Old 01-20-2014, 02:45 PM   #15
jamesm
Originally Posted by Malt View Post
Give it a year and I'll bet another pretty penny that OFT will suit the needs of that other 10% as well.
I surely hope so, but being in the software dev business i can assure you there's a whooooooole lotta work to be done to make it as flexible as RaceRom. Sure you may see SD and Boost Cut come into play, but I doubt you'll be able to define your own routines any time soon. It's really easy to accommodate one use case, it's extremely difficult to create a tool that allows any user to accommodate any use case.
Now please prove me wrong .
The Following 2 Users Say Thank You to jamesm For This Useful Post:
Cerbrian (09-16-2017), wparsons (01-20-2014)
Old 01-20-2014, 04:16 PM   #16
1stGenBRZ86
1stGenBRZ86's Avatar
Maybe speed density is not needed at the moment on this platform, but it for sure will be after all the "kit based" turbo hype is over. The only true way to make power on most efi imports is by eliminating the maf and using map and iat. Its relevant to custom kit builders because they are more than likely not looking for an off the shelf base map.
Btw, dont take this as a rant for one company or another. I am all for competition because it will bring the best options for the end user.
1stGenBRZ86 is offline   Reply With Quote
Old 01-20-2014, 04:29 PM   #17
Malt
Drives: 2015 WRX
There's a thread in this very section discussing this with a differing opinion than yours. Could you explain why you think speed density is a requirement for turbo applications?
EDIT: I can't find that thread right now. I suspect it fell victim to a moderator delete during the great ecutek/visconti flame fest of '13.
Malt is offline   Reply With Quote
The Following User Says Thank You to Malt For This Useful Post:
Luckrider (01-20-2014)
Old 01-20-2014, 06:00 PM   #18
xDanger_208x
xDanger_208x's Avatar
Drives:
Thanks op for asking the question I had rattling around in my head ;-)
Does the OFT offer flat foot shifting and launch control?
If so... I just might be a very near future customer.
xDanger_208x is offline   Reply With Quote
Old 01-20-2014, 06:01 PM   #19
Malt
Drives: 2015 WRX
Yes and yes
xDanger_208x (01-20-2014)
Old 01-20-2014, 06:02 PM   #20
xDanger_208x
Drives:
Yes and yes
Is it easily adjustable?
Old 01-20-2014, 06:09 PM   #21
Malt
Drives: 2015 WRX
Launch control adjustment requires you to modify a single field on the bin file, which is fairly easy. This current map release is on dev format which is not adjustable but the maps will be released in bin format once they are out of beta. Shiv noted that all future beta releases will follow this format so there will be a short delay period where the new maps will not be adjustable.
Old 01-20-2014, 06:10 PM   #22
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yes, you can adjust it in the user tuning software (RomRaider):
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Cross (01-22-2014)
Old 01-20-2014, 08:28 PM   #23
1stGenBRZ86
Because in an na to turbo conversion, you will most likely want blow through for driveability. This presents the problem of having the sensor prematurely failing from too much boost (usually over 15 psi). I know many nissan guys that have to deal with this (mafs physically blowing off or randomly failing). On the other hand, pull through setups (like factory turbo cars) generally lead to cars stalling out. I suppose a good tuner can fix these issues, but speed density becomes easier with big boost, especially for end users.
Old 01-20-2014, 08:36 PM   #24
Malt
Drives: 2015 WRX
I really wish the thread that shiv participated in wasn't deleted because he put it way more eloquently than I can but his assertion was that MAF works just fine for boosted applications, it's just that tuners are used to tuning with MAP so that's what they do.
