:21 PM   #4
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
Aem fail safe and innovate mtx oil temp and pressure ... 2 gauges, 4 important readings
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following 3 Users Say Thank You to protpibe For This Useful Post:
Creole (06-04-2014), Freeman (05-14-2014), Sportsguy83 (01-24-2014)
Old 01-23-2014, 10:37 PM   #5
gdrider77
gdrider77's Avatar
Where and how are you guys getting the oil temp and pressure.
Old 01-23-2014, 11:38 PM   #6
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Just Greddy Multi D/A boost gauge at the moment, I will add a few more sensors later on to the gauge (Oil temp)
Build Thread
Instagram
Old 01-24-2014, 03:28 AM   #7
xwd
I put the pressure sensor in place of the stock oil pressure switch, and the temp probe in another spot on top of the block. You need a fitting from Subaru they call an oil gallery plug which has a 1/8 PT thread. Or you could use a sandwich plate with fittings. I am using the Greedy Multi D/A as well with four sensors hooked up. It will monitor/alarm on three at one time.
The Following User Says Thank You to xwd For This Useful Post:
misooscar (06-09-2014)
Old 01-24-2014, 04:36 AM   #8
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
As he said, I have the same, still need to fit the Innovate gauge, though.
Pitman is offline   Reply With Quote
Old 01-24-2014, 06:30 AM   #9
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by DJCarbine View Post
p3cars vent gauge
This!
P3Cars vent gauge for oil temp, coolant temp, boost & vacuum. Innovate LC-2 wideband wired to aux 1 of the P3Cars gauge for AFR. AEM oil pressure sensor wired to aux 2 for oil pressure. Over boost protection programmed into the tune.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 01-24-2014, 06:37 AM   #10
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
https://www.subarugenuineparts.com/p...roducts_id=961
Right beside the throttle body there is a hex plug. Unscrew it, screw in the galley, screw in your sensor and wire it.
http://www.ft86club.com/forums/showp...95&postcount=8
The Following 5 Users Say Thank You to ecko04 For This Useful Post:
Bramick (11-23-2014), GT86_PRAGUE (10-26-2015), SirBrass (02-25-2014), that_guy (01-26-2014), TIE Pilot (01-24-2014)
Old 01-24-2014, 07:16 AM   #11
mike the snake
The PLX gauge can be anything you want. You just buy whatever module you need for any particular function. The gauge itself can scroll through a bunch of different functions.
http://www.plxdevices.com/
Old 01-24-2014, 07:44 AM   #12
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I have this same combo. Two gauges giving 4 outputs
I have Robispec sandwich plate and it has two ports for each pressure and temp. Like dwx said, you can tee into the stock oil pressure sensor (use aluminum fitting brass can break too easily) and the port on top of the block for oil temp
http://www.fastwrx.com/oilgalleryplug.html
Old 01-24-2014, 07:48 AM   #13
Pitman
Living the dream
Pitman's Avatar
Any chance of you posting up some pictures of your connections?
Thanks,
Dave
Old 01-24-2014, 08:13 AM   #14
Sportsguy83
Drives: Limited BRZ
Thanks,
Dave
The block port that me and @dwx speak of for the Oil Temp is right on the side of the AC compressor.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
jcw99 (01-06-2015), Pitman (01-24-2014), SirBrass (02-25-2014)
S> Unichip + Download Cable ($300), Socal Preferred l0aded Engine, Exhaust, Bolt-Ons 1 01-05-2014 06:17 PM
Gauges - The best in monitoring devices! Rev Works Interior Parts (Incl. Lighting) 1 07-28-2013 09:28 AM
WTB: 2x Stock FRS/BRZ wheels (with tires preferred) LA area retrosmiths Wheels and Tires 1 07-18-2013 04:21 AM
Tyre Pressure Monitoring Systems Fish Eagle AFRICA 3 07-14-2013 04:52 PM
New Tire Pressure Monitoring Sensors? Kochinopride Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 04-14-2013 08:51 PM
