Old 01-16-2014, 01:33 AM   #2073
tinma
Drives: '13 BRZ
Originally Posted by rayrush View Post
Hi, i am interested in gramlights 57 extreme in 18 x 8.5. They come in different offsets. My question is does the offset effect the concave? is so which one has the most concave in the 18 x 8.5? Thanks for any help. I am confused looking at the charts
I believe it is. I THINK the lower the offset, the more of a concave? I could be completely wrong though.
tinma is offline   Reply With Quote
The Following User Says Thank You to tinma For This Useful Post:
rayrush (01-16-2014)
Old 01-16-2014, 02:44 AM   #2074
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
It depends a bit on the Manufacturer. Some of them (most of them) only change the thickness of the wheelhub inside (that side that is mounted towards your car) so you dont see any changes from the outside. Some of them do change the Wheelhub from the outside, so you would have a deeper Wheelhub in the middle than normally (Only the part around where the lugnuts go in, not the whole wheel design)
I have not yet seen a wheel design that acutally the concave face has changed with the offset. (there may be out there, but I have not seen any yet)
Killerbee is offline   Reply With Quote
The Following User Says Thank You to Killerbee For This Useful Post:
Old 01-16-2014, 02:47 AM   #2075
Killerbee
Killerbee's Avatar
Im about to pull the trigger on Enkei RS05RR rims but i wanted to make sure first that this setup will be fine with stock suspension/height.
18x8.5 rims
tire size: P225/40ZR18
Is this setup free from rubbing? any suggestions are greatly appreciated!
Offset is missing to answer that question. Any offset around +35-40 will be fine.
The tires will be streched abit, you may want to think about 245/35/18 if you rather want a flush sitting tire on your wheels.
Also note that it will ad a bit "offroad" look to the car, so you may want to think about lowering it 1" or so. (wider wheels will add to the stock offroad look even more)
tinma (01-16-2014)
Old 01-16-2014, 02:49 AM   #2076
Killerbee
Killerbee's Avatar
Originally Posted by cncnjn View Post
Would 18x9.5 5x100 38mm offset fit? My car is also lowered about 1 inch all around on coilovers.
Will fit. You may want to add some camber so the wheels are not poking out that much in the front, but you will have no issues with rubbing either way
cncnjn (01-17-2014)
Old 01-16-2014, 02:59 AM   #2077
rayrush
Drives: gt86
Thanks for your replies!!!
Next question is will 57xtreme 18 x 8.5 + 42 fit whiteout any dramas or poke?
Any tire size recommendations?
rayrush is offline   Reply With Quote
Old 01-16-2014, 03:26 AM   #2078
Killerbee
Killerbee's Avatar
On Stock suspension this is really tight to the inner struits. I do recommend to take a +35 or a +38. (Still, I GUESS that +42 should work out, but im not 100% sure. The +35/+38 work however 100% sure on that)
Tires are 225/40/18 if you want it cheap and dont mind a bit strech, or 245/35/18 if you can afford a bit more and like to have a flush sitting tire on your wheels
Old 01-16-2014, 03:21 PM   #2079
tinma
Drives: '13 BRZ
wider as in going 18? or the 8.5?
Old 01-16-2014, 05:01 PM   #2080
Killerbee
Killerbee's Avatar
As in 8.5 wheels, it will just look way more offroad because of the agressive wheels.
See yourself
Stock Susp with Stock Wheels -> http://www.ft86club.com/forums/showp...82&postcount=9
Stock Susp with 8.75 Wheels -> http://www.ft86club.com/forums/showp...4&postcount=98
1" Drop with 8.75 Wheels -> http://www.ft86club.com/forums/showp...&postcount=127
Old 01-16-2014, 07:18 PM   #2081
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Looking at a set of Rota Torques, 17x9 et 30.
Will this rub at full turn? I'm looking at using 225 width tires - Too much stretch?
This is all on stock suspension (and I don't plan to drop or change it)
Thanks!
daiheadjai is offline   Reply With Quote
Old 01-16-2014, 07:50 PM   #2082
bildo
Drives: FT86 ZN6
Hi guys,
Im looking at buying 18x9.5s on all corners for my 86.
i was hoping to get it lowered on eibach sportline springs, is this possible or do i need to have coilovers to pull this off...
Im not sure what offset or tyre size i should be looming at too...
Any help would be great thanks!!
Sent from my GT-I9505 using Tapatalk
bildo is offline   Reply With Quote
Old 01-16-2014, 07:50 PM   #2083
bildo
Drives: FT86 ZN6
Woop forgot to mention Rays 57xtremes SP spec.
Old 01-17-2014, 02:42 AM   #2084
Killerbee
Killerbee's Avatar
Originally Posted by bildo View Post
Hi guys,
Offset is important in that question. If you take +35 or +38 you're fine, however there will be 5-10mm poke in the front if you dont add camber. Tires you should go for 245/35/18 in that dimension
Thanks!
Well, you can run this setup, but be aware of the following:
-The Wheels will poke out, specially because you're not changing your suspension. Expect about 10mm in the front, and 6-8mm in the rear
-225 will strecht quiet a bit. If you want to drive it spirited you should consider taking 245/40/17
daiheadjai (01-17-2014)
Old 01-17-2014, 03:49 AM   #2085
mike the snake
On my car, with 18x8.5 and 18x9.5 both with 45 offset, the fronts are inset more than the rears.
The rears are perfectly flush, but the fronts could use maybe 5-10mm spacer to be perfectly flush.
Not sure if "poke" means inset, or sticking out past the fender, but in any case, the rears seem to be further inset than the fronts.
Old 01-17-2014, 07:59 AM   #2086
cncnjn
Drives: Raven FRS Veilside Nissan 350z
Thanks a bunch
cncnjn is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
