Old 01-11-2014, 10:03 PM   #71
FR-Sizzle
Drives: brz
Originally Posted by cslntuee View Post
I am still debating which throttle body I should go.
They are all pretty expensive and I never see any dyno result.
TODA one looks like a taper design from 72mm to 68 mm (pic1)
http://www.todaracingusa.com/catalog/pc/viewCategories.asp?idCategory=198
The image (pic2) shows the taper structure can push the air flow.
The revolution on is 70 mm, but there is one red adapter in the end.
I am not sure that will be same function as taper or is useless
How do you think? Thanks.
http://revo-tune.jp/catalogue/detail.php?id=294
Pretty sure that adapter is for the revolution x gruppem collaborated intake they made.
FR-Sizzle is offline   Reply With Quote
Old 01-14-2014, 11:29 PM   #72
cslntuee
Drives: Subaru BRZ Limited
The red adapter looks like for fitting the stock manifold.
cslntuee is offline   Reply With Quote
The Following 2 Users Say Thank You to cslntuee For This Useful Post:
Mr. (01-20-2014), soros151 (01-19-2014)
Old 01-19-2014, 12:54 PM   #73
soros151
SorosMotorsports
soros151's Avatar
Drives: Whiteout Pearl
Looks good. Now some ITB's.
soros151 is offline   Reply With Quote
Old 01-19-2014, 03:21 PM   #74
Zaneman
Drives: 2013 BRZ limited
I had a 72mm Tundra throttle body that with a spacer would fit. The DBW plugged in but I didn't test to see if it would work.
I'm under the impression that the intake manifold had a 3in opening.
Zaneman is offline   Reply With Quote
Old 01-28-2014, 05:37 PM   #75
nelsmar
Any updates?
My flickr - Canibeat
Local magazine scout
Old 01-28-2014, 05:48 PM   #76
MAPerformance
Drives: Asphalt FRS
Originally Posted by nelsmar View Post
Any updates?
Sorry man, its on the back burner for a bit. We really need to finish our turbo kit so I can get my car back LOL. But after that is done, we can start focusing our attention on it. These pesky drive by wire throttle bodies can be a bit tricky. But we will make it happen
MAPerformance is offline   Reply With Quote
Old 01-28-2014, 06:01 PM   #77
nelsmar
Did you do anything in the ECU to compensate for the CEL?
Old 01-28-2014, 06:32 PM   #78
MAPerformance
Drives: Asphalt FRS
Not yet, but at this point, we do not believe it is simply a tuning issue. There is air leaking somewhere in this thing. We may need to modify the throttle plate some more.
Old 01-31-2014, 03:55 AM   #79
NYCsubaruBRZ
Drives: 2013 Subaru BRZ & 99' Ford Explorer
are you going to half shaft the throttle body as well? or just p&p to 68mm?
NYCsubaruBRZ is offline   Reply With Quote
Old 01-31-2014, 10:02 AM   #80
MAPerformance
Drives: Asphalt FRS
We are still currently using the stock shaft, but we are looking into possibly replacing that as well. That could be part of our small air leak causing the high idle.
Old 01-31-2014, 11:08 PM   #81
NYCsubaruBRZ
yea id like to see this happen.
id buy a p&p and halfshaft tb right away
The Following User Says Thank You to NYCsubaruBRZ For This Useful Post:
MAPerformance (02-01-2014)
Old 02-24-2014, 04:28 PM   #82
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Updates??
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 02-25-2014, 01:14 PM   #83
MAPerformance
Drives: Asphalt FRS
Originally Posted by RehabJeff86 View Post
Updates??
Sorry man, nothing right now. But it will happen. Looks like its still on the back burner, but hopefully it happens soon. Should be able to test it on my boosted FRS soon as well once we get that all dialed in.
The Following User Says Thank You to MAPerformance For This Useful Post:
RehabJeff86 (02-26-2014)
Old 02-25-2014, 02:52 PM   #84
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
Waiting and watching closely. Personally, I would love to see this combined with the FBM intake manifold they are prototyping.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Cusco Throttle Body? track_warrior Engine, Exhaust, Transmission 66 06-28-2016 06:28 PM
Dirty throttle body AVOturboworld Engine, Exhaust, Transmission 11 05-11-2016 10:58 AM
Heated throttle body? Turdinator Engine, Exhaust, Transmission 19 04-06-2014 11:21 AM
YR-Advance Throttle Body ANREX Engine, Exhaust, Transmission 9 10-30-2012 01:45 AM