Old 01-20-2014, 08:41 PM   #25
Shiv@Openflash
Drives: 2013 FRS
Almost every OEM turbo car (GTR, Porsche, Mazda, Subaru, Toyota, etc,.) uses a draw through MAF configuration. Compared to Speed Density approach, MAF just does the best job at actually measuring airflow. Most aftermarket "tuner" turbo kits suggest SD conversion because this allow them to simplify hardware and dump blow-off valve discharge to the atmosphere instead of re-routing it back to the intake tract (post MAF). Running a draw-through MAF configuration with BOV dumped to atmosphere will cause all sorts of drivability issues (stalling, partial throttle lumpiness, etc,.) But that is more a reflection of the turbo system hardware, not the tuning side of things. My suggestion is to have a turbo kit that is designed properly and then pick the best tuning approach from that point onwards. Not pick a turbo kit that isn't fully resolved and then pick the only tuning approach that has any chance of making it work well.
My 2c,
Shiv
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
Blokatos (04-30-2016), normancw (01-21-2014)
Old 01-20-2014, 09:56 PM   #26
jamesm
you will run out of maf around 350ish whp, or atleast the cars i've tuned ran out around there (one actually a bit lower). so, if you're on pump gas you probably won't need it. if you're running a larger turbo or e85, you will. the alternative is to install a larger maf housing, but that may not work well depending on your hardware configuration, and won't get you around the load limit anyway (which may matter at that level). so theoretically you could keep installing larger maf tubes until you hit 4g/rev, then you're done.
i generally prefer to run a hybrid setup, with maf on the low end and sd up top. it's the best-of-both-worlds way to go, imho.
Cross (01-22-2014), Fast_Freddy (01-23-2014)
Old 01-21-2014, 08:58 PM   #27
JuniorAWD
Drives: GTR 9.0@170_XT 10.8@130_GC 8.3@165
Exactly what I do with my flex/e85/Big turbo cars. Cars drive great, and can deliver power until you max out the fuel system, engine, trans ect.
IMO OFT is basically free software that comes with a tablet, " no lab-top needed" but you are paying for free software, because you have to buy the tablet from them... Why not just use the free stuff on your existing labtop?
You can buy the ECUTEK end user Cable/License and do the same thing, but have software that has been evolving for 2yrs and comes backed by guys who have pioneered the tuning side of the FA platform for just as long. That alone makes it worth while.
JuniorAWD is offline   Reply With Quote
The Following 2 Users Say Thank You to JuniorAWD For This Useful Post:
Fast_Freddy (01-23-2014), Proof (01-21-2014)
Old 01-21-2014, 09:16 PM   #28
Shiv@Openflash
Drives: 2013 FRS
As an tuner yourself, you should talk with customers who have owned both tuning options and get a better handle on what most people find valuable, necessary and unimportant. As tuners, many of us tend to put excessive value in things that most people either don't care about or will never benefit from (SD conversion for instance). Likewise, we also tend to devalue things that many typical customers truly appreciate on a day to day basis (handheld convenience, not having to muck with comm ports or software licenses, stability, diagnostic simplicity, free tunes, a large open community and the ability to resell without losing $$ etc,.). At the end of the day, everyone has different priorities. And it's probably not a good idea to project one's own needs to that of others/your customers. After 15yrs of being in the tuning business, I finally learned this lesson. Just recently, in fact
The Following 7 Users Say Thank You to Shiv@Openflash For This Useful Post:
djdnz (01-23-2014), JS + BRZ (01-24-2014), mwjcyber (09-26-2014), normancw (01-21-2014), shaunsweeney (01-24-2014), skye67 (01-26-2014), Strife26 (12-05-2017)
#fanboysthread, oftsupportgroup, unichip ftw
ECUTek question ATSAaron Engine, Exhaust, Transmission 12 04-03-2014 06:37 PM
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 12:35 PM
I need help on which ecutek I should get, stg 1 or 2 Frsexxxy Engine, Exhaust, Transmission 22 03-29-2013 10:45 PM
Which should I get ecutek stg 1 or stg 2? Frsexxxy Engine, Exhaust, Transmission 5 03-21-2013 01:10 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 09:34 PM
