#2717 |
Drives:
#2718 |
Grip>Slip
installing the intercooler tomorrow morning. so stoked. any last minute tips? i'm going to try doing it without removing the manifold if possible.
#2719 |
That Guy
Drives: 2013 asphalt FRS MT
Well, your still higher than anyone else with your setup. I'd say you're doing well.
#2720 |
WUB WUB
Drives: 2013 Firestorm
this is uncorrected (40ish degrees out)
| The Following 5 Users Say Thank You to wrxgoose For This Useful Post: | Alabang 86 (02-06-2014), brianhj (01-19-2014), Calum (01-19-2014), normancw (01-19-2014), whataboutbob (01-19-2014) |
#2721 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
Very nice well done
What's your gain compared to non IC? Did you manage to check boost? |
#2722 |
WUB WUB
no, not yet. i'm going to see if my friend will come down and help me install the boost gauge tomorrow.
#2723 |
Just the tip
I have some questions that I'm not really finding anywhere related to the Innovate since I just got one.
1. I hear replacing the plastic inlet tube will increase the loudness of the supercharger whine. Does anyone know where I can buy one? I know I can have the local shop make one up but they estimated $200-$300. I want to hear the supercharger scream! ![]() 2. Has anyone tried a short ram type intake? Would this reduce lag or would the benefit of the filter straight off the supercharger be negated by the hotter air being pulled in from the engine? 3. From what I've read it's highly recommended to get a dual catch can setup to help protect all the parts. Is this true? I want my parts to go the distance. 4. I'm getting some lag occasionally around 1.5k-2k. I've read this is a result of needing the tune to be fixed. Is this still the case? 5. Any other minor things I can do for this kit to make it better? Not counting the intercooler, meth, or e85.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#2724 | |
Drives: 2013 SWP BRZ
Everything else is pretty simple, I had a bitch of a time getting the retaining clips back on, a few bolts of mine came off tight and i think thats why, its a REAL tight fit with the clips back in, so you might have to wiggle/pull the charger around to get the retaining clips in and bolted down. also, grease up the o ring strips to keep them in place when putting the charger back on. Everything else is pretty simple, minus getting the air out of the system when filling it with coolant. Its going to take the required amount of coolant so make sure you check how much you have put in. If i would have stopped without knowing the amount that its suppose to take I would have no coolant in there right now haha. Also, the water pump will be quiet once the air is all out. You will know the difference when you hear it. |
| The Following User Says Thank You to xxscaxx For This Useful Post: | civicdrivr (01-19-2014) |
#2725 | |
Mr. Cranky Pants
Drives: 2013 Argento FR-S
Bonus - the car in this video must have a metal intake, his Kenne Bell SC is loud as hell: [ame="http://www.youtube.com/watch?v=KYM1bFiN8X4"]SNAKEBITE MUSTANG COBRA - YouTube[/ame] |
#2726 | |
WUB WUB
post responded in bold
#2727 | |
That Guy
#2728 |
Drives: 2013 Subaru BRZ - DGM
| The Following 2 Users Say Thank You to Starscream15 For This Useful Post: | Captain Snooze (01-20-2014), wrxgoose (01-19-2014) |
#2729 |
Adding the Perrin intake made mine whine louder.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread) ![]() |
#2730 |
Drives: 2017 Camaro 1SS
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
