Old 01-20-2014, 08:20 PM   #127
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Luckrider View Post
I was just wondering if the intake/exhaust advance was to account for the header.
I'm on my 3rd tank of e85 and with my log with the longest time before flashing (probably 300 miles) had the highest ltft down to .74%
http://www.datazap.me/u/luckrider/e8...og=0&data=1-11
Edit: There is a 3rd gear pull from 1500rpm at ~1500s on that log.
A section of your previous log (which had more driving/learning time):
Notice how your LTFT under load dropped to -7.03% to account for the lower ethanol content in your fuel. Expect to see the same behavior with the new map (or after every new flash) after some more driving/learning time. Right after your flash, LTFTs will be 0.0%. As you drive more, they will start to move in the direction you need them to move in order to achieved the desired AFR under load
Shiv@Openflash is offline   Reply With Quote
Old 01-20-2014, 08:38 PM   #128
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
So the -% in LTFTs helps lean out the car a tad to accommodate for the higher dino content of the fuel? I am not upset at all that my station is pumping low E since it is terribly cold here. My car starts right up without messing with the IPW. Vra vra vree VROOM! is all that it takes every single time.
Luckrider is offline   Reply With Quote
Old 01-20-2014, 08:44 PM   #129
Shiv@Openflash
Drives: 2013 FRS
Exactly
I agree. Having a lower E content is great for the reason you mentioned. Plus, it's overkill to run E85 on an NA FA20. It will get all the cooling/octane it needs to make max power at somewhere around E60.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Luckrider (01-20-2014)
Old 01-20-2014, 08:52 PM   #130
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Originally Posted by RSH View Post
Just the opposite for me. I have an EL and axleback and it sounds much quieter to me.
I am loving it though, throttle response is incredibly smooth and seems very uniform throughout the range. Much, much better than any previous release IMHO.
When I went from stock to 1.34 I noticed a marked decrease in drone and overall volume. Love it. I'm stock aside from a track pipe. Hope my drone doesn't come back when I can finally run 1.5 haha
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-20-2014, 09:28 PM   #131
steve99
Drives: FT86
1.52 dev tune not working for ZA1JA01G ROM type
OFT v1.51 maps will support the following Australian Market ROMs by tomorrow afternoon:
ZA1JA00G - 2012 EU Manual High FD
ZA1JA01G - 2012 EU Manual High FD
ZA1JA01I - 2012 EU Auto
Cheers,
shiv
Hi Shiv,
Erased tune files from OFT (except stock rom)
Loaded 1.52B dev database synced ok on OFM
I am on ZA1JA01G rom type (AU BRZ Sept 2013)
go to car but "write" greyed out
I currently have 1.42B stage 1 flashed to car do I need to flash back to stock before using 1.52B dev tunes ??
or something not correct in dev file for A01G roms ?
Thanks
Old 01-20-2014, 09:30 PM   #132
Shiv@Openflash
Drives: 2013 FRS
Hi Shiv,
I am on ZA1JA01G rom type (AU BRZ Sept 2014)
Thanks
Email me (shiv@vishnutuning.com) your original ROM. It's probably different from the original A01G rom that is in the database. Which is why it's not recognizing your ROM type. Have you had your ECU flashed before by another other tuning device?
-shiv
steve99 (01-20-2014)
Old 01-20-2014, 09:36 PM   #133
steve99
Drives: FT86
-shiv
Hi Shiv will email my ROM to you
I have not used any other tuning device other than OFT
Thanks for reply
Old 01-20-2014, 09:37 PM   #134
Shiv@Openflash
Drives: 2013 FRS
Thanks for reply
Great. I'll add your ROM to the database later tonight and post up a new .dev file
It's possible that the A01G in the database isn't perfectly stock. Since you are sure yours is, I'll replace it with your file.
Old 01-20-2014, 09:40 PM   #135
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
@shiv My CAL ID shows as ZA1JA01C but isn't letting me use the dev tunes. I think my original rom is just a ecutek stock rom.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-20-2014, 09:49 PM   #136
Shiv@Openflash
Drives: 2013 FRS
That's the problem. It's not actually a stock ROM. Email it to me please.
Old 01-20-2014, 09:55 PM   #137
Apoc
Apoc's Avatar
just sent
“The World is Flat”
[||•]=(86)=[•||]
Old 01-20-2014, 11:02 PM   #138
Cross
It's the Mad Cow
Cross's Avatar
Hey Shiv I have a question and possible suggestion.
Where can we check which dev version our OFT has from the OFT itself?
I ask this because earlier I loaded the 1.50 and you updated twice today (Thank you for the hard work) and there was apparently an update at version 1.51 that could effect me so I wanted to be sure I had the latest updates.
The Device does say which flash was recently flashed but not the version of the flash. It also showed an asterisk next to the E85 UEL as thats what I was using. I went ahead and flashed it again just to be sure since I deleted and then loaded the 1.52 Beta Dev.
I wasn't sure if I just overlooked it or if this was something we could have in the future to help avoid confusion for those using this new format of .Dev Beta releases.
Also I will keep testing it but to me it did feel even smoother down low but it seems to have lost some up top... I will be doing some logging over this week to see the differences between the 1.5x and 1.42 I was running before it with my Cranking tables.
My cold start issues are back obviously since I cannot make the changes I did before with the help of others here on the boards.
Old 01-20-2014, 11:25 PM   #139
Malt
Drives: 2015 WRX
Just to avoid any confusion, I've noticed that OFT just remembers what slot you flashed, not which map. If you flash slot 5 and then delete the maps on the OFT and put then in a different order it might confuse you as to which map you currently have on your ecu.
I found this out after I swapped back to a gas map but moved the e85 map I was using to a different slot.
Malt is offline   Reply With Quote
The Following 3 Users Say Thank You to Malt For This Useful Post:
Cross (01-20-2014), garfull (01-21-2014), Shiv@Openflash (01-20-2014)
Old 01-21-2014, 12:33 AM   #140
Shiv@Openflash
Drives: 2013 FRS
Here is your ecutek "stock" ROM compared to an actual stock ROM:
You can see some non-stock data where there should be FFs. This also changes the checksum data at the end of the ROM (not shown).
Until we come up with a way to flash non-stock and old ROMs to new stock ROM status, I've added your ecutek "Stock" rom to the database so it should work for you now.
soooo.....now v1.53 is released
v1.53b Changes:
-Replaced the stock A01G and A01D ROMs in the database with actual stock ROMs.
-Added a “stock” Ecutek ROM to the database.
If anyone else with one of the supported ROM types doesn't get tuned map file generation, please email me your original ROM so I can compare it to the counterpart in our map database. If they aren't 100% identical, tuned map files will not be generated. I will have to add your original ROM to the database.
Cheers
shiv
Apoc (01-21-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
OpenFlash Tablet: OFT 3-Touch Programming with Preloaded Tune File Database Shiv@Openflash Software Tuning 154 12-12-2015 03:26 PM
OpenFlash Tablet E85 (and gasoline) Maps now available Shiv@Openflash Software Tuning 401 08-13-2014 11:14 PM
OpenFlash Tablet: new v1.40b maps, new website, new sales, oh my Shiv@Openflash Software Tuning 122 12-14-2013 10:17 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
