Old 01-19-2014, 08:03 PM   #71
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Reviving an old thread. Installed my pod FINALLY yesterday.
I f*cked up installing the gauges, because I measured angle with the pod outside the vent, so when I actually installed sit the pod in the vent they were already tapped and the are sitting at a nice angle.. LOL
I'll post pics of them installed and on this coming week.
Still running the same 2 gauges? Failsafe and oilpress/temp?
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Sportsguy83 (01-19-2014)
Old 01-19-2014, 08:04 PM   #72
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
Yea he is.
xDBOYx is offline   Reply With Quote
The Following User Says Thank You to xDBOYx For This Useful Post:
Old 01-20-2014, 11:46 AM   #73
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Originally Posted by bgibbsunc View Post
I use the AEM failsafe for wideband and boost. I also use the Innovate MTX-D for oil temp/pressure.
Where are you routing the sensor wiring to the cabin... Through firewall?
rb6freak is offline   Reply With Quote
Old 01-21-2014, 12:03 AM   #74
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@xDBOYx @SmsAlSuwaidi here are some pics of my crooked pod
The Following User Says Thank You to Sportsguy83 For This Useful Post:
ftc~brz (01-22-2014)
Old 01-21-2014, 12:38 PM   #75
xDBOYx
xDBOYx's Avatar
I dont see what u did wrong. But it looks good and the gauges match up during the day. Not bad.
Any tips for install mine is on the way.
Sportsguy83 (01-21-2014)
Old 01-21-2014, 01:16 PM   #76
Sportsguy83
Drives: Limited BRZ
I needed to enlarge the hole for the cables in the pod because the Failsafe and the Innovate both include a fair amount of cables and thick to boot (thats what she said).
Set the pod in place and test fit the gauges so you know the correct angle to set them (there is a strip of double sided tape that will hold them in whatever palce you initially set them to).
I had an issue with the Innovate gauge (in this pod and other pod so the problem is the gauge) that it is smaller than 52 mm. To fix it, put a few mm of black tape around it and it will fit snug.
The actual vent needs to be cut in order to route the cables (not a big deal and you will understand once you take the vent cover and look).
I think thats it.
Old 01-21-2014, 02:41 PM   #77
xDBOYx
xDBOYx's Avatar
I think thats it.
Awesome. How much bigger did u have to make the hole? How much of vent did you have to cut? Innovate market these as 52mm wierd that their smaller.
Old 01-21-2014, 03:00 PM   #78
Sportsguy83
Drives: Limited BRZ
It would be a bit of trial and error but I enlarged it as far as I could go without breaking it. The vent you will see right away the side pointing to the cluster needs to be cut. I also cut a portion on the bottom of the pod to not need to cut the vent too deep down.
I agree on the gauge, don't know if mine was manufactured bad or what, but I needed foam tape to make it stay still on the other pod and black electric tape on this one.
Old 01-21-2014, 03:08 PM   #79
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
I have a similar setup, except I went with the ATI vent pod for the Innovate and then the Block8head for AEM Failsafe. I'm just waiting for the blockhead mount to arrive
How does it look with the silver rings instead of black rings on the gauges? I was torn on that one because of the stock silver trim
protpibe is offline   Reply With Quote
Old 01-21-2014, 03:14 PM   #80
xDBOYx
xDBOYx's Avatar
Sounds good when can we expect some night shots? Ill post mine when it comes.
Old 01-21-2014, 03:15 PM   #81
Sportsguy83
Drives: Limited BRZ
Car should be up and running in the weekend all fingers crossed....
Old 01-21-2014, 03:17 PM   #82
xDBOYx
xDBOYx's Avatar
Gonna update your build journal? I need to make one when I have something more worthy then wheels and suspension mod to post about.
Old 01-21-2014, 03:19 PM   #83
Sportsguy83
Drives: Limited BRZ
I'm considering starting a new one and just referencing the old one... As it is right now its just a big mess.
Old 01-21-2014, 03:27 PM   #84
xDBOYx
xDBOYx's Avatar
Haha I hear ya. Keep me posted. Cant wait to see the new beast.
AEM Wideband Failsafe Gauge Pitman Forced Induction 51 08-14-2016 11:06 AM
LC-1 wideband 02 sensor MattF Engine, Exhaust, Bolt-Ons 4 11-05-2013 09:52 PM
Innovate LC1 wideband choi0706 Engine, Exhaust, Bolt-Ons 0 08-27-2013 11:29 PM
Wideband LC-1 wiring. MattF Forced Induction 9 07-09-2013 09:33 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
