Old 01-19-2014, 06:27 PM   #2731
wrxgoose
WUB WUB
Drives: 2013 Firestorm
Originally Posted by brianhj View Post
mods? gas?
so it's nearly head to head with JR SC?
93 octane, borla uel headers, perrin 2.5" header back, tune, clutch, injectors. smaller SC belt so i can stop breaking them.
wrxgoose is offline   Reply With Quote
The Following User Says Thank You to wrxgoose For This Useful Post:
brianhj (01-20-2014)
Old 01-19-2014, 06:28 PM   #2732
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by stockysnail View Post
I have some questions that I'm not really finding anywhere related to the Innovate since I just got one.
1. I hear replacing the plastic inlet tube will increase the loudness of the supercharger whine. Does anyone know where I can buy one? I know I can have the local shop make one up but they estimated $200-$300. I want to hear the supercharger scream!
2. Has anyone tried a short ram type intake? Would this reduce lag or would the benefit of the filter straight off the supercharger be negated by the hotter air being pulled in from the engine?
We made an aluminum "warm air" intake that sits with a massive 3" filter right where the stock airbox was. We did not need to remove timing from the tune, and it felt like it picked up a few HP. Having the big opening for the blower to pull through is not such a bad thing, and given the small opening of the stock inlet, doing a proper cold air intake will not be as simple as sticking a kinked pipe through there.
Oh yeah, the whine with the 70mm pulley and an open intake is GLORIOUS. Add an UEL header to the mix (we run JDL) and a free flowing exhaust and the thing sounds like nothing else on the road.
Xero-Limit is offline   Reply With Quote
Old 01-19-2014, 06:40 PM   #2733
wrxgoose
WUB WUB
vid maybe? i'd love to know what i'm in for when i get this aluminum intake made.
Old 01-19-2014, 06:47 PM   #2734
phloozy
phloozy's Avatar
Drives: Scion FR-S
Heard it in person, it sounds amazing. I want it so bad, now that the new shop is up think you could fabricate another?
phloozy is offline   Reply With Quote
Old 01-19-2014, 09:15 PM   #2735
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
3. From what I've read it's highly recommended to get a dual catch can setup to help protect all the parts. Is this true? I want my parts to go the distance.
4. I'm getting some lag occasionally around 1.5k-2k. I've read this is a result of needing the tune to be fixed. Is this still the case?
5. Any other minor things I can do for this kit to make it better? Not counting the intercooler, meth, or e85.
1)As Swift said, the Perrin makes the blower louder and bolts right up.
3) ABSOLUTELY get catch cans. We had the blower off on @xjohnx's car and the manifold had a nice oil sheen. I'm not sure how many miles are on it, but catch cans are a must.
Originally Posted by xxscaxx View Post
I didn't see this and you are probably working on it already lol...but i did it without taking the manifold off. I'd suggest taking the back elbow part off first though. use long Allen key sockets with the balls on the end so you can get it on an angle.
Everything else is pretty simple, I had a bitch of a time getting the retaining clips back on, a few bolts of mine came off tight and i think thats why, its a REAL tight fit with the clips back in, so you might have to wiggle/pull the charger around to get the retaining clips in and bolted down.
also, grease up the o ring strips to keep them in place when putting the charger back on. Everything else is pretty simple, minus getting the air out of the system when filling it with coolant.
Its going to take the required amount of coolant so make sure you check how much you have put in. If i would have stopped without knowing the amount that its suppose to take I would have no coolant in there right now haha. Also, the water pump will be quiet once the air is all out. You will know the difference when you hear it.
Thanks for the tips. We ran out of daylight and had to call it quits before finishing, so we'll definitely use your suggestions tomorrow.
Sent from my Nexus 4 using Tapatalk 2
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 01-19-2014, 11:23 PM   #2736
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Yeah. It's not a great picture but you can kinda see the oil pooling around the plastic fittings. The whole elbow has a nice oil coating. This was right before I installed my catch can.
[IMG][/IMG]
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 01-19-2014, 11:25 PM   #2737
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Pics of catch can location on your setup?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-20-2014, 12:33 AM   #2738
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
@stockysnail & @wrxgoose
Im also having a jerky, hestitation very low down under 3000rpm.
who are your tuners? I mailed mine this morning to advise of this.
Ryan86 is offline   Reply With Quote
Old 01-20-2014, 12:46 AM   #2739
wrxgoose
WUB WUB
i'm using @JuniorAWD, and hopefully i can get in to see him when he goes to Shift Fast later this month.
Old 01-20-2014, 12:59 AM   #2740
stockysnail
Just the tip
stockysnail's Avatar
Originally Posted by swift996 View Post
Adding the Perrin intake made mine whine louder.
I already have the Perrin intake. I talked with Jason at Nameless Performance and he said they have a few metal tubes to replace the plastic ones. That should help make the supercharger whine more.
The Following User Says Thank You to stockysnail For This Useful Post:
swift996 (01-20-2014)
Old 01-20-2014, 01:05 AM   #2741
stockysnail
Just the tip
Originally Posted by Calum View Post
Why are you driving in the 1500-2000rpm range? With the extra parasitic drag of the supercharger I can't see that being benifical.
Because I get better gas mileage running at lower RPMs. 6th gear going 40-50 was getting me 38mpg. I don't drive that speed constantly anymore on my commute however so it doesn't matter now. I guess I should just saw screw it and go balls deep. WOT FTW!
Old 01-20-2014, 08:14 AM   #2742
xxscaxx
Drives: 2013 SWP BRZ
I experienced the same thing as well when I pulled my charger off to install the intercooler. Will be installing a catch can soon, want to try and wait for the radium specific kit for the twins though.
xxscaxx is offline   Reply With Quote
Old 01-20-2014, 09:10 AM   #2743
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm not saying to go WOT all the time, but there can be a compromise between the ultimate gas milage and potentially doing damage to your engine from lugging it.
The Following User Says Thank You to Calum For This Useful Post:
civicdrivr (01-20-2014)
Old 01-20-2014, 11:38 AM   #2744
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
Do you have plans to run e85? Also how loud is your setup with the uel and full exhaust?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
