Old 01-13-2014, 04:02 PM   #29
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by SirBrass View Post
At least we have a control unit that can mount to the column without being awkward, even if the electronics after it are entirely DIY. That much is worth something.
If the right unit is selected, it won't be as bad as all that. We just need to pick one for a car that uses a three wire resistor connection, like the one nalc found, the 2013 Impreza. That car even uses the same resistor values.
After that it is just a matter of connecting the wires.
I'm going to have my audio installer do the universal stalk for the Sony 701HD I want to get. I like touch screens, but when it comes to audio adjustment and track/freq changing while on the move, I want physical buttons (even if they're soft keys on the HU), not on-screen soft keys.
This should be mind-numbingly easy. A modern aftermarket H/U should be recognized by the box and set up automatically. Impressively plug and play.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 01-13-2014, 05:09 PM   #30
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Yup, indeed. The Axxess will do it automatically. The only thing I lack are the tools to do the mounting.
^GT5 Replay Photo Mode^
Old 01-14-2014, 02:57 PM   #31
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i want this. which one will work with a BRZ, i'll gladly buy, install and mount.
i'd prefer the one that mounts to the wheel, not the stalk, i'd end up cutting that apart and mounting somewhere easy to access by me.
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
xxscaxx (01-14-2014)
Old 01-14-2014, 03:03 PM   #32
laguayo
laguayo's Avatar
Drives: BRZ Limited DGM Automatic
Anyone know any similar SWC from another vehicle that would match the same resistance values needed by the brz? I just need that little black box with the switches and I could basically mount switches anywhere. The stalk sounds like too much $$$ for the little black box.
laguayo is offline   Reply With Quote
Old 01-14-2014, 03:18 PM   #33
mid_life_crisis
I was looking at that one, which also has more controls on it, by the way, and wondered if the strap was long enough to mount to a spoke instead of the rim of the steering wheel. If so, could it be operated with a thumb?
Old 01-14-2014, 03:24 PM   #34
mid_life_crisis
There is no little black box in the cars that use a similar setup. The box is needed here because it is taking a signal from the stalk and converting it to a different type of signal. The cars don't need that conversion between the factory SWCs and the factory H/U.
Factory to factory - no box needed.
Factory to aftermarket - needs electronic box.
Aftermarket to aftermarket - needs electronic box.
In the case of the twins a factory H/U to simple momentary switches needs a home made black box with a resistor array in it.
Read these:
http://www.ft86club.com/forums/showthread.php?t=39244
http://www.ft86club.com/forums/showthread.php?t=44827
http://www.ft86club.com/forums/showthread.php?t=51941
Note that the pin # discrepancy is just due to perspective. Are you looking at the port on the back of the H/U or at the end of the plug that gets inserted?
Old 01-14-2014, 03:42 PM   #35
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
I'd even love to put just a next/previous track button on the panel trim just to the left of the radio.
nocturne1 is offline   Reply With Quote
Old 01-14-2014, 03:50 PM   #36
mid_life_crisis
Very easy to do. Hardest part is making a nice cutout.
The BRZ only has touchscreen buttons for that?
Damn, and I'm ticked off because the FR-S unit doesn't have a mode button.
Old 01-14-2014, 03:57 PM   #37
laguayo
laguayo's Avatar
Read these:
Thanks I've read through most of those post I was just wondering if anyone knew any other OEM SWC I could get cheaper than the axxiss and was hoping to avoid having to make my own solution.
This is the post http://www.ft86club.com/forums/showp...5&postcount=42 that really blew my mind.
But given the simplicity I might just build my own.
Old 01-14-2014, 04:25 PM   #38
mid_life_crisis
This is the post http://"http://www.ft86club.com/foru...5&postcount=42 that really blew my mind.
If this is the post I think it is, don't forget that it isn't 6,7,8: it is 20,21,22. It can get extra confusing because 6,7,8 are directly above 20,21,22.
I would read post #2 carefully before building my own.
Old 01-14-2014, 10:02 PM   #39
nalc
Drives: 13 BRZ Limited 6MT GBS
2012+ Impreza SWCs are plug and play.
Based on investigation in another thread, it sounds like there is a possibility that most Toyota SWCs, while they don't have exactly the right values for the Subaru, are close enough that they'd still work properly, but I haven't tested.
Current gen Legacy SWCs are compatible if you're willing to do some surface mount soldering. I've got a standing offer to anyone who is gung ho enough to try it - I'll mail you all the resistors you need, for free. I ordered them all and did the conversion and I've got 100 of each value.
That's simple enough to do. Two resistors and a double pole momentary rocker.
nalc is offline   Reply With Quote
Old 01-14-2014, 10:41 PM   #40
mid_life_crisis
If you are referencing my thread, the resistors on the board are effectively the same as what you found. The value I quoted is the total for each switch, not the individual resistors. Remember, each switch uses all the resistors below it, so the value working on the switch is more than the resistor it is connected directly to.
You might reread post #2, where I summarized my findings.
Of course these values might be unique to the new Scions, I don't know.
Old 01-16-2014, 08:56 AM   #41
nalc
No, they're not the same, because I quoted the total for each switch as well. It just so happens that the total for the Subaru switches seems to be about the same as the increment for the Toyota switch. So when you posted the increments, and they were the same as the totals I posted, I think you thought that I had posted increments too.
The BRZ is
0
0 + 330 = 330
330 + 670 = 1000
330 + 670 + 2110 = 3110
Your post is this:
0
0 + 330 = 330
330 + 1000 = 1.3K
1300 + 3110 = 4.7K
However, the tolerance band on the HU is big enough that either will work. I'm just pointing out that your measured values don't match the BRZ shop manual, I think the confusion is because your increments happened to match my totals.
Old 01-16-2014, 11:40 AM   #42
mid_life_crisis
The BRZ is
0
0 + 330 = 330
330 + 670 = 1000
Your post is this:
0
0 + 330 = 330
330 + 1000 = 1.3K
1300 + 3110 = 4.7K
I have yet to find an official document listing the values for a Scion. Mine are based on testing and shop manual values for another Toyota, I don't know which. For all I know, the 2014 Scions could all use the same values as the BRZ.
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
Electric power steering assist to remote control SeanBlader BRZ First-Gen (2012+) — General Topics 6 01-07-2014 10:16 AM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
BRZ STI Steering wheel??? tacoss23 Cosmetic Modification (Interior/Exterior/Lighting) 9 08-26-2013 07:30 PM
