Old 07-06-2013, 11:47 PM   #1
MattF
MattF's Avatar
Drives: s13<EP3<s14<RSX TYPE-S<WRX<GTI<FR-S
Wideband LC-1 wiring.
Has anyone installed an innovate lc-1 wideband? I know there is a way to replace the stock wideband and then wire the serial out on the lc-1 to the factory harness. I would like to avoid welding another bung into the header.
My main question is has anyone done this yet or does anyone have a wiring diagram for it? I would assume this is what innovate motorsports did with there car. Any input would be greatly appreciated trying to get my car prepped for my supercharger install next weekend.
MattF is offline   Reply With Quote
Old 07-07-2013, 12:16 AM   #2
mrk1
Drives: Sterling BRZ Ltd
I'm looking into this as well, personally I'm going the route of welding in a second bung. I don't like to splice into factory wires if I don't have too.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-07-2013, 08:37 AM   #3
MattF
MattF's Avatar
I was going to go that route originally as well but I just dont see were you could weld another bung in before the cat.
Old 07-07-2013, 09:05 AM   #4
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Yes, I had a shop weld in another bung on my front pipe.
F1point4 is offline   Reply With Quote
Old 07-08-2013, 11:56 AM   #5
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
As far as I am aware, there is not a way to do that. The analog out signal on the LC-1 will not perfectly match the signal from the OEM sensor. As others have mentioned the easiest solution is just to weld another bung in or go with an aftermarket header with an extra bung already welded in.
Old 07-08-2013, 12:09 PM   #6
MattF
MattF's Avatar
I am getting another bung welded in today. I am planning on going with the nameless header when it is released.
Old 07-08-2013, 02:52 PM   #7
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
The innovate car does not have the analog output interfacing with the factory ECU. You will want to go the additional bung route for best results.
mines13 is offline   Reply With Quote
Old 07-09-2013, 07:50 AM   #8
mad_sb
Drives: 2013 Asphalt FR-S
... I know there is a way to replace the stock wideband and then wire the serial out on the lc-1 to the factory harness..
As far as i am aware, This won't work with our cars because the factory primary sensor is a wide range sensor and does not have the same output type as a typical narrow-band sensor. Narrow-bands can easily be replaced by an LC-1 using the narrow-band output function.
Maybe call innovate directly to confirm
Old 07-09-2013, 08:03 AM   #9
ft_sjo
Drives: GT86
Whoa there boys. The answer is categorically no (without serious work).
The issue isn't about linearisation of the sensor. The output of the LC-1 is an analogue voltage. The output of the sensor into the ECU is not. Oxygen sensors are current devices and require a controller/amplifier to read them. The ECU already has one built-in for the OE sensor.
Now it's _technically_ possible. You could bypass the controller in the ECU, splice into the analogue output before it goes into a processor/adc. You'd have to also know what the OE linearisation curve looks like. Good luck!
Old 07-09-2013, 09:33 AM   #10
MattF
MattF's Avatar
I have already had a bung welded into the header pre-cat.
Sent from my SCH-I605 using Tapatalk 2
AEM Failsafe wideband gauge. skatery1989 Interior Parts (Incl. Lighting) 2 04-14-2013 09:12 AM
AEM Truboost and UEGO Wideband Gauges F/S Supermassive Engine, Exhaust, Bolt-Ons 1 01-20-2013 05:35 AM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
