Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
11-22-2013, 10:31 AM | #1 |
Drives: FR-S 10 #103 AT
FR-S Audio pinout help needed
There is a very interesting writeup for the BRZ that makes use of the steering wheel switch pins for the radio. Apparently they are:
21 SWC1 Audio (Seek, Volume) 22 SWC2 Mode & Phone 23 SWC Common I'm trying to learn/verify what the corresponding pins are on the FR-S, specifically the base Pioneer used in the anniversary edition and as the base unit in the 2014. The other Scions have steering wheel controls, so something along these lines exists for this unit.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
11-26-2013, 12:45 PM | #2 |
This post was originally used to bump the thread and whine about not getting any help. I'm taking it to put a summary at the beginning of the thread.
At this point we know it works exactly as described for the FR-S base H/U used in the Anniversary edition and all 2014 Scions. It also works for the Fujitsu Ten w/Nav unit in the BRZ. On the back of the H/U there is a 28 pin connector. Looking at the connector from the back of the radio, counting left to right. Bottom row, Pins 20, 21 & 22. These three go to the steering wheel controls. 20 - common 21 - SW2 22 - SW1 The operation performed is controlled by the amount of resistance connected across the common and one of the SW pins. Here is what I have learned so far thanks to the generous assistance of a few members. SW1 0 - preset down/ scan up (radio) Next track (bluetooth, CD) 330 - preset up/scan down Previous track (bluetooth, CD) 1.3k - vol up 4.7k - vol down SW2 0 - mode/mute toggle 330- Hang up phone 1.3k - Enter phone menu and step through 4.7k - Pick up phone These values are if multiple switches are set up in parallel to each pin with one resistor per switch. The factory does not use that type of circuit. They build a series ladder so each level adds the previous ones to itself to create the totals listed above, so the factory circuit board has 0, 330, 1.0k, and 3.3k. The factory also puts a 100k resistor across the common/SW1 and common/SW2 connections (2 resistors total) for stability. This post has links to must have manuals for working on the audio system. http://www.ft86club.com/forums/showp...5&postcount=34
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." Last edited by mid_life_crisis; 01-07-2014 at 11:24 AM. |
11-28-2013, 11:46 PM | #3 |
Drives: fr-s
Actually I have been looking for the same info. Getting ready to install the backup camera and nav unit. Would like to know if any other pins on the 2014 hu can be used for other purposes.
11-30-2013, 02:23 PM | #4 |
Drives: Moped
http://www.ft86club.com/forums/showthread.php?t=29027
...would anything in the previous link help? (It had quite a few diagrams but I'm not sure if it has what you need) |
12-01-2013, 12:43 AM | #5 | |
12-01-2013, 09:30 PM | #6 |
Drives: Moped
12-07-2013, 11:12 PM | #7 |
Sooner or later someone will have the answer.
12-12-2013, 11:48 PM | #8 |
Still hoping.
12-18-2013, 10:00 AM | #9 |
Just keeping this on the first page until someone who has the information sees it.
12-18-2013, 04:23 PM | #11 |
I truly appreciate the effort, but I think my best bet is going to be that same thing from a 14 tc. I have the same request posted on a Scion site but no luck there yet either.
The problem is that the wires that I need don't exist in an FR-S. The pins are on the radio, but they aren't connected to anything.
12-18-2013, 04:34 PM | #12 | |
Professional Smartass
Drives: White Out FRS
12-18-2013, 04:57 PM | #13 | |
I'm not interested in steering wheel controls though. I want to do what a couple of the BRZ guys did. One created a pad that sits where the coin tray is between the shift lever and the center console.
12-18-2013, 05:43 PM | #14 | |
Similar Threads | ||||
Pinout for FRS Bespoke head unit - video inputs? | ATSAaron | Electronics | Audio | NAV | Infotainment | 2 | 12-09-2014 10:59 PM |
Audio Guru help needed | Thongpocket | Electronics | Audio | NAV | Infotainment | 17 | 10-03-2013 06:13 AM |
Audio genius needed... | Shit Luck | Electronics | Audio | NAV | Infotainment | 36 | 06-05-2013 06:09 PM |
SoCal Audio Shop Needed | dlux | Southern California | 5 | 05-17-2013 05:24 PM |
ECU Pinout? | Argento_FR-S | Engine, Exhaust, Transmission | 5 | 03-08-2013 10:19 AM |
